BlaKer Posted August 30, 2020 Posted August 30, 2020 Hi, I just got the corsair ICUE nexus and saw that you were working on remote sensor support for it. Do you got any updates on that? Will it even work cause of the icue requierment? Cause im not sure if i will return this to get a elgato streamingdeck insted. How good is the support for the elgato streamingdeck? How does it work to applie sensors to the buttons? Is it just one sensor per key or can you have many sensors on one "key". Which of these two would you recomend using for remote sensor? Kind regards BlaKe Quote
Fiery Posted August 31, 2020 Posted August 31, 2020 14 hours ago, BlaKer said: Hi, I just got the corsair ICUE nexus and saw that you were working on remote sensor support for it. Do you got any updates on that? Will it even work cause of the icue requierment? Cause im not sure if i will return this to get a elgato streamingdeck insted. How good is the support for the elgato streamingdeck? How does it work to applie sensors to the buttons? Is it just one sensor per key or can you have many sensors on one "key". Which of these two would you recomend using for remote sensor? Kind regards BlaKe Our iCUE Nexus device hasn't arrived yet. As soon as it hits our lab, we start researching how can we support it. I have high hopes of fully supporting it as long as you close iCUE (software) since it notoriously collides with any other hardware monitoring software that is trying to access Corsair hardware. As for El Gato, the support is quite basic. You can place a single image on the last key and that's it. We're hoping that someone can develop a plugin for it that would allow more flexibility and greater interaction with other plugins. Currently we cannot allocate more development time on that project. I cannot recommend either, since El Gato support is too basic, and without a test device I cannot confirm that iCUE Nexus would work with AIDA64. Quote
BlaKer Posted August 31, 2020 Author Posted August 31, 2020 8 hours ago, Fiery said: Our iCUE Nexus device hasn't arrived yet. As soon as it hits our lab, we start researching how can we support it. I have high hopes of fully supporting it as long as you close iCUE (software) since it notoriously collides with any other hardware monitoring software that is trying to access Corsair hardware. As for El Gato, the support is quite basic. You can place a single image on the last key and that's it. We're hoping that someone can develop a plugin for it that would allow more flexibility and greater interaction with other plugins. Currently we cannot allocate more development time on that project. I cannot recommend either, since El Gato support is too basic, and without a test device I cannot confirm that iCUE Nexus would work with AIDA64. Thx for the update Fiery. 1.So do i understand you correct that aida64 onyl can use one of the buttons for showing sensors? One cannot place diffrent sensors on all the buttons? I dont really need the pushing button part to work i just want to see all the sensors on the buttons. 2. What type of device would you recommend that is easy to install like the elgato or the corsair nexus if i dont want to use a second lcd display in windows or an old android device? Edit 3. I came across a beadapanel 5" if i connect this, will it show up as a second display in windows that i need to move the remote sensor to everytime i start my pc? Quote
Fiery Posted September 1, 2020 Posted September 1, 2020 23 hours ago, BlaKer said: Thx for the update Fiery. 1.So do i understand you correct that aida64 onyl can use one of the buttons for showing sensors? One cannot place diffrent sensors on all the buttons? I dont really need the pushing button part to work i just want to see all the sensors on the buttons. 2. What type of device would you recommend that is easy to install like the elgato or the corsair nexus if i dont want to use a second lcd display in windows or an old android device? Edit 3. I came across a beadapanel 5" if i connect this, will it show up as a second display in windows that i need to move the remote sensor to everytime i start my pc? 1) Only a single button is handled as a small LCD screen. 2+3) BeadaPanel has a 5-inch and 7-inch version. They are handled by the AIDA64 LCD module directly via their proprietary USB protocol. They don't show up as a secondary monitor in Windows. 1 Quote
BlaKer Posted September 1, 2020 Author Posted September 1, 2020 41 minutes ago, Fiery said: 1) Only a single button is handled as a small LCD screen. 2+3) BeadaPanel has a 5-inch and 7-inch version. They are handled by the AIDA64 LCD module directly via their proprietary USB protocol. They don't show up as a secondary monitor in Windows. Thank you! Quote
p1r473 Posted October 27, 2023 Posted October 27, 2023 On 8/31/2020 at 5:24 AM, Fiery said: Our iCUE Nexus device hasn't arrived yet. As soon as it hits our lab, we start researching how can we support it. I have high hopes of fully supporting it as long as you close iCUE (software) since it notoriously collides with any other hardware monitoring software that is trying to access Corsair hardware. As for El Gato, the support is quite basic. You can place a single image on the last key and that's it. We're hoping that someone can develop a plugin for it that would allow more flexibility and greater interaction with other plugins. Currently we cannot allocate more development time on that project. I cannot recommend either, since El Gato support is too basic, and without a test device I cannot confirm that iCUE Nexus would work with AIDA64. Any update on iCue nexus support? Doesnt seen to be any option in Preferences->LCD Quote
s3r1u5 Posted January 5, 2024 Posted January 5, 2024 Any news about this ? I know for sure that there is a way to use this display without ICUE as this SimHub application does https://www.simhubdash.com/external-graphic-dashboard-what-are-the-options-what-to-choose Quote
Ghiroza Posted October 27, 2024 Posted October 27, 2024 On 8/31/2020 at 11:24 AM, Fiery said: Our iCUE Nexus device hasn't arrived yet. As soon as it hits our lab, we start researching how can we support it. I have high hopes of fully supporting it as long as you close iCUE (software) since it notoriously collides with any other hardware monitoring software that is trying to access Corsair hardware. As for El Gato, the support is quite basic. You can place a single image on the last key and that's it. We're hoping that someone can develop a plugin for it that would allow more flexibility and greater interaction with other plugins. Currently we cannot allocate more development time on that project. I cannot recommend either, since El Gato support is too basic, and without a test device I cannot confirm that iCUE Nexus would work with AIDA64. It's been quiet some time since this message. Is there any plan to have any kind of support for the nexus device? I would love to have more control over it and have more information displayed then the limited options it offers by it self. Quote
Fiery Posted July 12 Posted July 12 On 8/30/2020 at 8:32 PM, BlaKer said: Hi, I just got the corsair ICUE nexus and saw that you were working on remote sensor support for it. Do you got any updates on that? Will it even work cause of the icue requierment? Cause im not sure if i will return this to get a elgato streamingdeck insted. How good is the support for the elgato streamingdeck? How does it work to applie sensors to the buttons? Is it just one sensor per key or can you have many sensors on one "key". Which of these two would you recomend using for remote sensor? Kind regards BlaKe @p1r473 @s3r1u5 @Ghiroza We've implemented support for Corsair iCUE Nexus LCD display in the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. You can activate and configure the Nexus LCD module in AIDA64 / Preferences / Hardware Monitoring / LCD / Corsair. Let me know how it works. Quote
samlevy0515 Posted September 5 Posted September 5 Great questions. Right now, the Elgato Stream Deck is definitely the more mature and flexible option for remote sensor monitoring. You can assign multiple sensors to a single key by using a plugin like "Stream Deck Smart Profile," which allows for dynamic, multi-line displays. Support is excellent. The Corsair Nexus is more limited since it requires iCUE to be running, which restricts remote monitoring. While I am looking into it, support isn't available yet. For your use case, the Stream Deck is likely the better choice. Hope that helps with your decision Quote
