Hello,
With the Intel drivers RSTe (X79) AIDA64 does not read correctly the temperature of SSD/HDD (stuck at 25°C)
With Crystal Disk Info, this is the right temperature (see screen)
Please let us know which version of Intel RSTe Drivers do you have installed, and what is your storage configuration? (AHCI mode or RAID mode? Any RAID arrays defined?)
Thank you. Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic.
Thanks :) If you don't have a RAID array defined, then please try to disable the option RAID member enumeration in AIDA64 Preferences / Stability. You need to restart AIDA64 after altering that option.
Please copy-paste or attach both a Disk Debug / ATA Dump and a Disk Debug / SMART Dump in both these states:
- State #1 is RAID member enumeration option enabled + RAID SMART support option enabled
- State #2 is RAID member enumeration option disabled+ RAID SMART support option disabled
Please don't forget to restart AIDA64 after altering those options in the Preferences ;)
What I means is: first please enable both mentioned options, restart AIDA64, and then create an ATA Dump, and then create a SMART dump.
Then, disable the two mentioned options, restart AIDA64, and then create an ATA Dump, and then create a SMART dump.
ok Fiery
ATA Dump
------[ AIDA64 v2.30.1947 Beta ]------
------[ Microsoft Windows 7 Professional 6.1.7601 Service Pack 1 (64-bit) ]------
Motherboard ID : 63-0100-000001-00101111-102010-Chipset$1APEQ006_BIOS DATE: 04/10/12 11:21:32 VER: 13.05
Motherboard Model : Asus Rampage IV Extreme
Motherboard Chipset : Intel Patsburg X79, Intel Sandy Bridge-E
DMI MB Product : RAMPAGE IV EXTREME
DMI MB Version : Rev 1.xx
DMI MB Serial : MT7022K48500701
DMI SYS Product : System Product Name
DMI SYS Version : System Version
DMI SYS Serial : System Serial Number
DMI BIOS Version : 1305
------[ PCI Devices ]------
B00-D1F-F02 [8086-1D02] [1043-84EF] [CC0106]: Intel Patsburg PCH - SATA AHCI 6-Port Controller [C-0]
------[ USB Devices ]------
[HID\VID_046D&PID_C525]: Périphérique conforme aux Périphériques d'interface utilisateur (HID)
[HID\VID_046D&PID_C525]: Périphérique de contrôle consommateur conforme aux Périphériques d'interface utilisateur (HID)
[HID\VID_046D&PID_C525]: Souris HID
[uSB\VID_046D&PID_C525]: Périphérique d’entrée USB (0000.001d.0000.001.001.000.000.000.000)
[uSB\VID_046D&PID_C525]: Périphérique USB composite (Port_#0001.Hub_#0004)
[uSB\VID_8087&PID_0024]: Generic USB Hub (Port_#0001.Hub_#0001)
[uSB\VID_8087&PID_0024]: Generic USB Hub (Port_#0001.Hub_#0002)
------[ Windows Devices / IDE Controllers ]------
------[ Windows Devices / RAID/SCSI Controllers ]------
Driver Desc : Intel® C600 Series Chipset SATA AHCI Controller
Driver Date : 3-15-2012
Driver Version : 3.1.0.1068
Driver Provider: Intel Corporation
------[ ATA Device 0 ]------
------[ ATA Device 1 ]------
------[ ATA Device 2 ]------
0000 40 00 FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00 @..?7.......?...
0010 00 00 00 00 53 30 56 59 4E 59 41 43 32 30 38 33 ....S0VYNYAC2083
0020 35 36 20 20 20 20 20 20 00 00 00 00 00 00 43 58 56 ......CX
0030 4D 30 33 42 31 51 53 41 4D 53 55 4E 47 20 53 53 M03B1QSAMSUNG SS
0040 44 20 38 33 30 20 53 65 72 69 65 73 20 20 20 20 D 830 Series
0050 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80 ..
0060 00 40 00 2F 00 40 00 02 00 02 07 00 FF 3F 10 00 .@./.@.......?..
0070 3F 00 10 FC FB 00 10 01 B0 C2 E7 0E 00 00 07 00 ?...............
0080 03 00 78 00 78 00 78 00 78 00 00 0E 00 00 00 00 ..x.x.x.x.......
0090 00 00 00 00 00 00 1F 00 0E 05 06 00 4C 00 40 00 ............L.@.
00A0 FC 03 31 00 6B 74 01 7D 63 41 69 74 01 BC 63 41 ..1.kt.}cAit..cA
00B0 7F 20 03 00 10 00 00 00 FE FF 00 00 00 00 00 00 ..............
00C0 00 00 00 00 00 00 00 00 B0 C2 E7 0E 00 00 00 00 ................
00D0 00 00 08 00 00 40 00 00 02 50 80 53 58 43 30 4D .....@...P.SXC0M
00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 40 ...............@
00F0 18 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
0100 29 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 )...............
0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0150 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01B0 00 00 01 00 00 00 00 00 00 00 00 00 3F 10 00 00 ............?...
01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01D0 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 ................
01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 33 ...............3
------[ ATA Device 3 ]------
0000 C0 85 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0010 00 00 00 00 52 31 32 39 36 47 43 53 42 30 30 31 ....R1296GCSB001
0020 33 32 30 30 20 20 20 20 00 00 00 00 00 00 53 42 3200 ......SB
0030 30 34 20 20 20 20 54 53 53 54 63 6F 72 70 20 43 04 TSSTcorp C
0040 44 44 56 44 57 20 53 48 2D 53 32 32 33 4C 20 20 DDVDW SH-S223L
0050 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 ..
0060 00 00 00 0F 00 00 00 02 00 02 06 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 ................
0080 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 ..x.x.x.x.......
0090 00 00 F8 00 10 02 00 00 02 02 00 00 68 00 40 00 ............h.@.
00A0 F8 00 10 02 10 02 00 00 00 00 00 00 00 00 00 00 ................
00B0 3F 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ? ..............
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 54 ...............T
------[ ATA Device 4 ]------
0000 5A 0C FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00 Z..?7.......?...
0010 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20 ....
0020 39 56 4D 32 34 59 35 4D 00 00 00 80 04 00 43 43 9VM24Y5M......CC
0030 34 39 20 20 20 20 53 54 33 35 30 30 34 31 38 41 49 ST3500418A
0040 53 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 S
0060 00 00 00 2F 00 40 00 02 00 02 07 00 FF 3F 10 00 .../.@.......?..
0070 3F 00 10 FC FB 00 10 01 FF FF FF 0F 00 00 07 00 ?...............
0090 00 00 00 00 00 00 1F 00 06 05 00 00 48 00 40 00 ............H.@.
00A0 F0 01 29 00 6B 34 01 7F 63 41 69 34 01 BE 63 41 ..).k4.cAi4..cA
00B0 7F 20 2A 00 2A 00 00 00 FE FF 00 00 D0 D0 00 00 *.*...........
00C0 00 00 00 00 00 00 00 00 30 60 38 3A 00 00 00 00 ........0`8:....
00D0 00 00 00 00 00 00 00 00 00 50 00 C5 6C 15 37 0A .........P..l.7.
00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 40 ...............@
00F0 1C 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
0100 29 00 30 60 38 3A 30 60 38 3A 20 20 02 00 40 01 ).0`8:0`8: ..@.
0110 00 01 00 50 06 3C 0A 3C 00 00 3C 00 00 00 08 00 ...P.<.<..<.....
0120 00 00 00 00 4F 00 80 02 00 00 00 00 08 00 00 00 ....O...........
0130 00 00 00 00 00 00 00 00 00 00 00 00 00 3F 00 98 .............?..
0190 00 00 00 00 00 00 00 00 00 00 00 00 3F 10 00 00 ............?...
01B0 00 00 20 1C 00 00 00 00 00 00 00 00 10 10 00 00 .. .............
01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 16 ................
Smart Dump
------[ SMART List ]------
<ORD>A0001</ORD><MODEL>ATA SAMSUNG SSD 830</MODEL><SERIAL>S0VYNYAC208356</SERIAL><REV>3B1Q</REV><DEVTYPE>SATA</DEVTYPE><SPTIPATH>\\?\scsi#disk&ven_ata&prod_samsung_ssd_830#4&19bf6b6&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SPTIPATH><SPTITEMP>1</SPTITEMP><PRIORITY>5</PRIORITY><MODSER>ATA SAMSUNG SSD 830</MODSER><LASTTEMP>255</LASTTEMP>
<ORD>A0002</ORD><MODEL>ATA ST3500418AS</MODEL><SERIAL>9VM24Y5M</SERIAL><REV>CC49</REV><DEVTYPE>SATA</DEVTYPE><SPTIPATH>\\?\scsi#disk&ven_ata&prod_st3500418as#4&19bf6b6&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SPTIPATH><SPTITEMP>1</SPTITEMP><PRIORITY>5</PRIORITY><MODSER>ATA ST3500418AS</MODSER><LASTTEMP>255</LASTTEMP>
<ORD>R0001</ORD><MODEL>SAMSUNG SSD 830 Series</MODEL><SERIAL>S0VYNYAC208356</SERIAL><REV>CXM03B1Q</REV><IDBUFSIZE>512</IDBUFSIZE><RAIDMEMBER>1</RAIDMEMBER><SMARTINFO>1</SMARTINFO>
<INTSASSMARTCTRL>0</INTSASSMARTCTRL><INTSASSMARTDEV>0</INTSASSMARTDEV><PRIORITY>9</PRIORITY><MODSER>SAMSUNG SSD 830 Series</MODSER><LASTTEMP>26</LASTTEMP>
<ORD>R0002</ORD><MODEL>TSSTcorp CDDVDW SH-S223L</MODEL><SERIAL>R1296GCSB0013200</SERIAL><REV>SB04</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>1</ATAPIDEV><RAIDMEMBER>1</RAIDMEMBER>
<PRIORITY>9</PRIORITY><MODSER>TSSTcorp CDDVDW SH-S223L</MODSER>
<ORD>R0003</ORD><MODEL>ST3500418AS</MODEL><SERIAL>9VM24Y5M</SERIAL><REV>CC49</REV><IDBUFSIZE>512</IDBUFSIZE><RAIDMEMBER>1</RAIDMEMBER>
<SMARTINFO>1</SMARTINFO><INTSASSMARTCTRL>0</INTSASSMARTCTRL><INTSASSMARTDEV>3</INTSASSMARTDEV><PRIORITY>9</PRIORITY><MODSER>ST3500418AS</MODSER>
<LASTTEMP>29</LASTTEMP>
------[ SMART Device 2 ]------
0000 01 00 - 01 00
0000 05 33 00 64 64 00 00 00 00 00 00 00 - 05 0A 00 00 00 00 00 00 00 00 00 00
0010 09 32 00 63 63 BD 00 00 00 00 00 00 - 09 00 00 00 00 00 00 00 00 00 00 00
0020 0C 32 00 63 63 4C 00 00 00 00 00 00 - 0C 00 00 00 00 00 00 00 00 00 00 00
0030 B1 13 00 63 63 05 00 00 00 00 00 00 - B1 00 00 00 00 00 00 00 00 00 00 00
0030 B3 13 00 64 64 00 00 00 00 00 00 00 - B3 0A 00 00 00 00 00 00 00 00 00 00
0040 B5 32 00 64 64 00 00 00 00 00 00 00 - B5 0A 00 00 00 00 00 00 00 00 00 00
0050 B6 32 00 64 64 00 00 00 00 00 00 00 - B6 0A 00 00 00 00 00 00 00 00 00 00
0060 B7 13 00 64 64 00 00 00 00 00 00 00 - B7 0A 00 00 00 00 00 00 00 00 00 00
0060 BB 32 00 64 64 00 00 00 00 00 00 00 - BB 00 00 00 00 00 00 00 00 00 00 00
0070 BE 32 00 4A 42 1A 00 00 00 00 00 00 - BE 00 00 00 00 00 00 00 00 00 00 00
0080 C3 1A 00 C8 C8 00 00 00 00 00 00 00 - C3 00 00 00 00 00 00 00 00 00 00 00
0090 C7 3E 00 FD FD 00 00 00 00 00 00 00 - C7 00 00 00 00 00 00 00 00 00 00 00
0090 EB 12 00 63 63 37 00 00 00 00 00 00 - EB 00 00 00 00 00 00 00 00 00 00 00
00A0 F1 32 00 63 63 09 4C 31 38 00 00 00 - F1 00 00 00 00 00 00 00 00 00 00 00
00B0 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
00C0 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
00D0 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
00E0 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
00F0 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0100 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0110 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0120 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0130 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0140 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0150 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0160 00 00 00 00 FF 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0170 02 00 1C 02 00 5B 03 00 01 00 02 09 - 00 00 00 00 00 00 00 00 00 00 00 00
0180 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0190 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01A0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01B0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01C0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01D0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01E0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01F0 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01F0 00 00 00 00 00 11 - 00 00 00 00 00 4E
------[ SMART Device 4 ]------
0000 0A 00 - 01 00
0000 01 0F 00 73 63 4E EF CB 05 00 00 00 - 01 06 00 00 00 00 00 00 00 00 00 00
0010 03 03 00 61 61 00 00 00 00 00 00 00 - 03 00 00 00 00 00 00 00 00 00 00 00
0020 04 32 00 61 61 1A 0E 00 00 00 00 00 - 04 14 00 00 00 00 00 00 00 00 00 00
0030 05 33 00 64 64 00 00 00 00 00 00 00 - 05 24 00 00 00 00 00 00 00 00 00 00
0030 07 0F 00 51 3C 59 65 DD 07 00 00 00 - 07 1E 00 00 00 00 00 00 00 00 00 00
0040 09 32 00 56 56 4E 30 00 00 00 00 00 - 09 00 00 00 00 00 00 00 00 00 00 00
0050 0A 13 00 64 64 00 00 00 00 00 00 00 - 0A 61 00 00 00 00 00 00 00 00 00 00
0060 0C 32 00 63 63 09 07 00 00 00 00 00 - 0C 14 00 00 00 00 00 00 00 00 00 00
0060 B7 32 00 64 64 00 00 00 00 00 00 00 - B7 00 00 00 00 00 00 00 00 00 00 00
0070 B8 32 00 64 64 00 00 00 00 00 00 00 - B8 63 00 00 00 00 00 00 00 00 00 00
0080 BB 32 00 25 25 3F 00 00 00 00 00 00 - BB 00 00 00 00 00 00 00 00 00 00 00
0090 BC 32 00 64 63 16 00 00 00 00 00 00 - BC 00 00 00 00 00 00 00 00 00 00 00
0090 BD 3A 00 42 42 22 00 00 00 00 00 00 - BD 00 00 00 00 00 00 00 00 00 00 00
00A0 BE 22 00 47 3C 1D 00 11 1E 00 00 00 - BE 2D 00 00 00 00 00 00 00 00 00 00
00B0 C2 22 00 1D 28 1D 00 00 00 07 00 00 - C2 00 00 00 00 00 00 00 00 00 00 00
00C0 C3 1A 00 1C 11 4E EF CB 05 00 00 00 - C3 00 00 00 00 00 00 00 00 00 00 00
00C0 C5 12 00 64 64 00 00 00 00 00 00 00 - C5 00 00 00 00 00 00 00 00 00 00 00
00D0 C6 10 00 64 64 00 00 00 00 00 00 00 - C6 00 00 00 00 00 00 00 00 00 00 00
00E0 C7 3E 00 C8 C8 07 00 00 00 00 00 00 - C7 00 00 00 00 00 00 00 00 00 00 00
00F0 F0 00 00 64 FD 00 42 00 00 70 CE 00 - F0 00 00 00 00 00 00 00 00 00 00 00
00F0 F1 00 00 64 FD 99 A3 07 22 00 00 00 - F1 00 00 00 00 00 00 00 00 00 00 00
0100 F2 00 00 64 FD CA EA C1 82 00 00 00 - F2 00 00 00 00 00 00 00 00 00 00 00
0110 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0120 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0130 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0140 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0150 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0160 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0170 82 00 58 02 00 7B 03 00 01 00 01 57 - 00 00 00 00 00 00 00 00 00 00 00 00
0180 02 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
0180 00 00 21 10 00 00 01 03 03 03 03 03 - 00 00 00 00 00 00 00 00 00 00 00 00
0190 03 03 03 00 00 00 00 00 00 00 00 01 - 00 00 00 00 00 00 00 00 00 00 00 00
01B0 00 00 35 CD 16 61 82 28 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01B0 00 00 01 00 AC 00 99 A3 07 22 C2 17 - 00 00 00 00 00 00 00 00 00 00 00 00
01C0 02 00 CA EA C1 82 34 19 03 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01D0 00 00 A3 CE 3F 1C 00 00 00 06 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01E0 00 00 F6 25 00 00 60 00 05 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01F0 00 3B 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00
01F0 00 00 00 00 00 95 - 00 00 00 00 00 60
ATA Dump
Smart Dump
Thank you for the tests. We'll fix that in the next AIDA64 beta update.
It should not require fixing
5. Missing disk, SMART and drive temperature information on Intel RST 11.5 drivers.
Description: Using Intel Rapid Storage Technology (RST) driver v11.5 or Enterprise RST driver will probably cause loss of disk information including SMART and temperature. This is a bug in the Intel RST driver v11.5 and Intel fixed this problem in version 11.5.0.1153 of the RST driver and Enterprise RST driver v3.2.
Workaround: Update the RST driver to v11.5.0.1153 (or eRST to v3.2) at least.
3.2 is not out just yet, but so far 11.5.0.1153beta tests have been positive
There was a slight issue in the SPTI temperature measurement part of AIDA64 that we've fixed. Of course installing the latest RST or RSTe driver is always recommended, since according to the information we've received from Intel, they are working very hard in the past few months to fix and improve their RST/RSTe drivers. Let's hope RST 11.6 WHQL and RSTe 3.2 WHQL will finally eliminate all revealed issues ;)
Ah, something that wouldn't cause a problem for everyone then?
you're on the ball this week Fiery, i've never had a faster response xD
i just hope intel have fixed their uninstall script, the previous version of 11.5 installed the iastorf (Filter) as a lowerfilter and failed to remove it on uninstall leading to fun times getting windows to work if you delete the file before removing the lowerfilter value
It's quite difficult to explain what was wrong, but hopefully the fixed beta will work properly with both RSTe v3.1 and RSTe v3.2
Thank you, we're pushing hard to fix the reported issues before the next AIDA64 stable release is out ;)
Hi Fiery
With the latest beta, I did not have any info on the temperature of the disk (even after reboot)
must, in the preferences/Stability, check the option "Smart Array Support" and it's good
Default check for future betas or clarify
And also, nothing important, there is no "ATA" before the names of the disks (see screen in the first post and that there)
it's better for me that there is not "ATA" :)
thank you Fiery
I'm sorry, I forgot to ask you to enable the options "RAID member enumeration" and "RAID SMART support" in the Preferences :) So that's how it's supposed to provide the best results on your configuration.
