B. A. Kenney 0 Posted October 10, 2010 Report Share Posted October 10, 2010 Hello, I have a HP Pavilion dv6 Notebook 3032-us with mobile Intel Core i3 350M processor, 4GB DDR3-1066 memory, 320GB Hitachi SATA-II hard drive. My problem is that if I open AIDA64 CPUID, my system would freeze if the processor speed is fully kicked in (running at full speed; I think). I don't know if this is the CPUID's parameter error or if my processor is causing the system to hang. It's really frustrating! How do I fix this issue and still access AIDA64 CPUID at the same time without restarting my laptop every time? Thanks, BK P.S. - I access AIDA64 CPUID a lot of times because of its new design and quick information that I need to know. Quote Link to post Share on other sites
Fiery 456 Posted October 10, 2010 Report Share Posted October 10, 2010 1) Do you experience the same lockup on other systems as well, or it only happens on this particular notebook? 2) Does the lockup happen when you go to the following AIDA64 pages in the left page menu? - Computer / Summary - Computer / Sensor - Motherboard / CPU - Motherboard / SPD - Motherboard / Chipset - Display / GPU Please let us know which page(s) cause a similar lockup. We need to narrow it down to a specific module of AIDA64, so we can start investigating from there. Thanks, Fiery Quote Link to post Share on other sites
B. A. Kenney 0 Posted October 10, 2010 Author Report Share Posted October 10, 2010 Hello Fiery, First of all, thanks for the reply! To answer your question: 1) I do not experience this problem with other machines - thank goodness! 2) Often times, I am always in the Sensor page when I open AIDA64 CPUID window, if not in the Summary page. Anyways, what matters the most is if I visit any page, freeze up will still occur. How weird. I believe the Sensor page is the most frequent cause for error. If you need more information, please let me know! Thanks, BK Quote Link to post Share on other sites
ckit 0 Posted October 29, 2010 Report Share Posted October 29, 2010 I just got the same lockup and I'm mad as hell about it! - Opened PhotoFiltre Studio 10.3.2 and started work on a pic - Opened AIDA64 v1.00.1123 beta and CPUID window, pressed Alt+Prt Scn, Ashampoo Snap 3's editor loads with screenshot... - On cropping the last of 4 sides -BANG- my machine locks frozen and need to press Reset on my case! Windows 7 Professional x64 Quote Link to post Share on other sites
Fiery 456 Posted October 29, 2010 Report Share Posted October 29, 2010 I just got the same lockup and I'm mad as hell about it! - Opened PhotoFiltre Studio 10.3.2 and started work on a pic - Opened AIDA64 v1.00.1123 beta and CPUID window, pressed Alt+Prt Scn, Ashampoo Snap 3's editor loads with screenshot... - On cropping the last of 4 sides -BANG- my machine locks frozen and need to press Reset on my case! Windows 7 Professional x64 In case it didn't freeze right after you opened AIDA64 CPUID window, then I'm not at all convinced that the freeze is in connection with AIDA64, or that it's entirely AIDA64's fault But please let us know more about your system, e.g. CPU type, motherboard model, and whether you can experience similar lockups when you have e.g. the OSD Panel opened. Quote Link to post Share on other sites
ckit 0 Posted October 30, 2010 Report Share Posted October 30, 2010 In case it didn't freeze right after you opened AIDA64 CPUID window, then I'm not at all convinced that the freeze is in connection with AIDA64, or that it's entirely AIDA64's fault But please let us know more about your system, e.g. CPU type, motherboard model, and whether you can experience similar lockups when you have e.g. the OSD Panel opened. Gigabyte H55M-USB3 rev2.00 bios F10 (latest) Motherboard Intel Core i5-661 3.33Ghz (using Intel HD GPU) Kingston 8Gb DDR3 1333Mhz Dual Channel (2 x 4Gb) I admit the lockup occurred in Ashampoo Snap 3 but AIDA64 was still running in the background and unless Ashampoo Snap 3 has a problem with Intel HD Graphics Drivers (latest are installed) the blame comes back to AIDA64. Not long after the lockup, I went back and retraced all steps without AIDA64 this time (captured something else to the clipboard) and there were no lockups. Quote Link to post Share on other sites
Fiery 456 Posted October 30, 2010 Report Share Posted October 30, 2010 Gigabyte H55M-USB3 rev2.00 bios F10 (latest) Motherboard Intel Core i5-661 3.33Ghz (using Intel HD GPU) Kingston 8Gb DDR3 1333Mhz Dual Channel (2 x 4Gb) I admit the lockup occurred in Ashampoo Snap 3 but AIDA64 was still running in the background and unless Ashampoo Snap 3 has a problem with Intel HD Graphics Drivers (latest are installed) the blame comes back to AIDA64. Not long after the lockup, I went back and retraced all steps without AIDA64 this time (captured something else to the clipboard) and there were no lockups. 1) Do you overclock your system? 2) Do you have any external hard disk drives connected? If yes, then USB or eSATA or FireWire? 3) Does a lockup occur when you have the Sensor page showing and updating? 4) Please copy-paste the full content of the Sensor page into this topic. Thanks, Fiery Quote Link to post Share on other sites
ckit 0 Posted October 30, 2010 Report Share Posted October 30, 2010 (edited) 1) Do you overclock your system? 2) Do you have any external hard disk drives connected? If yes, then USB or eSATA or FireWire? 3) Does a lockup occur when you have the Sensor page showing and updating? 4) Please copy-paste the full content of the Sensor page into this topic. Thanks, Fiery 1. No 2. Not at the time, I have 3 external USB 2.0 HDD's but only connect them when needed. 3. Not so far 4. Sensor Type ITE IT8720F (ISA 290h) Motherboard Name Gigabyte H55 / H55M / H57M / P55 / P55A / P55M / Q57M Series Chassis Intrusion Detected Yes Temperatures Motherboard 37 °C (99 °F) CPU 23 °C (73 °F) CPU #1 / Core #1 34 °C (93 °F) CPU #1 / Core #2 29 °C (84 °F) PCH 64 °C (147 °F) GMCH 37 °C (99 °F) SAMSUNG HD502HJ 35 °C (95 °F) Cooling Fans CPU 1308 RPM Voltage Values CPU Core 0.960 V +3.3 V 3.360 V +5 V 4.946 V +12 V 12.352 V VBAT Battery 3.168 V DIMM 1.584 V Not sure if it matters or not but I'm not using a Discrete Graphics card, I'm using Intel's newer integrated graphics in the Core range. Edited October 30, 2010 by ckit Quote Link to post Share on other sites
ckit 0 Posted October 31, 2010 Report Share Posted October 31, 2010 Just changed HEPT from 32-bit to 64-bit in the BIOS but didn't fix it. Also, noticed that when it locks up the multiplier reads x26!!! it should go between x9.0 and x10.0 Quote Link to post Share on other sites
Fiery 456 Posted October 31, 2010 Report Share Posted October 31, 2010 Core i5 661 uses a max. non-turbo multiplier of 25x (25 x 133.33 MHz BCLK = 3333 MHz core clock). With Turbo Boost it can raise the core multiplier up to as high as 27x. So when AIDA64 reads 26x, it is absolutely normal for your CPU. Thank you for the feedback, please let me know if AIDA64 locks up when you have the Computer / Overclock page opened and updating. Quote Link to post Share on other sites
ckit 0 Posted October 31, 2010 Report Share Posted October 31, 2010 AIDA64 locks up when the Overclock page is open and updating. I've also updated to the latest beta 1130. Quote Link to post Share on other sites
Fiery 456 Posted November 1, 2010 Report Share Posted November 1, 2010 AIDA64 locks up when the Overclock page is open and updating. I've also updated to the latest beta 1130. Thank you, that narrows it down to CPU clock measurement. Do you have any other software running in the background that may also monitor & measure CPU clock speed? Quote Link to post Share on other sites
ckit 0 Posted November 1, 2010 Report Share Posted November 1, 2010 Not really, Process Lasso Pro v4.00.08 RC1 beta would be the closest, I guess. Quote Link to post Share on other sites
Fiery 456 Posted November 1, 2010 Report Share Posted November 1, 2010 Not really, Process Lasso Pro v4.00.08 RC1 beta would be the closest, I guess. Can you please try to close that to see if it causes a collision with AIDA64, or we need to look elsewhere? Quote Link to post Share on other sites
ChiefZeke 0 Posted November 1, 2010 Report Share Posted November 1, 2010 Running AIDA 1.00.1130 and Process Lasso Pro 4.00.08RC1 - checked Computer/Overclock page here - no problems at all. Quote Link to post Share on other sites
Fiery 456 Posted November 1, 2010 Report Share Posted November 1, 2010 Running AIDA 1.00.1130 and Process Lasso Pro 4.00.08RC1 - checked Computer/Overclock page here - no problems at all. Thanks What CPU and motherboard do you have? I suspect it's going to be a bug related to Clarkdale/Arrandale core processors. Quote Link to post Share on other sites
ckit 0 Posted November 2, 2010 Report Share Posted November 2, 2010 Can you please try to close that to see if it causes a collision with AIDA64, or we need to look elsewhere? We need to look elsewhere! Having said that, it did take me much longer to reproduce the lock up. Logfile of AnVir Task Manager Pro v6.3.1 http://www.anvir.com Log saved at 2/11/2010 18:04 Platform: Windows Windows7_64 MSIE: Internet Explorer v8.0 Running processes: {Not Microsoft} C:\Program Files (x86)\USB Safely Remove\USBSRService.exe {CPU time=0:00, Memory=4 MB, PageFile=1.9 MB} C:\Program Files\Alwil Software\Avast5\AvastSvc.exe {CPU time=0:05, Memory=6 MB, PageFile=15 MB} C:\Program Files (x86)\Intel\Intel® Management Engine Components\LMS\LMS.exe {CPU time=0:00, Memory=5 MB, PageFile=2 MB} C:\Program Files\Raxco\PerfectDisk10\PDAgent.exe {CPU time=0:02, Memory=9 MB, PageFile=3 MB} c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe {CPU time=0:00, Memory=3 MB, PageFile=1.0 MB} C:\Program Files (x86)\Quick PDF Tools\QuickPDFTCP0719.exe {CPU time=0:00, Memory=5 MB, PageFile=2 MB, Security risk=38%} C:\Program Files\Raxco\PerfectDisk10\PDEngine.exe {CPU time=0:02, Memory=7 MB, PageFile=2 MB} C:\Windows\System32\igfxtray.exe {CPU time=0:00, Memory=6 MB, PageFile=2 MB} C:\Windows\System32\hkcmd.exe {CPU time=0:00, Memory=10 MB, PageFile=3 MB} C:\Windows\System32\igfxpers.exe {CPU time=0:00, Memory=8 MB, PageFile=3 MB} C:\Program Files\Logitech\SetPointP\SetPoint.exe {CPU time=0:00, Memory=18 MB, PageFile=8 MB} C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe {CPU time=0:00, Memory=11 MB, PageFile=10 MB} C:\Program Files\Process Lasso\ProcessLasso.exe {CPU time=0:01, Memory=4 MB, PageFile=4 MB} C:\Program Files\Process Lasso\ProcessGovernor.exe {CPU time=0:00, Memory=4 MB, PageFile=2 MB, Security risk=26%} C:\Program Files\Process Lasso\ProcessGovernor.exe {CPU time=0:00, Memory=4 MB, PageFile=3 MB, Security risk=26%} C:\Program Files (x86)\SoftMaker Office 2010\Smash.exe {CPU time=0:00, Memory=6 MB, PageFile=1.6 MB, Security risk=30%} C:\Program Files (x86)\Internet Download Manager\IDMan.exe {CPU time=0:00, Memory=17 MB, PageFile=8 MB} C:\Program Files (x86)\NetworkIndicator\NetworkIndicator.exe {CPU time=0:00, Memory=4 MB, PageFile=1.3 MB} C:\Program Files\Common Files\LogiShrd\KHAL3\KHALMNPR.exe {CPU time=0:00, Memory=11 MB, PageFile=6 MB} D:\KeePass\KeePass.exe {CPU time=0:01, Memory=48 MB, PageFile=43 MB, Security risk=30%} C:\Program Files (x86)\USB Safely Remove\USBSafelyRemove.exe {CPU time=0:00, Memory=16 MB, PageFile=12 MB} C:\Program Files (x86)\AquaSnap\AquaSnap.Daemon.exe {CPU time=0:00, Memory=2 MB, PageFile=2 MB, Security risk=30%} C:\Program Files (x86)\Ashampoo\Ashampoo Snap 3\ashsnap.exe {CPU time=0:00, Memory=9 MB, PageFile=4 MB} C:\Program Files (x86)\AquaSnap\AquaSnap.Daemon.x64.exe {CPU time=0:00, Memory=3 MB, PageFile=2 MB, Security risk=26%} C:\Program Files\Raxco\PerfectDisk10\PDAgentS1.exe {CPU time=0:00, Memory=5 MB, PageFile=2 MB} D:\CintaNotes\cintanotes.exe {CPU time=0:00, Memory=8 MB, PageFile=3 MB, Security risk=46%} C:\Program Files (x86)\FindAndRunRobot\FindAndRunRobot.exe {CPU time=0:02, Memory=20 MB, PageFile=10 MB, Security risk=40%} C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe {CPU time=0:00, Memory=5 MB, PageFile=2 MB} C:\Program Files (x86)\Intel\Intel® Rapid Storage Technology\IAStorIcon.exe {CPU time=0:00, Memory=22 MB, PageFile=23 MB} C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe {CPU time=0:00, Memory=4 MB, PageFile=1.3 MB} C:\Program Files\Alwil Software\Avast5\AvastUI.exe {CPU time=0:00, Memory=3 MB, PageFile=4 MB} C:\Program Files (x86)\Internet Download Manager\IEMonitor.exe {CPU time=0:00, Memory=6 MB, PageFile=2 MB} C:\Program Files (x86)\BillP Studios\WinPatrol\WinPatrol.exe {CPU time=0:00, Memory=9 MB, PageFile=2 MB} C:\Program Files (x86)\Brother\ControlCenter3\BrccMCtl.exe {CPU time=0:02, Memory=14 MB, PageFile=5 MB, Security risk=30%} C:\Program Files (x86)\NetWorx\networx.exe {CPU time=0:00, Memory=22 MB, PageFile=16 MB} D:\FirefoxPortable\FirefoxPortable.exe {CPU time=0:00, Memory=8 MB, PageFile=36 MB, Security risk=30%} D:\FirefoxPortable\App\Firefox\firefox.exe {CPU time=0:16, Memory=148 MB, PageFile=125 MB} C:\Program Files (x86)\Intel\Intel® Rapid Storage Technology\IAStorDataMgrSvc.exe {CPU time=0:00, Memory=15 MB, PageFile=17 MB} C:\Program Files (x86)\Intel\Intel® Management Engine Components\UNS\UNS.exe {CPU time=0:00, Memory=10 MB, PageFile=5 MB} C:\Program Files (x86)\AnVir Task Manager Pro\AnVir.exe {CPU time=0:09, Memory=32 MB, PageFile=42 MB} {Microsoft} C:\Windows\System32\smss.exe {CPU time=0:00, Memory=1.1 MB} C:\Windows\System32\csrss.exe {CPU time=0:00, Memory=4 MB, PageFile=2 MB} C:\Windows\System32\wininit.exe {CPU time=0:00, Memory=4 MB, PageFile=1.6 MB} C:\Windows\System32\csrss.exe {CPU time=0:01, Memory=14 MB, PageFile=2 MB} C:\Windows\System32\winlogon.exe {CPU time=0:00, Memory=7 MB, PageFile=3 MB} C:\Windows\System32\services.exe {CPU time=0:01, Memory=10 MB, PageFile=6 MB} C:\Windows\System32\lsass.exe {CPU time=0:01, Memory=10 MB, PageFile=4 MB} C:\Windows\System32\lsm.exe {CPU time=0:00, Memory=4 MB, PageFile=2 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=9 MB, PageFile=4 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=7 MB, PageFile=4 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=22 MB, PageFile=21 MB} C:\Windows\System32\svchost.exe {CPU time=0:05, Memory=98 MB, PageFile=96 MB} C:\Windows\System32\svchost.exe {CPU time=0:01, Memory=31 MB, PageFile=18 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=15 MB, PageFile=8 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=15 MB, PageFile=13 MB} C:\Windows\System32\spoolsv.exe {CPU time=0:00, Memory=13 MB, PageFile=7 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=13 MB, PageFile=12 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=9 MB, PageFile=6 MB} C:\Windows\System32\taskhost.exe {CPU time=0:00, Memory=7 MB, PageFile=3 MB} C:\Windows\System32\dwm.exe {CPU time=0:05, Memory=27 MB, PageFile=60 MB} C:\Windows\explorer.exe {CPU time=0:03, Memory=37 MB, PageFile=24 MB} C:\Windows\System32\SearchIndexer.exe {CPU time=0:00, Memory=13 MB, PageFile=19 MB} C:\Program Files\Windows Media Player\wmpnetwk.exe {CPU time=0:00, Memory=1.0 MB, PageFile=5 MB} C:\Windows\System32\svchost.exe {CPU time=0:00, Memory=8 MB, PageFile=5 MB} C:\Windows\System32\wbem\WmiPrvSE.exe {CPU time=0:00, Memory=5 MB, PageFile=2 MB} O2 - BHO: IDMIEHlprObj Class - {0055C089-8582-441B-A0BF-17B458C2A3A8} - C:\Program Files (x86)\Internet Download Manager\IDMIECC.dll O2 - BHO: Java Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll O4 - HKLM\..\Run: [NUSB3MON] "C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe" O4 - HKLM\..\Run: [iAStorIcon] C:\Program Files (x86)\Intel\Intel® Rapid Storage Technology\IAStorIcon.exe O4 - HKLM\..\Run: [brMfcWnd] C:\Program Files (x86)\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN O4 - HKLM\..\Run: [ControlCenter3] C:\Program Files (x86)\Brother\ControlCenter3\brctrcen.exe /autorun O4 - HKLM\..\Run: [sunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe" O4 - HKLM\..\Run: [avast5] "C:\Program Files\Alwil Software\Avast5\avastUI.exe" /nogui O4 - HKLM\..\Run: [WinPatrol] C:\Program Files (x86)\BillP Studios\WinPatrol\winpatrol.exe -expressboot O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime {Security risk=24%} O4 - HKLM\..\Run: [NetWorx] "C:\Program Files (x86)\NetWorx\networx.exe" /auto O4 - HKCU\..\Run: [sMASH] "C:\Program Files (x86)\SoftMaker Office 2010\SMASH.EXE" {Security risk=30%} O4 - HKCU\..\Run: [iDMan] C:\Program Files (x86)\Internet Download Manager\IDMan.exe /onboot O4 - HKCU\..\Run: [NetworkIndicator] C:\Program Files (x86)\NetworkIndicator\NetworkIndicator.exe O4 - HKCU\..\Run: [KeePass Password Safe 2] "D:\KeePass\KeePass.exe" {Security risk=30%} O4 - HKCU\..\Run: [uSB Safely Remove] C:\Program Files (x86)\USB Safely Remove\USBSafelyRemove.exe /startup O4 - HKCU\..\Run: [AquaSnap] C:\Program Files (x86)\AquaSnap\AquaSnap.Daemon.exe {Security risk=30%} O4 - HKCU\..\Run: [AshSnap] C:\Program Files (x86)\Ashampoo\Ashampoo Snap 3\ashsnap.exe O4 - HKCU\..\Run: [CintaNotes] "D:\CintaNotes\cintanotes.exe" -m {Security risk=46%} O4 - File: Find And Run Robot.lnk = C:\Program Files (x86)\FindAndRunRobot\FindAndRunRobot.exe {Security risk=40%} O4 - File: Logitech . Product Registration.lnk = C:\Program Files (x86)\Common Files\LogiShrd\eReg\SetPoint\eReg.exe O23 - Service: avast! Antivirus (avast! Antivirus) - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe O23 - Service: avast! Mail Scanner (avast! Mail Scanner) - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe O23 - Service: avast! Web Scanner (avast! Web Scanner) - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe O23 - Service: Windows Media Center Receiver Service (ehRecvr) - Microsoft Corporation - C:\Windows\ehome\ehrecvr.exe O23 - Service: Intel® Rapid Storage Technology (IAStorDataMgrSvc) - Intel Corporation - C:\Program Files (x86)\Intel\Intel® Rapid Storage Technology\IAStorDataMgrSvc.exe O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech, Inc. - C:\Program Files\Common Files\LogiShrd\Bluetooth\LBTServ.exe O23 - Service: Intel® Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel® Management Engine Components\LMS\LMS.exe O23 - Service: PDAgent (PDAgent) - Raxco Software, Inc. - C:\Program Files\Raxco\PerfectDisk10\PDAgent.exe O23 - Service: PDEngine (PDEngine) - Raxco Software, Inc. - C:\Program Files\Raxco\PerfectDisk10\PDEngine.exe O23 - Service: Performance Counter DLL Host (PerfHost) - Microsoft Corporation - C:\Windows\SysWOW64\perfhost.exe O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe O23 - Service: Quick PDF Tools Background Service (QuickPDFTCPService0719) - Debenu Pty Ltd - C:\Program Files (x86)\Quick PDF Tools\QuickPDFTCP0719.exe {Security risk=38%} O23 - Service: Software Protection (sppsvc) - Microsoft Corporation - C:\Windows\System32\sppsvc.exe O23 - Service: Interactive Services Detection (UI0Detect) - Microsoft Corporation - C:\Windows\System32\UI0Detect.exe O23 - Service: Intel® Management & Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel® Management Engine Components\UNS\UNS.exe O23 - Service: USB Safely Remove Assistant (USBSafelyRemoveService) - Unknown owner - C:\Program Files (x86)\USB Safely Remove\USBSRService.exe -- End of file - 11028 bytes Quote Link to post Share on other sites
ChiefZeke 0 Posted November 2, 2010 Report Share Posted November 2, 2010 Thanks What CPU and motherboard do you have? I suspect it's going to be a bug related to Clarkdale/Arrandale core processors. ABIT IX48 GT3 motherboard Intel Core 2 Quad 9650 cpu If you need more info let me know. Quote Link to post Share on other sites
ckit 0 Posted November 12, 2010 Report Share Posted November 12, 2010 I'm still getting lockups with the new AIDA64 v1.20 Final. Using CPU-Z for now, I might try HWInfo32 or Gigabyte's EasyTune 6 later... Quote Link to post Share on other sites
rooie 0 Posted November 15, 2010 Report Share Posted November 15, 2010 Well, count me in, system freezes when using 'sensors' or 'overclock' Had exactly the same with Everest! What is working is the 'pci trick' in the ini file but then you will have NO sensor reading. The speed of the NB is reported false, 1200mhz instead of 2100mhz. My system: Asus M4A89TD/pro USB3 AMD 1055T overclocked to 3900mhz Patriot 2000ll series 2000mhz@1600mhz 2x2GB 2 x HD5850 Seems to me that reading the sensorchip is causing troubles. Quote Link to post Share on other sites
Fiery 456 Posted November 17, 2010 Report Share Posted November 17, 2010 All of you, please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1155bv4sdn8ytxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it makes any difference. Rooie: I suppose in your case it's a ULPS-related issue. Please try to disable Multi-GPU support in AIDA64 / main menu / File / Preferences / Stability, and check if it fixes the lockup. Quote Link to post Share on other sites
ckit 0 Posted November 18, 2010 Report Share Posted November 18, 2010 Can't test it sorry, my license is now invalid. Quote Link to post Share on other sites
IceMan 0 Posted November 18, 2010 Report Share Posted November 18, 2010 did you use an stolen key? Quote Link to post Share on other sites
ckit 0 Posted November 18, 2010 Report Share Posted November 18, 2010 No. Quote Link to post Share on other sites
IceMan 0 Posted November 18, 2010 Report Share Posted November 18, 2010 pls post a screenshot with your key with previous version (were the key worked) and one screen with new version who the key doesnt work i mean a screen under help/info Quote Link to post Share on other sites
