4 hours ago, Maoxian said:
or Because I'm a laptop?
With laptops it's usually difficult to measure such values.  But, we can try to figure out how it works if you could help us a little bit.  Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
  • Thanks 1
OK   thank you ~~
isasensordump2.txt
On ‎3‎/‎10‎/‎2020 at 10:27 AM, Maoxian said:
I'm afraid we cannot find the fan RPM reading or the fan duty cycle reading among the EC registers.  It may still be there, but it's difficult to identify them.
  • 1 year later...
