Hello
I have a problem with rams, they are indicated as on the screen in Aida64, while it will have to be A1, B1, C1, D1
and I have the temperature of the water plugged into the "Water In" port on the motherboard, but it indicates Temperature N°1 in Aida64
It is possible to rename in "Water" (the "In" and "Out" to put in Extended Labels) and it's "duplicate" with T-Sensor 1
Asus having made the effort to add these ports, as long as they are named correctly in Aida64 :D
And for Water Flow, in bios it is indicated in l/m, in Aida64 it is indicated in RPM
Possible to have in l/m (see in l/h) in Aida64
Thanks
And merry christmas ;)
DIMM slot numbering is quite tricky with Skylake-X processors, and we haven't yet found a way to properly reorganize the DIMM slots to suit all motherboard layouts.
Water In and Water Out temperatures do not have a dedicated temperature slot in the hardware monitoring module of AIDA64.  That's why they use a generic temperature label.  Asus uses a lot of different sensor labels on its ROG products.  And that single motherboard vendor alone bloats up our list of dedicated sensor slots quite a lot :(  BTW, when you have both T Sensor 1 and Water In thermal readings available, the first one would appear as Temperature #1, and the second one would appear as Temperature #2.  They wouldn't use the same generic temperature slot, so it wouldn't overwrite each other at all.
When a water flow reading is available through a fan slot, RPM is the measurement unit that AIDA64 would use.  You can use the Correction facility (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction) to convert the readings to a different format, but that wouldn't change the displayed measurement unit at all.
Happy New Year! ;)
Too bad, for once Asus put "probes" for Watercooling :(
Too complicated to rename this probe in Water ?
Read the information from the bios (indicated correctly in the bios) is not good ?
Because Temperature N°1, it can be anything and everything
And also, if it is possible to add a section "Watercooling" (not translated into French) in Sensor
Currently, water pump, water flow are in Fans, not really the right place
Thanks and happy new year too
Expand
It's not that difficult to rename any of the readings, but it involves allocating newer and newer sensor slots.  New sensor slots mean the whole monitoring module gets bigger and slower (by a tiny bit) everytime we add more, so we gotta be careful not to carelessly add everything that Asus comes up with :)
Watercooling section doesn't make much sense, since that's not how the sensor readings are grouped on the Sensor page anyway.  When you have a dedicated liquid flow meter (Aquaero, T-Balancer, etc), it will be slotted into the Flow Sensors group though.
Expand
If it's not complicated, it may be better then
Currently reading Water indicates Temperature N°1 (why not just Temperature, if not other temperature probes ?)
T_Sensor 1, indicates Temperature N°2 (nothing consistent)
I found it good, a section Watercooling, more serious, and defined each section
If it's a little longer, even 1 second, nothing dramatic
Or the best and simplest for everyone, be able to rename probes and sections, and very easy to integrate
Thanks
Thanks
Expand
You can already do that if you use any of the OSD Panel, Desktop Gadget, SensorPanel, or External LCD modules ;)
  On 1/3/2018 at 12:04 PM, tistou77 said:
Yes, but I was talking in the Sensor window,  of course ;)
Expand
I know. But the Sensor page was not designed to be customizable. If you need to customize the readings, you can do that via multiple other methods ;)  So there's a solution for everyone.
Expand
But you planned to "customize" it, if I remember correctly ?
  On 1/3/2018 at 12:27 PM, Fiery said:
Only the labels, but not the grouping logic ;)
Expand
It will be good already ;)
an idea of when it will be done ?
Although it's weird to have water pumps, etc ... in the fans
EDIT: I had thought for the Watercooling section, so as not to overload the scan of the Sensor window, maybe add the option in the "Preferences"
Those who do not have Watercooling probes, do not activate this option and the scan is not slowed down :D
Expand
As I've explained above, the Sensor page is not meant to be customized.  Use one of the listed features if you need to have the layout customized.
Expand
Okay, and an idea of when the probes (labels) can be "customize" ?
And for DIMMs, no solution then ?
Expand
1) I'm not sure, since it's not a quick project
2) Already replied above ;)
Expand
But for this motherboard, it's only Skylake-X, there is still a problem ?
it will have to be like any
Rampage Extreme , right ?
Expand
We're not quite sure why the DIMM numbering is illogical.
  • 3 weeks later...
  On 1/25/2018 at 2:09 PM, tistou77 said:
Not good :(
Thanks
Expand
Are you sure your DIMM slots are properly populated in order to have all 4 memory channels enabled?  If yes, then it means LGA2066 motherboards do not use a single layout for DIMM slots assignment -- in which case we need to implement motherboard specific DIMM slot numbering logic :(
Expand
Yes, I think
Asrock Configurator
correctly recognizes DIMMs
  On 1/25/2018 at 2:22 PM, tistou77 said:
Yes, I think
Asrock Configurator
Expand
Does AIDA64 report Quad Channel DDR4 on the AIDA64 CPUID Panel?  If yes, then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
