Ranathum Posted December 18, 2021 Posted December 18, 2021 Hello I would like to know which are the best displays for computer hardware monitor, I want 5 inch to 10 inch with high resolution, what are the best manufacters and models? Quote
Fiery Posted December 19, 2021 Posted December 19, 2021 22 hours ago, Ranathum said: Hello I would like to know which are the best displays for computer hardware monitor, I want 5 inch to 10 inch with high resolution, what are the best manufacters and models? The options are quite limited in case you want an USB-connected display. In that case check out Matrix Orbital EVE3/EVE4 and BeadaPanel. In case HDMI-connected display is an option too, then the selection is unlimited since any monitor or TV can work too, using SensorPanel. Quote
Ranathum Posted December 20, 2021 Author Posted December 20, 2021 15 hours ago, Fiery said: The options are quite limited in case you want an USB-connected display. In that case check out Matrix Orbital EVE3/EVE4 and BeadaPanel. In case HDMI-connected display is an option too, then the selection is unlimited since any monitor or TV can work too, using SensorPanel. With BeadaPanel, I could connect it direct to a usb header on a pc motherboard? Quote
Fiery Posted December 20, 2021 Posted December 20, 2021 5 minutes ago, Ranathum said: With BeadaPanel, I could connect it direct to a usb header on a pc motherboard? Check if this page has the answer: https://elinux.org/BeadaPanel If not, try to ask @beada Quote
beada Posted December 21, 2021 Posted December 21, 2021 All BeadaPanel screens equipped with a Micro-USB port so one can use a convert cable to connect it to mother board 2.54 header. 1 Quote
