Sensor CPU temp display incorrect? (MSI X58 Pro-E)
The Sensorpanel CPU Temperature display appears to be incorrect... it displays in the 15-19C range, but the Power-Up System BIOS Hardware Monitor shows upper 26/27C. Initially there is an occasional sample displayed at/near the correct value, but after a minute or 3, it settles out in the teens.
------[ AIDA64 v2.20.1822 Beta ]------
------[ Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 (32-bit) ]------
Motherboard ID : 66-2776-009999-00101111-031911-TYLSBURG$A7522800_A7522IMS V8.15 031911
Motherboard Model : MSI X58 Pro-E (MS-7522)
Motherboard Chipset : Intel Tylersburg X58, Intel Nehalem
DMI MB Manufacturer : MSI
DMI MB Product : MSI X58 Pro-E (MS-7522)
DMI MB Version : 3.0
DMI MB Serial : To be filled by O.E.M.
DMI SYS Manufacturer: MSI
DMI SYS Product : MS-7522
DMI SYS Version : 3.0
DMI SYS Serial : To Be Filled By O.E.M.
DMI BIOS Version : V8.15
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 00h
Winbond SuperIO HWMonitor Port = 0000h
Winbond SuperIO Device ID = 0541h
Fintek SuperIO Port = 4Eh
Fintek SuperIO HWMonitor Port = 0A00h
Fintek SuperIO Device ID = 0541h
LPC47 SuperIO Device ID = FFFFh
------[ LM78 ISA Sensor Device at 0A00 ]------
0000 FF 03 00 00 FF FF FF FF FF FF 01 00 4F 4C 00 00
0010 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
0020 D4 92 18 06 76 8A 28 D0 CC FF FF FF FF FF FF FF
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0050 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
0060 00 00 00 00 FF FF 00 00 00 00 FF 0C 40 24 FF 00
0070 FF FF 11 FF 43 FF 23 FF FF FF FF FF FF FF FF FF
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF A8 FF
0090 00 08 08 00 56 FF 7F FF 42 24 FF AA 55 55 FF 0A
00A0 02 F7 00 FF 02 F3 3C 32 28 1E FF E5 CE B7 A0 0D
00B0 04 83 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E
00C0 05 5D 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
00D0 0F FF 00 FF 03 FF 64 64 64 64 FF FF FF FF FF 0F
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00F0 00 00 00 00 00 00 3D FF 03 5E FF 00 FF FF FF FF
0070 0072 0074 0076 0078 0079 007A 007B 007C 007D 007E 007F
T: 255 17 67 35 255 255 255 255 255 255 255 255
T: 255 17 66 35 255 255 255 255 255 255 255 255
T: 255 16 67 35 255 255 255 255 255 255 255 255
T: 255 15 66 34 255 255 255 255 255 255 255 255
T: 255 15 67 35 255 255 255 255 255 255 255 255
Reg$20 CPU Core: r = 212, r*0.016 = 3.39
Reg$21 CPU Aux: r = 146, r*0.016 = 2.34
Reg$22 +3.3 V: r = 24, r*0.016 = 0.38
Reg$23 +5 V: r = 6, r*0.016 = 0.10
Reg$24 +12 V: r = 118, r*0.016 = 1.89
Reg$25 -12 V: r = 138, r*0.016 = 2.21
Reg$26 -5 V: r = 40, r*0.016 = 0.64
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
In the BIOS Setup processors are unable to execute halt cycles to put their clocks down in order to cool themselves down. Hence if in the BIOS Setup you can see 20+ Celsius, but AIDA64 measures 15-19C, it may be correct. Please compare AIDA64 values against MSI Control Center values.
Downloaded/installed MSI Control Center and found CPU temp under Green Power/Basic. The two values match.
Sorry to have bothered.
