Loyd Posted March 12 Share Posted March 12 With the update I no longer have chassis 1 fan, just CPU, CPU OPT and GPU ( only one of the 2). I have rebooted no change. as 64 only reports 3 out of my 10 fans, the others go thru a razer controller, That is a quarter of the reportable fans. Like to have them back,,,Gigabyte B760i ddr4 mini-ITX system board with an i5-12600KF CPU, ASUS RX 5700 XT GPU Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 12 Share Posted March 12 46 minutes ago, Loyd said: With the update I no longer have chassis 1 fan, just CPU, CPU OPT and GPU ( only one of the 2). I have rebooted no change. as 64 only reports 3 out of my 10 fans, the others go thru a razer controller, That is a quarter of the reportable fans. Like to have them back,,,Gigabyte B760i ddr4 mini-ITX system board with an i5-12600KF CPU, ASUS RX 5700 XT GPU In AIDA64 please press Ctrl+Alt+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
Loyd Posted March 12 Author Share Posted March 12 here is the requested fil isasensordump.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 13 Share Posted March 13 17 hours ago, Loyd said: here is the requested fil Thank you. We've checked the sensor chip registers, but we can only find 2 fans spinning there. Are you sure your motherboard can monitor the 3rd fan properly? Can you see it having a meaningful RPM value reported in the BIOS Setup (UEFI Setup) ? Quote Link to comment Share on other sites More sharing options...
Loyd Posted March 13 Author Share Posted March 13 I found the problem. I had put in a splitter on that fan and the splitter did not have the proper wiring once removed speed reporting was back. I did look in the bios and sys_fan1 was not reporting but i could see it was working and I could change the speed, then I remembered the splitter. On an another note how can i get input from a program called Fan control. would be nice to be able to use that to display the fans' speed. thanks for all the trouble great program Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 13 Share Posted March 13 34 minutes ago, Loyd said: I found the problem. I had put in a splitter on that fan and the splitter did not have the proper wiring once removed speed reporting was back. I did look in the bios and sys_fan1 was not reporting but i could see it was working and I could change the speed, then I remembered the splitter. On an another note how can i get input from a program called Fan control. would be nice to be able to use that to display the fans' speed. thanks for all the trouble great program Do you mean this software? https://getfancontrol.com/ And if so, how come it can monitor more fans than AIDA64? What are those fans connected to? Quote Link to comment Share on other sites More sharing options...
Loyd Posted March 14 Author Share Posted March 14 Yes, fan control not only monitors it controls them by curves you set up. these fans in my case are directly connected to the mobo, to a razer 8 port hub, and a asus 5700 xt GPU. it works all 12 fans and it seems to use very little resources. Aida64 only monitors mobo connected fans try it Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 14 Share Posted March 14 1 minute ago, Loyd said: Yes, fan control not only monitors it controls them by curves you set up. these fans in my case are directly connected to the mobo, to a razer 8 port hub, and a asus 5700 xt GPU. it works all 12 fans and it seems to use very little resources. Aida64 only monitors mobo connected fans try it I suppose in your case we'd need to focus on the Razer 8-port hub you've mentioned. That's the device that we need to natively support in AIDA64. Please let us know what's the model name or part number of that Razer device. I assume it is connected via USB to your motherboard, is it the case? Quote Link to comment Share on other sites More sharing options...
Loyd Posted March 14 Author Share Posted March 14 It is called Razer PWM fan controller, (Amazon) from the comments razer support doesn't support it very well. It plugs into a MOBO usb port and a sata port for power then runs it own software to control fans. when running "fan control" I set all other fan controls to 50% then "fan control" can run them to 0 up to 100 works great. If you can get this to inface with 64 it would be great Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 14 Share Posted March 14 2 hours ago, Loyd said: It is called Razer PWM fan controller, (Amazon) from the comments razer support doesn't support it very well. It plugs into a MOBO usb port and a sata port for power then runs it own software to control fans. when running "fan control" I set all other fan controls to 50% then "fan control" can run them to 0 up to 100 works great. If you can get this to inface with 64 it would be great Thank you, we'll order a unit and check it out. Quote Link to comment Share on other sites More sharing options...
Loyd Posted March 14 Author Share Posted March 14 the fan control program uses a plugin to interface the razer with FC. The razer does not commutate naturally with FC, It needs this plug in. there are a lot of plug ins available for all sorts of items on the FC github site. have fun. Quote Link to comment Share on other sites More sharing options...
Fiery Posted April 9 Share Posted April 9 On 3/14/2024 at 7:41 PM, Loyd said: the fan control program uses a plugin to interface the razer with FC. The razer does not commutate naturally with FC, It needs this plug in. there are a lot of plug ins available for all sorts of items on the FC github site. have fun. We've implemented support for Razer PWM PC Fan Controller in the latest AIDA64 beta version available at: https://www.aida64.com/downloads/latesta64xebeta Let us know how it works. Quote Link to comment Share on other sites More sharing options...
Loyd Posted April 10 Author Share Posted April 10 It works all 9 fans are reporting, good job. I am assuming the razer has to be running etc, only make sense could not report other wise, DUH Quote Link to comment Share on other sites More sharing options...
rinaldop Posted April 10 Share Posted April 10 On 4/9/2024 at 7:38 AM, Fiery said: We've implemented support for Razer PWM PC Fan Controller in the latest AIDA64 beta version available at: https://www.aida64.com/downloads/latesta64xebeta Let us know how it works. Great news! Any chance for Corsair fan controllers to be added? Quote Link to comment Share on other sites More sharing options...
