Hello everyone :D. Aida64 on my iphone XR shows that the battery capacity is 2658mAh while actual battery capacity of Iphone XR is 2942mAh. Is this a mistake or my Iphone battery has been replaced? Thank you.
Hi, probably AIDA64 was not able to download the updated database to fix this value. Please try to restart AIDA64 on your phone with Internet connection. The value comes from the database so it is not possible to detect replaced or different battery size.
  • 7 months later...
Hello,
I know this is an old post, but hopefully i can still post here as I have similar question.
I have a korean model LG v50 ThinQ. Aida64 shows 3500 mah (reported by android) and 4000 mah (from database).
My question is why does it show these two figures? Is there a problem with my phone battery?
Thank you
Thank you
The first battery capacity value (labelled as "Capacity (Reported by Android)") comes from the Android profile of your device. It was encoded to the profile by the manufacturer of your device, and may or may not reflect an accurate value. The second value (labelled as "Capacity (From Database)") comes from the built-in AIDA64 hardware database, and should reflect the correct value.
