zwillhill Posted May 4, 2018 Posted May 4, 2018 Hi, the Dell optiplex 7020 desktop doesn't show fan info, no idea if Aida64 can support this in the future so I thought I would add the sensor logs to see if that would help There is one cpu fan and chassis fan,in the log below there are two fan rpm value likes they are the real rpm but not show in aida64. ------[ Dell SMI Command 02A3 / Data 0000 (Fan RPM) took 0 msec ]------ Cmd 000002A3 --> 00000479 1145rpm Data 00000000 --> 00000000 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 02A3 / Data 0001 (Fan RPM) took 0 msec ]------ Cmd 000002A3 --> 00000577 1399rpm Data 00000001 --> 00000001 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 the 1145rpm fan is a cpu fan, top rpm is 4163, and the 1399rpm fan is a chassis fan, top rpm is 2076. ------[ Versions ]------ Program Version : AIDA64 Extreme v5.97.4618 Beta BenchDLL Version: 4.3.783-x64 Windows Version : Microsoft Windows 10 Pro 10.0.17655.1000 (64-bit) ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-041312-Chipset$1AQQW014_BIOS DATE: 02/02/18 02:02:46 VER: A15.00 Motherboard Model : Dell OptiPlex 7020 Motherboard Chipset : Intel Lynx Point Q87, Intel Haswell DMI MB Manufacturer : Dell Inc. DMI MB Product : XXXXX DMI MB Version : A00 DMI MB Serial : /XXXX/XXXX/ DMI SYS Manufacturer: Dell Inc. DMI SYS Product : OptiPlex 7020 DMI SYS Version : 00 DMI SYS Serial : XXXXXX DMI BIOS Version : A15 ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = 0000h (0000h / 0000h) Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = C9A1h (C9A1h / 0000h) ASpeed SuperIO Port = 00h ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA> _TZ_.TZ01._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3030</DATA> _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : ------[ Dell SMI Command FEA3 (SMBIOS Version) took 0 msec ]------ Cmd 0000FEA3 --> 44494147 Data 00000000 --> 00000000 Stat1 00000000 --> 00000000 Stat2 00000000 --> 44454C4C ------[ Dell SMI Command FFA3 (SMBIOS Interface) took 0 msec ]------ <FAILED> ------[ Dell SMI Command 00A3 / Data 0000 (Fan Speed) took 0 msec ]------ Cmd 000000A3 --> 00000003 Data 00000000 --> 00000000 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 00A3 / Data 0001 (Fan Speed) took 0 msec ]------ Cmd 000000A3 --> 00000003 Data 00000001 --> 00000001 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 00A3 / Data 0002 (Fan Speed) took 0 msec ]------ <FAILED> ------[ Dell SMI Command 00A3 / Data 0003 (Fan Speed) took 0 msec ]------ <FAILED> ------[ Dell SMI Command 02A3 / Data 0000 (Fan RPM) took 0 msec ]------ Cmd 000002A3 --> 00000479 Data 00000000 --> 00000000 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 02A3 / Data 0001 (Fan RPM) took 0 msec ]------ Cmd 000002A3 --> 00000577 Data 00000001 --> 00000001 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 02A3 / Data 0002 (Fan RPM) took 0 msec ]------ <FAILED> ------[ Dell SMI Command 02A3 / Data 0003 (Fan RPM) took 0 msec ]------ <FAILED> ------[ Dell SMI Command 10A3 / Data 0000 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 0000001A Data 00000000 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0001 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000001 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0002 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000002 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0003 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000003 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0004 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000004 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0005 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000005 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0006 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000006 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 10A3 / Data 0007 (Temperature) took 0 msec ]------ Cmd 000010A3 --> 00000022 Data 00000007 --> 0000640A Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 Total time = 0 msec Quote
Fiery Posted May 6, 2018 Posted May 6, 2018 On 2018. 05. 04. at 5:51 PM, zwillhill said: Hi, the Dell optiplex 7020 desktop doesn't show fan info, no idea if Aida64 can support this in the future so I thought I would add the sensor logs to see if that would help There is one cpu fan and chassis fan,in the log below there are two fan rpm value likes they are the real rpm but not show in aida64. ------[ Dell SMI Command 02A3 / Data 0000 (Fan RPM) took 0 msec ]------ Cmd 000002A3 --> 00000479 1145rpm Data 00000000 --> 00000000 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 ------[ Dell SMI Command 02A3 / Data 0001 (Fan RPM) took 0 msec ]------ Cmd 000002A3 --> 00000577 1399rpm Data 00000001 --> 00000001 Stat1 00000000 --> 00000000 Stat2 00000000 --> 00000000 the 1145rpm fan is a cpu fan, top rpm is 4163, and the 1399rpm fan is a chassis fan, top rpm is 2076. We'll fix the issue in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta build is available for download. Quote
Fiery Posted May 7, 2018 Posted May 7, 2018 18 hours ago, Fiery said: We'll fix the issue in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta build is available for download. The mentioned new AIDA64 beta build is now available for download at: https://www.aida64.com/downloads/latesta64xebeta Quote
zwillhill Posted May 7, 2018 Author Posted May 7, 2018 23 minutes ago, Fiery said: The mentioned new AIDA64 beta build is now available for download at: https://www.aida64.com/downloads/latesta64xebeta It's working fine!!! thx a lot! Quote
Fiery Posted May 7, 2018 Posted May 7, 2018 27 minutes ago, zwillhill said: It's working fine!!! thx a lot! Thank you for your feedback! Quote
