Ridingmac Posted April 6, 2021 Posted April 6, 2021 Hi, I have a corsair H150i has a CPU cooler. Aida64 show pump rpm and only 2 or the 3 fans. RTSS and HWinfo64 do however have all 3 fans and i would like my sensor panel to display all 3 fans. Is there a way to add either RTSS or HWinfo64 sensor data to Aida64 extreme? If so can someone point me in the right direction to a tutorial/documentation on how to do this? Thanks Quote
Fiery Posted April 7, 2021 Posted April 7, 2021 22 hours ago, Ridingmac said: Hi, I have a corsair H150i has a CPU cooler. Aida64 show pump rpm and only 2 or the 3 fans. RTSS and HWinfo64 do however have all 3 fans and i would like my sensor panel to display all 3 fans. Is there a way to add either RTSS or HWinfo64 sensor data to Aida64 extreme? If so can someone point me in the right direction to a tutorial/documentation on how to do this? Thanks Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
Ridingmac Posted April 7, 2021 Author Posted April 7, 2021 I would also add, that i do have all 3 fans within RTSS and HWinfo64. usbdump.txt Quote
