Pak1979 Posted September 28, 2019 Posted September 28, 2019 Is it possible to make the virtual flow sensor for the AquaComputer D5 Next readable with Aida64? All other sensors of the D5 Next are already readable. Only the Flow is not aviable. Quote
Fiery Posted September 28, 2019 Posted September 28, 2019 1 hour ago, Pak1979 said: Is it possible to make the virtual flow sensor for the AquaComputer D5 Next readable with Aida64? All other sensors of the D5 Next are already readable. Only the Flow is not aviable. I'm afraid we have no information on the register index of the flow rate reading on D5 Next. In other words, we don't know how to measure that value right now. If you can help us a bit about that, we _may_ be able to figure it out though, so it's not a lost cause Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also, check what Aquasuite reports as flow rate for your D5 Next device. The value should fluctuate a bit, in which case please let us know a few examples of readings. We'll do our best to try and find the reading among the D5 Next registers that are shown in the Aquaero Dump. Thanks, Fiery Quote
Nunod Posted September 28, 2019 Posted September 28, 2019 Hi Fiery, similar issue how to get the D5 Next flow measurement visible in AIDA64 (my case D5 Next with aqua computer high flow sensor 53068 connected instead of virtual flow sensor). Let me know if this helps. Best, Nuno Below is the aquero debug dump Manufacturer : Aqua Computer GmbH & Co. KG Product : Device Serial Number : 23493-47249 Device ID : 0C70-F00E Revision : 0100h Device Instance : HID\VID_0C70&PID_F00E&MI_01\7&250A4908&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 151 Output Report Byte Length : 264 Feature Report Byte Length: 1025 ------[ Aquaero/Aquaduct Device ]------ Manufacturer = Aqua Computer GmbH & Co. KG Product = Device Serial Number = 23493-47249 Device ID = 0C70-F00E Usage = 0001h Usage Page = FF00h Input Report Byte Length = 151 Output Report Byte Length = 264 Feature Report Byte Length = 1025 ------[ D5Next Input Report ]------ Structure Version = 1 Firmware Version = 1006 Flow 153 l/h, Water Temp 29.62 C Pump 4828 rpm (as displayed by aquasuite) and associated debug dump 0000 00 01 5B C5 B8 91 00 01 00 00 00 64 03 EE 00 00 ..[........d.... 0010 00 71 00 00 03 E6 F5 00 00 00 0E 00 01 5A ED 00 .q...........Z.. 0020 00 00 00 FF FF 00 00 00 AA 6B C0 3B 00 00 06 E7 .........k.;.... 0030 9B 6B 97 6B 5D 9B 04 BA 01 EC 00 00 01 B9 7F FF .k.k]........... 0040 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 00 ................ 0050 00 00 00 00 00 00 0B 92 05 F7 05 F7 00 00 27 10 ..............'. 0060 04 BA 00 00 00 00 00 00 00 00 04 27 10 04 AE 04 ...........'.... 0070 D4 05 C8 12 DC 00 27 10 27 10 27 10 25 7C 09 AE ......'.'.'.%|.. 0080 08 6D 09 A2 08 6C 00 14 00 04 00 00 00 00 00 00 .m...l.......... 0090 00 00 00 00 00 00 ...... Flow 152 l/h, Water Temp 29.65 C Pump 4829 rpm (as displayed by aquasuite) and associated debug dump 0000 00 01 5B C5 B8 91 00 01 00 00 00 64 03 EE 00 00 ..[........d.... 0010 00 71 00 00 03 ED 3A 00 00 00 0E 00 01 5A ED 00 .q....:......Z.. 0020 00 00 00 FF FF 00 00 00 AA 87 C2 13 00 00 06 E6 ................ 0030 9A 8D 97 59 5D 8F 04 BB 01 F1 00 00 01 B9 7F FF ...Y]........... 0040 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 00 ................ 0050 00 00 00 00 00 00 0B 95 05 F3 05 F3 00 00 27 10 ..............'. 0060 04 BB 00 00 00 00 00 00 00 00 04 27 10 04 AF 04 ...........'.... 0070 CD 05 C1 12 DD 00 27 10 27 10 27 10 13 7B 09 AB ......'.'.'..{.. 0080 08 6D 09 A3 08 6C 00 16 00 04 00 00 00 00 00 00 .m...l.......... 0090 00 00 00 00 00 00 ...... Flow 78 l/h, Water Temp 30.39 C Pump 2732 rpm (as displayed by aquasuite) and associated debug dump 000 00 01 5B C5 B8 91 00 01 00 00 00 64 03 EE 00 00 ..[........d.... 0010 00 71 00 00 03 F5 47 00 00 00 0E 00 01 5A ED 00 .q....G......Z.. 0020 00 00 00 FF FF 00 00 00 AB 1A C2 69 00 00 06 EA ...........i.... 0030 2C 41 96 FC 5D 8E 04 C0 01 F2 00 00 01 BA 7F FF ,A..]........... 0040 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 00 ................ 0050 00 00 00 00 00 00 0B DF 03 0F 03 0F 00 00 27 10 ..............'. 0060 04 C0 00 00 00 00 00 00 00 00 04 0A 18 04 BD 01 ................ 0070 60 01 AA 0A AC 00 27 10 0A 18 27 10 12 3A 09 AE `.....'...'..:.. 0080 08 6D 09 A3 08 6C 00 17 00 04 00 00 00 00 00 00 .m...l.......... 0090 00 00 00 00 00 00 ...... Quote
Pak1979 Posted September 29, 2019 Author Posted September 29, 2019 Hello Fiery I have only the single D5 Next connected via a external USB cable to the PC. Unfortunately, I do not own a Aquaero to read it out. Quote
Nunod Posted September 29, 2019 Posted September 29, 2019 a debug dump from aida64 aquero and the HWinfo D5 Next info snip (hope this provides more datapoints to debug the dump) ------[ Versions ]------ Program Version : AIDA64 Extreme v6.10.5200 BenchDLL Version: 4.5.811-x64 Windows Version : Microsoft Windows 10 Pro 10.0.18362.387 (64-bit) ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-090216-Chipset$0AAAA000_BIOS DATE: 06/27/19 19:20:18 VER: 05.0000D Motherboard Model : Asus ROG Rampage VI Extreme Omega Motherboard Chipset : Intel Kaby Point X299, Intel Skylake-X ------[ HID Device Info / HID-compliant vendor-defined device ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : Device Serial Number : 23493-47249 Device ID : 0C70-F00E Revision : 0100h Device Instance : HID\VID_0C70&PID_F00E&MI_01\7&250A4908&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 151 Output Report Byte Length : 264 Feature Report Byte Length: 1025 ------[ Aquaero/Aquaduct Device ]------ Manufacturer = Aqua Computer GmbH & Co. KG Product = Device Serial Number = 23493-47249 Device ID = 0C70-F00E Usage = 0001h Usage Page = FF00h Input Report Byte Length = 151 Output Report Byte Length = 264 Feature Report Byte Length = 1025 ------[ D5Next Input Report ]------ Structure Version = 1 Firmware Version = 1006 0000 00 01 5B C5 B8 91 00 01 00 00 00 64 03 EE 00 00 ..[........d.... 0010 00 71 00 00 00 B9 28 00 00 00 12 00 01 D9 81 00 .q....(......... 0020 00 00 00 FF FF 00 00 00 AB 3E C2 55 00 00 06 EB .........>.U.... 0030 28 32 97 FD 5D 92 04 C1 01 F2 00 00 01 BA 0F 3C (2..]..........< 0040 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 03 00 ................ 0050 00 00 00 00 00 00 0B B7 02 DC 02 DC 00 00 27 10 ..............'. 0060 04 C1 00 00 00 00 00 00 00 00 04 08 F0 04 BE 01 ................ 0070 3F 01 83 0A 50 00 27 10 08 F0 27 10 1E 77 09 AF ?...P.'...'..w.. 0080 08 6D 09 A4 08 6C 00 15 00 04 00 00 00 00 00 00 .m...l.......... 0090 00 00 00 00 00 00 ...... Quote
Fiery Posted October 7, 2019 Posted October 7, 2019 On 9/29/2019 at 11:53 PM, Nunod said: a debug dump from aida64 aquero and the HWinfo D5 Next info snip (hope this provides more datapoints to debug the dump) ------[ Versions ]------ Program Version : AIDA64 Extreme v6.10.5200 BenchDLL Version: 4.5.811-x64 Windows Version : Microsoft Windows 10 Pro 10.0.18362.387 (64-bit) ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-090216-Chipset$0AAAA000_BIOS DATE: 06/27/19 19:20:18 VER: 05.0000D Motherboard Model : Asus ROG Rampage VI Extreme Omega Motherboard Chipset : Intel Kaby Point X299, Intel Skylake-X ------[ HID Device Info / HID-compliant vendor-defined device ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : Device Serial Number : 23493-47249 Device ID : 0C70-F00E Revision : 0100h Device Instance : HID\VID_0C70&PID_F00E&MI_01\7&250A4908&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 151 Output Report Byte Length : 264 Feature Report Byte Length: 1025 ------[ Aquaero/Aquaduct Device ]------ Manufacturer = Aqua Computer GmbH & Co. KG Product = Device Serial Number = 23493-47249 Device ID = 0C70-F00E Usage = 0001h Usage Page = FF00h Input Report Byte Length = 151 Output Report Byte Length = 264 Feature Report Byte Length = 1025 ------[ D5Next Input Report ]------ Structure Version = 1 Firmware Version = 1006 0000 00 01 5B C5 B8 91 00 01 00 00 00 64 03 EE 00 00 ..[........d.... 0010 00 71 00 00 00 B9 28 00 00 00 12 00 01 D9 81 00 .q....(......... 0020 00 00 00 FF FF 00 00 00 AB 3E C2 55 00 00 06 EB .........>.U.... 0030 28 32 97 FD 5D 92 04 C1 01 F2 00 00 01 BA 0F 3C (2..]..........< 0040 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 03 00 ................ 0050 00 00 00 00 00 00 0B B7 02 DC 02 DC 00 00 27 10 ..............'. 0060 04 C1 00 00 00 00 00 00 00 00 04 08 F0 04 BE 01 ................ 0070 3F 01 83 0A 50 00 27 10 08 F0 27 10 1E 77 09 AF ?...P.'...'..w.. 0080 08 6D 09 A4 08 6C 00 15 00 04 00 00 00 00 00 00 .m...l.......... 0090 00 00 00 00 00 00 ..... Thank you, we'll add flow rate reading for D5 Next in the next AIDA64 beta update due in a few days from now. Quote
Fiery Posted October 7, 2019 Posted October 7, 2019 On 9/29/2019 at 9:42 PM, Pak1979 said: Hello Fiery I have only the single D5 Next connected via a external USB cable to the PC. Unfortunately, I do not own a Aquaero to read it out. You don't need an Aquaero device to issue the Aquaero Dump. We'll rename that dump to Aquacomputer Dump to avoid further confusion. Quote
Fiery Posted October 8, 2019 Posted October 8, 2019 On 10/7/2019 at 2:30 PM, Fiery said: Thank you, we'll add flow rate reading for D5 Next in the next AIDA64 beta update due in a few days from now. The new AIDA64 beta build is available for download at: https://www.aida64.com/downloads/latesta64xebeta Quote
Pak1979 Posted October 11, 2019 Author Posted October 11, 2019 I ran Aquasuite and the newAida64 beta at the same time and compared the read values. The new beta works great. Quote
Fiery Posted October 14, 2019 Posted October 14, 2019 On 10/11/2019 at 5:55 AM, Pak1979 said: I ran Aquasuite and the newAida64 beta at the same time and compared the read values. The new beta works great. Awesome, thank you for your help! Quote
