tistou77 Posted June 13, 2017 Posted June 13, 2017 Hello When I check the box "Stress GPU (s), I have this popup (see screen)what is it exactly ? Thanks Quote
Fiery Posted June 13, 2017 Posted June 13, 2017 It's quite self-explanatory I believe There's a Windows video driver setting used for video driver recovery purposes. If it's set too low, the OpenCL kernel that AIDA64 uses for GPU stressing may cause Windows to think the video driver has stopped responding. In which case Windows would restart the video driver, which would then break the AIDA64 GPU stress testing cycle. So it's best to have the TdrDelay value configured at a high level. AIDA64 will check the TdrDelay value, and if it's lower than 8 seconds, it will show you that popup warning message. If you let it fix the issue for you, it will increase the TdrDelay value to 8 seconds. Quote
tistou77 Posted June 13, 2017 Author Posted June 13, 2017 Thanks for the explanationI do not know the values, hence my question This value is changed all the time, or until the next reboot ? Thanks Quote
Fiery Posted June 15, 2017 Posted June 15, 2017 On 2017. 06. 13. at 2:53 PM, tistou77 said: Thanks for the explanationI do not know the values, hence my question This value is changed all the time, or until the next reboot ? Thanks It's changed permanently, but the change is only applied after the first Windows restart after altering the Registry TdrDelay value. Quote
xixou Posted July 22, 2017 Posted July 22, 2017 Interesting. Where is the 8 sec delay located in the registry? Quote
Fiery Posted July 24, 2017 Posted July 24, 2017 On 2017. 07. 23. at 0:36 AM, xixou said: Interesting. Where is the 8 sec delay located in the registry? Please check the following forum topic: Quote
Mastah Posted February 3, 2018 Posted February 3, 2018 I receive the same message and click "No". And now gpu stability test doesn't work even if i change the TdrDelay value in regedit. Can you help me in this question? My config notebook asus x201e (celeron 847, HD Graphics 2000), the latest drivers are installed. Quote
Fiery Posted February 5, 2018 Posted February 5, 2018 On 2018. 02. 03. at 6:25 PM, Mastah said: I receive the same message and click "No". And now gpu stability test doesn't work even if i change the TdrDelay value in regedit. Can you help me in this question? My config notebook asus x201e (celeron 847, HD Graphics 2000), the latest drivers are installed. Your notebook features an Intel Sandy Bridge class iGPU that doesn't support OpenCL. AIDA64 GPU stress test and GPGPU benchmarks require a GPU that supports OpenCL. 1 Quote
GreenImp Posted January 18, 2024 Posted January 18, 2024 Howdy. This fixed my issue on my (ASRock RX 7800 XT Challenger) GPU with the Preview Drivers that enabled AFMF. Any game I used FSR or AFMF enabled would crash eventually & this solved my problem. Thanks AIDA64! Quote
houmous Posted December 3, 2025 Posted December 3, 2025 Hi I got the above message about tdrdelay when I first selected GPU for stress testing. I clicked no and cancelled the test while I researched it. I now want to make the change but I no longer get the message when I click GPU. How can I retrive the message and carry out the registry amendment? Thanks! Quote
