Aida 64 Extreme shows wrong CPU VCore ASROCK Z390M-ITX/ac, i7-8700K
Hi,
Aida64 extreme shows VCORE value the same as VID. I have set manual voltage and HWINFO64 reports 1.264V while AIDA64 reports 1.367. I see that this issue is frequent?
Best Regards,
Teemu
  • 3 weeks later...
Just to note that this issue was not resolved with the latest update.
I think it is weird that you cannot see the CPU vCore BEFORE you buy the license. Only after you bought it you see if it shows correct or not. Of course I assumed this value would be read correctly.
  • 3 weeks later...
We've checked, and your motherboard is supposed to be fully supported by AIDA64 v6.32.  If it's possible, please post a screenshot of the Computer / Sensor page of AIDA64.  Make sure to try to make all sensor readings visible by resizing the AIDA64 window to its maximum height that fits on your Windows Desktop.
Also please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
