Mach Posted December 5, 2022 Posted December 5, 2022 On 12/5/2022 at 12:21 PM, plzt said: I have a 7900X on an Asus X670E-E and had almost no sensors available. The beta software has now unlocked the majority of items thanks! Is your CPU temp gets locked if you use AIDA64 Low-Level sensor on that board? Quote
hosty Posted December 8, 2022 Posted December 8, 2022 +1 - 7900X cpu on Asus TUF x670e-plus wifi motherboard, Armoury Crate is installed. Bios version is 0821. - The cpu temperature only gets locked once aida64 sensor panel is started. - sleeping and waking the computer is working as a temporary workaround. 1 Quote
odt_jarvis Posted December 9, 2022 Posted December 9, 2022 +1 Same like @hosty but other mainboard - 7900X cpu on Asus ROG Strix B650E-F Gaming WiFi motherboard, Armoury Crate is installed. Bios version is 0821. - The cpu and mainboard temperatures only get locked once aida64 sensor panel is started. - sleeping and waking the computer is working as a temporary workaround. - HWInfo works fine Quote
Mach Posted December 9, 2022 Posted December 9, 2022 New 6226 beta of Aida64 released but doesn't fix the CPU temp lock on Asus AMD 670x MB. Quote
Sayoung Posted December 14, 2022 Posted December 14, 2022 Update on this one, new stable version 6.85.6300 still not fixing CPU temp sensor readings lock issue, currently the only work around is sleep (S3) and wake up right after start AIDA64. Quote
JarleH Posted December 15, 2022 Posted December 15, 2022 Are there really no temp sensors pr core in the AMD 7700X? I only find CPU and package temps, no individual temps at all in AIDA64 Extreme.... Quote
Tomas914 Posted December 15, 2022 Posted December 15, 2022 Can confirm on version 6.85.6300 ASUS TUF x670 WIFI (latest bios 0821) + Ryzen 7950x CPU temp still locks after running AIDA. HWInfo doesn't have this issue, maybe some workaround could be done? Quote
A Blade Of Grass Posted December 19, 2022 Posted December 19, 2022 My main issue is CPU and CPU Package Temp doesn't show up as an option in the Temperatures menu. I feel like my issue is AIDA64 isn't pointing to my CPU Temp or CPU Package Temp Sensor to pull those readings. Same issue as everyone else described, except my CPU Temp DOESN'T lock up when I open AIDA64 Extreme. I have a prebuilt sensor panel from Amazon that reads the CPU Temp just fine (but wanted to upgrade to AIDA64 Sensor Panel for more info to monitor). I have an Asus MB with Armoury Crate which displays the CPU Temp correctly and I can adjust the fan speeds there, as well as HWiNFO which also displays the temps correctly. I recently tried updating to the latest BIOS and most recent stable AIDA64 version with no change. I downloaded an awesome Sensor Panel and tweaked some info and changed the aspect ratio to 800x480 to fit on my 7" screen I ordered (lots of work to resize all the .png files). That's why there's a big N/A for the CPU Temp in the attached image. I tried the Sleep option, but no change happened. I'm also running Windows 10 Home. I'm not sure that has anything to do with this or not. AIDA64 Extreme (Version 6.85.6300) Asus ROG Strix Z590-A Gaming WiFi II (BIOS 1601) Intel Core i7-11700K 11th Gen Quote
Amit Paz Posted December 22, 2022 Posted December 22, 2022 This is not really related to this thread. Please open a new one for your problem. Quote
Amit Paz Posted December 22, 2022 Posted December 22, 2022 Can confirm that new version does not solve the problem of CPU temps readout locking up. Quote
JarleH Posted January 5, 2023 Posted January 5, 2023 Also just a related friendly reminder; as pointed out before, Aida64 also cannot read any single coretemp from the 7700X CPU. Just CPU, CPU diode and CPU package. 1 Quote
Mach Posted January 6, 2023 Posted January 6, 2023 New Aida64 v6315 is out, but nothing yet on CPU temp lock on Asus x670e motherboard. Quote
ozkr_tech Posted January 10, 2023 Posted January 10, 2023 New Aida64 v6317 is out, but nothing yet on CPU temp lock on Asus Prime x670-P motherboard. Quote
Fiery Posted January 10, 2023 Posted January 10, 2023 On 10/18/2022 at 11:03 AM, Lahabria said: Good morning, Having a strange issue with AIDA64 Engineer. Everything seems to be working except CPU and CPU Package temperatures. After startup it seems to read the sensor then freezes, it doesn't update. GPU and other temperatures seems to work. I tried uninstalling and reinstalling, running the stable version and the beta version and same results. I can see the temperatures working fine using ICue / HWInfo. I also tried AIDA64 Extreme and same results. ROG Strix X670E-A Ryzen 9 7950x RTX 3090 Have Icue and Steelseries GG running @Qwinn @nin6996 @DBentt @Amit Paz @Martin Piotrowski @JarleH @Mach @Sayoung @plzt @hosty @odt_jarvis @Tomas914 @A Blade Of Grass @ozkr_tech We've fixed the suck CPU temperature issue about Asus X670 motherboards in the latest AIDA64 beta build available at: https://www.aida64.com/downloads/latesta64xebeta Quote
ozkr_tech Posted January 11, 2023 Posted January 11, 2023 New Aida64 v6318 is out, but still some issues on CPU temp lock on Asus Prime x670-P motherboard. Got 3 sensor options: CPU, CPU Package and CPU Diode. Only CPU Diode is working. The other 2 sensors are stuck. Quote
Mach Posted January 11, 2023 Posted January 11, 2023 Aida64 v6318 beta still have the CPU temp and package lock on boot on Asus x670E Hero. Only CPU diode works. Quote
JarleH Posted January 11, 2023 Posted January 11, 2023 20 hours ago, Fiery said: @Qwinn @nin6996 @DBentt @Amit Paz @Martin Piotrowski @JarleH @Mach @Sayoung @plzt @hosty @odt_jarvis @Tomas914 @A Blade Of Grass @ozkr_tech We've fixed the suck CPU temperature issue about Asus X670 motherboards in the latest AIDA64 beta build available at: https://www.aida64.com/downloads/latesta64xebeta Ok, we are getting there. BUT isnt it even possible to read the temps on each core for the AMD Ryzen 7000 series?! Quote
Qwinn Posted January 14, 2023 Posted January 14, 2023 On 1/10/2023 at 5:37 PM, Fiery said: @Qwinn @nin6996 @DBentt @Amit Paz @Martin Piotrowski @JarleH @Mach @Sayoung @plzt @hosty @odt_jarvis @Tomas914 @A Blade Of Grass @ozkr_tech We've fixed the suck CPU temperature issue about Asus X670 motherboards in the latest AIDA64 beta build available at: https://www.aida64.com/downloads/latesta64xebeta Hi Fiery. Appreciate the attention to the problem, but still getting stuck CPU Package temp when starting sensorpanel on Aida64 beta 6.85.6318 on X670E Crosshair Extreme as well. Quote
Fiery Posted January 16, 2023 Posted January 16, 2023 On 1/14/2023 at 10:17 PM, Qwinn said: Hi Fiery. Appreciate the attention to the problem, but still getting stuck CPU Package temp when starting sensorpanel on Aida64 beta 6.85.6318 on X670E Crosshair Extreme as well. @ozkr_tech @Mach @JarleH Thank you for the feedback. Please check the following new beta build too: https://www.aida64.com/downloads/latesta64xebeta Quote
Qwinn Posted January 16, 2023 Posted January 16, 2023 2 hours ago, Fiery said: @ozkr_tech @Mach @JarleH Thank you for the feedback. Please check the following new beta build too: https://www.aida64.com/downloads/latesta64xebeta Hi Fiery. Great news! Far as I can tell, 6.85.6318 6.85.6323 does fix the problem. I can run sensorpanel now without locking CPU Package temp. I did not check the other temps others have remarked on, but the most important temp that controls the fans seems to be okay now. (Edited to correct version number that fixes the issue) Quote
JarleH Posted January 16, 2023 Posted January 16, 2023 2 hours ago, Qwinn said: Hi Fiery. Great news! Far as I can tell, 6.85.6318 6.85.6323 does fix the problem. I can run sensorpanel now without locking CPU Package temp. I did not check the other temps others have remarked on, but the most important temp that controls the fans seems to be okay now. (Edited to correct version number that fixes the issue) Good! Now I just wonder if its possible to also see temps of the individual cores : Quote
ozkr_tech Posted January 17, 2023 Posted January 17, 2023 New Aida64 v6323 is out, now i can confirm all the issues with the CPU temp lock on Asus Prime x670-P motherboard has been completely fixed. All 3 sensor options work as expected: CPU, CPU Package and CPU Diode. Remember to restart the computer after upgrading to the new beta version before the changes actually takes effect. (it might give false positive of not working if the computer is not restarted after the aida64 upgrade) Thanks @Fiery and the Aida64 team for great effort! Cheers! Quote
Mach Posted January 17, 2023 Posted January 17, 2023 I can also confirm the CPU temp lock has been fixed on Asus x670E Hero. Thank you very much @Fiery Quote
JarleH Posted January 25, 2023 Posted January 25, 2023 But to everyone here; the Aida64 wrong reading is not just a Aida64 problem, it effects whole machine. If you set your fans to speed of the CPU temp, they also will spin up due to the 'false' reading of the CPU temp. I am pretty sure Asus needs to fix this with a BIOS update. Quote
