7 hours ago, Mach said:
Try putting the windows in sleep mode and wake it up, then Aida64 seems to read the temps correctly.
I can confirm that after waking from sleep temp reading works correctly.
Same here. Now also Armory Crate works. So we are stuck with Sleep mode until BIOS fix I guess...
10 hours ago, Martin Piotrowski said:
Can confirm this workaround leads to "unstuck" CPU temperature readings after manually putting PC in sleep mode then waking it up.
It did so for me and a couple of others.
On 10/25/2022 at 1:58 PM, Fiery said:
Thank you!  We're investigating the issue.  Do you guys have Ryzen Master installed?  We now suspect that it may be a collision between that and AIDA64.  BTW, the issue affects older motherboards (e.g. MSI X570) and other 3rd party monitoring software (e.g. HWiNFO64) too.
This may not be an Aida64 issue, the Asus x670e Hero Q-Code also is locked on the CPU temp. Putting Windows into sleep mode and wake up will unlock it, then Aida and Q-Code panel shows the right CPU temp.
So far our conclusion is also that the issue is rather rooted in the firmware (BIOS) handling the onboard sensor chip incorrectly than a bug in AIDA64.
Agreed!
Makes sense. I did try to have the led display the bios code instead of the temperature (you can do that in the bios) and that did not help. Only thing that helped so far is sleep. Although, why is Aida64 only showing the CPU temp taken by the MB and not the temps reported by the CPU itself (like HWinfo does)?
Good question!
We will add CPU diode temperature measurement for Raphael CPUs in the next AIDA64 beta update.
Another thing I noticed and to add to this CPU temp freezing is that when Windows is boot up without having Aida64 to load with Windows, the temp works. Once I manually launched Aida64 then the temp freezes again.
You can actually start up Aida and use a lot of its features without locking the temp, you just can't activate the sensors, either via the regular UI or by starting up a Sensorpanel.  If you have Sensorpanel enabled in Aida, disable it and reboot.  Then you can at least use Aida to view regular system info, run benchmarks, etc.
Aida64 SensorPanel is vital for my daily use, one of the reason I get Aida64 in the first place. I even have a 7" LCD display to show the SensorPanel at all time.
I also realized under AIda64 Preferences/Stability that "Low-Level sensor operations" causes the BIOS to stop reporting/freeze the CPU temp. Of course this sensor option is needed for my SensorPanel modules that I have in it.
This has been tested on Asus ROG x670e Hero 0805 beta and full release, the problem still persist.
For the record and to save folks time, the new beta release does not stop the CPU package temp lock, at least not on a x670e Crossfire Extreme running bios 0705.  I haven't updated to 0805 because it apparently doesn't fix the issue either.
Fiery, has there been any communication from Aida to Asus on the nature of the problem so they're aware they need to resolve it?  If so, did they acknowledge the problem is theirs?
  • Like 2
Thank you Fiery, currently on the beta v6217, the CPU Diode temp works but as Qwinn motioned, I can also confirm that on ASUS ROG x670e Hero, the CPU temp and CPU package temp gets locked with the Aida64 Low-Level sensor operation enabled.
Thank you for your feedback!
Fiery, would it be possible to add Chipset and VRM temp monitoring on the next beta of Aida64 for the x670x series motherboard, specially Asus?
Thanks again.
Very much the same issue here, ROG X670 Hero (BIOS version 0805), AMD 7950X,  running Sensorpanel on a dedicated small screen.
AIDA 64 Low-Level sensor operation got the whole MB temp reading locked,  causing fan speed locked.
I have a 7900X on an Asus X670E-E and had almost no sensors available. The beta software has now unlocked the majority of items thanks!
