kojahap Posted March 10, 2024 Posted March 10, 2024 Linear write test does not work correctly in newer versions and waits for SLC cache release. Test time for 500 GB increased from 9 minutes to 27 minutes, but the graph is very smooth, all speed is shown exclusively using SLC cache. dll 3.2 works properly https://ibb.co/517pkVH https://ibb.co/fQqNJkh Error - https://ibb.co/n6mQHSX Quote
Fiery Posted March 10, 2024 Posted March 10, 2024 6 hours ago, kojahap said: Linear write test does not work correctly in newer versions and waits for SLC cache release. Test time for 500 GB increased from 9 minutes to 27 minutes, but the graph is very smooth, all speed is shown exclusively using SLC cache. dll 3.2 works properly https://ibb.co/517pkVH https://ibb.co/fQqNJkh Error - https://ibb.co/n6mQHSX What do you mean by DLL 3.2? Do you use the same Windows version across the test runs? Quote
kojahap Posted March 10, 2024 Author Posted March 10, 2024 1 hour ago, Fiery said: What do you mean by DLL 3.2? Do you use the same Windows version across the test runs? From old version 3.2 of Aida64. There were used different AMD/Intel computers and different windows updates, even complete reinstallation of windows. Quote
Fiery Posted March 10, 2024 Posted March 10, 2024 2 hours ago, kojahap said: From old version 3.2 of Aida64. There were used different AMD/Intel computers and different windows updates, even complete reinstallation of windows. I was asking because quite frankly we've changed very little in the past 10 years about the Disk Benchmarks. So whatever difference you may experience could just be because of changes happening in and about the Windows kernel and the way Windows treats storage devices. Quote
kojahap Posted March 10, 2024 Author Posted March 10, 2024 2 hours ago, Fiery said: I was asking because quite frankly we've changed very little in the past 10 years about the Disk Benchmarks. So whatever difference you may experience could just be because of changes happening in and about the Windows kernel and the way Windows treats storage devices. However, replacing a single file without changing the system can solve this problem. Quote
Fiery Posted March 11, 2024 Posted March 11, 2024 10 hours ago, kojahap said: However, replacing a single file without changing the system can solve this problem. Which file should we replace? Quote
Solution kojahap Posted March 11, 2024 Author Solution Posted March 11, 2024 3 hours ago, Fiery said: Which file should we replace? Clean installation of Aida64 version 7.0 + aida_diskbench.dll from Aida64 version 3.2 or 4.2 (AIDA64 Disk Benchmark Version - 1.04.07) work correctly. https://ibb.co/KWbXsyd Quote
Hateme Posted September 4, 2025 Posted September 4, 2025 THIS. Why it is still not fixed in newer versions? Quote
