Soul--Reaver Posted November 4, 2012 Posted November 4, 2012 Hi I've got an Asus Sabertooth Z77 motherboard and to manage all of my fans i require AI Suite II to be installed. As i understood it, since Aida64 2.60 Aida64 uses a different method to retrieve sensor information when AI Suite is installed and when it is not installed. For various reasons i want to Aida64 to use the method for when Ai Suite II is not installed while AI Suite II is installed. How can i do this? I could not find anything in the stability tab about this so for now i'm still stuck on Aida64 2.50 Kind regards Swen Kruiper Quote
Squall Leonhart Posted November 4, 2012 Posted November 4, 2012 So you want to put your computer at a risk of instabilities, locking up the smbus, freezing the LPC bus, etc. Quote
Fiery Posted November 4, 2012 Posted November 4, 2012 It's absolutely not recommended to have the low-level register access when AI Suite is installed, since it would cause various issues, e.g. fan alerts (when they are spinning fine), system lockup, voltage delivery issues, etc. AIDA64 automatically detects AI Suite, and when it is installed, AIDA64 will use the AI Suite method based on ATKEX calls. Quote
Soul--Reaver Posted November 16, 2012 Author Posted November 16, 2012 Yeah well the problem is that AI Suite II has a serious issue with the Sabertooth Z77 where: - it would randomly crash the whole system and the only way to turn the system back on is to remove the 24 pins power cable or the power cable to the wall. (this would happen at a average of once a week) - Randomly control will be lost over Chassis fan 1 and 3 which would make them run at around 95% speed permanently until reboot. (this would happen at average of once every 2 days) As long as i don't run the Ai Suite II main program (normally started by the task manager which i have currently disabled) there is no problem. The windows services installed by AI Suite seem to not have any issues if they keep running though. Above problems, or at least the second issue with the fans, occurs both with Aida64 2.60 and 2.70 while the AI Suite II main program is not running (the services are running though). Most likely because your are using the services AI Suite normally uses. You might understand that i would be very glad if Aida64 would not use AI Suite services as it is really not good for my system and that i would be able to set it back to aida64 2.50 methods. I would uninstall AI Suite if i had the change but i'm afraid i can't because there is currently no program that can manage the 2 assistant fans properly I currently have a perfectly stable system running Aida64 2.50 and would like it to stay that way while i upgrade Aida64 to 2.70 Quote
Soul--Reaver Posted November 18, 2012 Author Posted November 18, 2012 Would it work the way i want to if i stopped the atkexComSvc.exe (Asus COM service)? Quote
Fiery Posted November 18, 2012 Posted November 18, 2012 Would it work the way i want to if i stopped the atkexComSvc.exe (Asus COM service)? I think it should work that way. Please give it a try, and let us know how it went. Quote
Soul--Reaver Posted November 20, 2012 Author Posted November 20, 2012 Needed to completely disable the Asus COM service as Aida64 tries to start it. After a reboot 2 other Asus services (among them the all important AsusFanControlService) would not run anymore so i had to enable the Asus COM service again and downgrade Aida64 back to 2.50 So the theory worked but it caused other issues. So i'm back to square one Personally i still feel that this is something that belongs in the stability tab of Aida64 but it seems that people here (at least the ones that posted in this topic) do not agree Fiery, we can discuss this as long as we want but i've made my case. If you have anymore ideas i'm ready to hear them and if not i would appreciate a straight answer whether or not above suggested addition will be considered or denied I appreciate the support 1 Quote
Fiery Posted November 21, 2012 Posted November 21, 2012 The "final" solution will definitely be the new option on the Stability page of the Preferences. We'll add that soon, and I'll post a message into this topic once a new beta of AIDA64 -- with the requested change implemented -- becomes available. Quote
Fiery Posted November 23, 2012 Posted November 23, 2012 We've implemented the requested new option on the Preferences / Stability page in the following new beta version of AIDA64 Extreme Edition: http://www.aida64.com/downloads/aida64extremebuild2222jv3z7yfrsbzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
Soul--Reaver Posted November 25, 2012 Author Posted November 25, 2012 I have to be honest. I expected this to be added in a future release, not in a new build as this was not really a bug (at least not one in Aida64). Not that i'm complaining, Aida64 just exceeded expectations. Which is a good thing Thanks I've updated Aida64 and disabled the atkex setting in the stability tab. If i have any issues i'll post them here Quote
StackOverflow13 Posted January 4, 2013 Posted January 4, 2013 I have to be honest. I expected this to be added in a future release, not in a new build as this was not really a bug (at least not one in Aida64). Not that i'm complaining, Aida64 just exceeded expectations. Which is a good thing Thanks I've updated Aida64 and disabled the atkex setting in the stability tab. If i have any issues i'll post them here I'm in the same situation as yourself. If I disable asus services then fan xpert 2 wont work & my chasis fans run at 100%. How did you get round this? how do you control your fans please? Quote
Soul--Reaver Posted April 6, 2014 Author Posted April 6, 2014 I haven't disabled any services. Only the AI Suite task in the task scheduler has been disabled Quote
