[Sold] ER-OLEDM032 (SSD1322) 3.2" OLED USB interface
  • 2 months later...
Just replying back with some feedback.
Although I wasn't using this with AIDA64 (rather, I was using Python and Ubuntu to monitor my ESXi Home Lab), the kit worked perfectly so kudos added to you Romain :)
I will now be getting Aida64 to use it with my desktop :)
Here's a couple of photos...
That looks awesome!
  • 6 months later...
I'm from China.First of all, please forgive my poor English.....
I have a very small itx chassis, and I want to be able to fit a larger OLED display in a limited volume to monitor hardware status.
So I found an OLED display on Taobao,The parameters of the display are as follows
  • Size: 3.83inch
  • Resolving power: 320x132
  • Control chip: Two  SSD1320
  • Interface type:  SPI
  • Pin count:  10
Pin assignment
PIN 1      GND       Power grounding
PIN 2      VCC       Positive pole of power supply,Range:2.9-3.3V
PIN 3      SCL       Clock pin
PIN 4      SDA       Data pin
PIN 5      RES       Reset pin,Low potential effective
PIN 6      DC       Control
PIN 7     CS1       The first one Chip selection
PIN 8      CS2       The second one Chip selection
PIN 9      FR1       The first one  Signal synchronization
PIN 10      FR2       The second one Power grounding
Product pictures
To connect this OLED display to the computer,I bought a FT232H module.
Product pictures
So......I found your way to connect the hardware,But they can't work...........
My question
  1. FT232H Can  connect two ssd1320?If  can connect,How to connect.
  2. How to choose Ft232h driver ,VCP?D2XX?Libusb?
  3. How to set Ft232h pattern in the FT_Prog,like mode?IO pin?
  4. How to set AIDA64,choose api?
  • Size: 3.83inch
  • Pin count:  10
Pin assignment
PIN 3      SCL       Clock pin
PIN 4      SDA       Data pin
PIN 6      DC       Control
Product pictures
Product pictures
My question
I'm afraid we're not skilled in hardware development issues.  Maybe the topic opener romP44 can chime in.
  • 9 months later...
Hi all,
I'm back on this forum 1 year and a half... :rolleyes:
I see some people would be interested by a new batch. Please, can you confirm it? Anybody else?
  • 5 months later...
i'm using a FT232H module from CJMCU(cjmcu.taobao.com) and a different brand oled module(still ssd1322).The CJMCU FT232H module can't configure C6 as IO mode,so i remain it as default(Tristate) and it still works fine.
  • 5 months later...
On 6/4/2021 at 8:53 PM, romP44 said:
Hi all,
Would be intrested :-)
