tistou77 Posted October 9, 2014 Share Posted October 9, 2014 Hello With the latest version, the temperature 2 and 3 are not shown in the monitoring (temperature only 1)And I do not have either CHAN_FAN1 And there is a misreading for Vcore to "load"?AIDA64 shows 1.264v while CPU-Z and HW Info indicate 1.249v Thanks Quote Link to comment Share on other sites More sharing options...
tistou77 Posted October 9, 2014 Author Share Posted October 9, 2014 With the last beta OK for CHA_FAN 1A but on CHA_FAN 1B, it does not work And not OK for temperature 2 et 3 (OK in the bios) Quote Link to comment Share on other sites More sharing options...
tistou77 Posted October 10, 2014 Author Share Posted October 10, 2014 It's ok with the last beta Thanks so much for your great work Quote Link to comment Share on other sites More sharing options...
Fiery Posted October 10, 2014 Share Posted October 10, 2014 Thank you for the feedback Quote Link to comment Share on other sites More sharing options...
Grestorn Posted October 31, 2014 Share Posted October 31, 2014 The value for the case fans can become erratic when the system is under heavy load. Maybe that's related to how the value is calculated. Is there something that can be done about it? Right now this makes the value quite useless, since I usually need to see it under heavy load. Quote Link to comment Share on other sites More sharing options...
Fiery Posted October 31, 2014 Share Posted October 31, 2014 Chassis fans on Rampage V Extreme are not calculated or adjusted. They are directly interpreted from the fan registers. Do you have Asus AI Suite installed? If yes, then the issue may be because that software collides with AIDA64 sensor module. Quote Link to comment Share on other sites More sharing options...
