EvilPants Posted February 24, 2021 Posted February 24, 2021 I got R5 3600 gpu RX580 my pc keep restarting every time I play sometimes I can play like 1 hour then after that it will restart, not only gaming but even editing and Idle time but most of the time when I'm gaming Quote
Fiery Posted February 24, 2021 Posted February 24, 2021 33 minutes ago, Newri Renomeron said: I got R5 3600 gpu RX580 my pc keep restarting every time I play sometimes I can play like 1 hour then after that it will restart, not only gaming but even editing and Idle time but most of the time when I'm gaming Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
EvilPants Posted February 25, 2021 Author Posted February 25, 2021 I follow your instruction but it seems nothing happen unless i turned off the gpu sensor that's works magically Quote
Fiery Posted March 12, 2021 Posted March 12, 2021 On 2/25/2021 at 12:42 PM, Newri Renomeron said: I follow your instruction but it seems nothing happen unless i turned off the gpu sensor that's works magically Thank you. We'll try to find out what's going on. There must be an issue with AMD's own video drivers that causes these headaches. Quote
EvilPants Posted April 10, 2021 Author Posted April 10, 2021 any udpates about the system reboot? Quote
Mice007 Posted April 11, 2021 Posted April 11, 2021 We are still trying to figure out whats the catch with the AMD drivers. Quote
Squall Leonhart Posted April 14, 2021 Posted April 14, 2021 I've put this towards a vanguard user to try and get a repro and then forward onto AMD, theres clearly an issue with a driver mutex or kernel memory corruption when the two software are paired that needs to be investigated from there end. 1 1 Quote
