tistou77 Posted January 25, 2018 Author Posted January 25, 2018 9 minutes ago, Fiery said: Does AIDA64 report Quad Channel DDR4 on the AIDA64 CPUID Panel? If yes, then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Yes, it's good Thanks smbusdump_full.txt Quote
Fiery Posted January 25, 2018 Posted January 25, 2018 Thank you. Please check if the DIMM slots numbering is correct on the Motherboard / SPD page. Maybe it's correct there, and is only wrong on the Computer / Sensor page? Quote
tistou77 Posted January 25, 2018 Author Posted January 25, 2018 4 hours ago, Fiery said: Thank you. Please check if the DIMM slots numbering is correct on the Motherboard / SPD page. Maybe it's correct there, and is only wrong on the Computer / Sensor page? Indeed, it's good in Motherboard / SPD Computer / Sensor Motherboard / SPD Just updated Computer / Sensor Quote
tistou77 Posted January 27, 2018 Author Posted January 27, 2018 Will it be corrected in the next beta ? Thanks Quote
Fiery Posted January 28, 2018 Posted January 28, 2018 On 2018. 01. 27. at 10:46 AM, tistou77 said: Will it be corrected in the next beta ? Thanks Thank you for checking it out thoroughly. It will be fixed in the next AIDA64 beta update. Quote
tistou77 Posted January 28, 2018 Author Posted January 28, 2018 50 minutes ago, Fiery said: Thank you for checking it out thoroughly. It will be fixed in the next AIDA64 beta update. Ok thanks Quote
Fiery Posted February 1, 2018 Posted February 1, 2018 Please check the latest AIDA64 beta build: https://www.aida64.com/downloads/latesta64xebeta Quote
tistou77 Posted February 1, 2018 Author Posted February 1, 2018 Tested and there are DIMMs that do not exist (DIMM A3, DIMM C3) Still ok in Motherboard / SPD and Computer / Overclocking Quote
tistou77 Posted February 3, 2018 Author Posted February 3, 2018 Will it be corrected in the next beta ? Thanks Quote
Fiery Posted February 5, 2018 Posted February 5, 2018 On 2018. 02. 03. at 4:15 PM, tistou77 said: Will it be corrected in the next beta ? Thanks We'll do our best This is a really new and strange issue to us. We basically needed to come up with a virtual SMBus layout to emulate the 4 memory channels that your motherboard offers. That's because the Skylake-X memory controller manages the SPD channels as if the CPU had only 2 memory controllers. Very odd... Quote
tistou77 Posted February 5, 2018 Author Posted February 5, 2018 6 hours ago, Fiery said: We'll do our best This is a really new and strange issue to us. We basically needed to come up with a virtual SMBus layout to emulate the 4 memory channels that your motherboard offers. That's because the Skylake-X memory controller manages the SPD channels as if the CPU had only 2 memory controllers. Very odd... Ok indeed it's odd that in the other sections of Aida64, the DIMMs are correctly recognized Quote
Fiery Posted February 20, 2018 Posted February 20, 2018 On 2018. 02. 05. at 2:21 PM, tistou77 said: Ok indeed it's odd that in the other sections of Aida64, the DIMMs are correctly recognized Here's the above mentioned new AIDA64 beta build. Hopefully it will now work perfectly on all pages https://www.aida64.com/downloads/latesta64xebeta Quote
tistou77 Posted February 20, 2018 Author Posted February 20, 2018 1 hour ago, Fiery said: Here's the above mentioned new AIDA64 beta build. Hopefully it will now work perfectly on all pages https://www.aida64.com/downloads/latesta64xebeta It's good, thanks Quote
Fiery Posted February 20, 2018 Posted February 20, 2018 2 hours ago, tistou77 said: It's good, thanks Thank you for the feedback Quote
tistou77 Posted February 20, 2018 Author Posted February 20, 2018 2 hours ago, Fiery said: Thank you for the feedback You're welcome Quote
tistou77 Posted July 1, 2020 Author Posted July 1, 2020 Hello Exactly the same problem (1st post) for DIMMs and Rampage VI Extreme Encore Thanks smbusdump_full.txt Quote
Fiery Posted July 9, 2020 Posted July 9, 2020 On 7/3/2020 at 12:33 PM, tistou77 said: Hi Possible to correct this ? Thanks We'll fix it in the next AIDA64 beta update. Quote
tistou77 Posted July 9, 2020 Author Posted July 9, 2020 Just now, Fiery said: We'll fix it in the next AIDA64 beta update. Thanks Quote
Fiery Posted July 15, 2020 Posted July 15, 2020 On 7/10/2020 at 5:29 PM, tistou77 said: It's good Thanks Thank you! Quote
