Mayo0666 Posted January 17, 2018 Posted January 17, 2018 Hi Odospace, i am trying to connet a Samsung Tab 2 10' instead of my phone, Odospace see it but i can't see sensor panel on its screen, what can i do? Quote
Mayo0666 Posted January 19, 2018 Posted January 19, 2018 mmh, i found that reinstalling odospace sensor panel on PC i can see the SAmsung tab2 now... Quite strange, isn't it? Quote
Overclockeverything Posted April 10, 2018 Posted April 10, 2018 When my system wakes from sleep odospace dll causes Aida to crash. I am running the latest V1.16 with ADB version 32 and ADIA64 version 5.97.4600. I am connecting via wi/fi to a Polaroid A7. Any help would be greatly appreciated. Everything works and connects automatically when I first boot my PC as well as when I manually restart AIDA after waking from sleep. Quote
pmgamer Posted January 3, 2019 Posted January 3, 2019 Hello, Great job, I would like to use your application since my G15 is out Can you tell me where I can found oslcd files ? I see a lot of template screen but no files, only odospace file lcd.zip, no body share templates ? Quote
novax Posted January 16, 2019 Posted January 16, 2019 On 1/3/2019 at 6:07 PM, pmgamer said: Hello, Great job, I would like to use your application since my G15 is out Can you tell me where I can found oslcd files ? I see a lot of template screen but no files, only odospace file lcd.zip, no body share templates ? Expand HelloHere in will count some, oslcd Quote
braddocksb Posted January 27, 2019 Posted January 27, 2019 Is posible go to first sensor page? I have install de app, make template in aida64, autopower on and off and autostart prepared. But when remote sensor is opening at start, stuck on logo, always need to slide to see the sensors. Quote
odospace Posted February 2, 2019 Author Posted February 2, 2019 Please set the "Panel Postion" within the Aida 64 OdoSpace settings to 0. It defines the position within the Android App tabs. Quote
HotShot Posted October 20, 2019 Posted October 20, 2019 On 4/10/2018 at 1:32 AM, Overclockeverything said: When my system wakes from sleep odospace dll causes Aida to crash. I am running the latest V1.16 with ADB version 32 and ADIA64 version 5.97.4600. I am connecting via wi/fi to a Polaroid A7. Any help would be greatly appreciated. Everything works and connects automatically when I first boot my PC as well as when I manually restart AIDA after waking from sleep. Expand Is there a solution for this problem? I've got it too. Quelle AIDA64 Extreme Zusammenfassung Nicht mehr funktionsfähig Datum 20.10.2019 03:40 Status Nicht berichtet Beschreibung Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\AIDA64 Extreme\aida64.exe Problemsignatur Problemereignisame: APPCRASH Anwendungsname: aida64.exe Anwendungsversion: 6.10.5200.0 Anwendungszeitstempel: 2a425e19 Fehlermodulname: aidardsp.dll_unloaded Fehlermodulversion: 1.1.0.0 Fehlermodulzeitstempel: 552c0d7f Ausnahmecode: c0000005 Ausnahmeoffset: 0000116b Betriebsystemversion: 10.0.18362.2.0.0.256.48 Gebietsschema-ID: 1031 Zusatzinformation 1: 2beb Zusatzinformation 2: 2beba6fb4680d73a8c78ca7c24ccdb46 Zusatzinformation 3: e912 Zusatzinformation 4: e912ddbe3f2150e5cb48514d40be2fb5 Quote
elliotman38 Posted October 22, 2019 Posted October 22, 2019 I just wanted to drop you a THANK YOU for this post. This is EXACTLY the solution I was looking for. I got my basic design working flawlessly. Now have to try and figure out how to do the fancy stuff. Quote
C0mbat_W0mbat Posted November 3, 2020 Posted November 3, 2020 Hi there thank you for a great tool, however I had it working on my Samsung TAB A, but now all i get is the icon in the middle of the screen, could someone please help. Quote
Fish Posted November 8, 2020 Posted November 8, 2020 Hi, I have a same problem. Whenever I return to my computer, AIDA is off and I have to restart it. Quote
Beans81 Posted November 9, 2020 Posted November 9, 2020 same here, was working fine on my samsung tab A through usb now only works using wifi. Quote
Jack Kolesar Posted November 15, 2020 Posted November 15, 2020 I found a bit of a workaround for the Sleep issue. I DISABLED "Load AIDA64 at Windows startup" and then created a scheduled task to load on "Workstation Unlock". This will make it launch at both startup and when resuming from sleep. If you manually lock and unlock it shouldn't create a new instance but instead launch the main window. I've attached the task XML file below. AIDA64 Unlock Start.xmlFetching info... Quote
Jack Kolesar Posted November 15, 2020 Posted November 15, 2020 Also, here is my current Odospace Export and layout files (GIMP) if anybody wants it. Ryzen_Custom.oslcdFetching info... AIDA_BG_Ryzen.xcfFetching info... 1 Quote
Beans81 Posted November 17, 2020 Posted November 17, 2020 On 11/3/2020 at 5:45 PM, Jonathan Guy Hudson said: Hi there thank you for a great tool, however I had it working on my Samsung TAB A, but now all i get is the icon in the middle of the screen, could someone please help. Expand Hi Jonathan not sure if you say my post, i to have a TAB A doesn't work through usb anymore but i did find a work around, if you go to preferences then scroll down to LCD and select odospace and put your samsung TAB A IP address in assuming its on the same network as your computer it should work, did for me hope this helps. Quote
zzzyz36 Posted December 5, 2020 Posted December 5, 2020 On 11/15/2020 at 3:29 PM, Jack Kolesar said: Also, here is my current Odospace Export and layout files (GIMP) if anybody wants it. Ryzen_Custom.oslcd 265.53 kB · 5 downloads AIDA_BG_Ryzen.xcf 1.85 MB · 3 downloads Expand Thanks for that I customized it and created my own for my Nexus 7. My only issue is that the setup seems to be using about 5% CPU , not sure if going over wifi makes a difference but its a bit high, impacts performance of benchmarks such as cinebench. Some questions. * Does USB use less CPU than Wifi? * Is there anyway to have Odospace/AIDA64 use less than 5% CPU to function? Quote
Fish Posted December 6, 2020 Posted December 6, 2020 @odospace Thanks for the tools. It was really fun to play with during the lockdown. To anyone having issues with 1) Crashing aida after wakeup 2) Tiny Gauges on FullHD phones here are my solutions. Maybe someone will find them useful. 1) I have worked it out the crashy Aida after wakeup. I gave up cable connection, Now im connecting computer and phone via wifi. Set up your router to reserve the IP to the phone so you wont have to change it in the aida setup every single time. No more crashing AIDA. 2) I have also figured out my way how to avoid the struggle with small gauges. Official advice is to download Gauges and manually resize them or draw your own. My solution: Change the screen resolution on the phone. I'm not skilled with photo editing at all, so at first I tried to resize the Gauges in gimp (cause its freeware) and use the custom gauge setup in Aida. However I have encountered weirdness in its behaviour. Sometimes these custom gauges were visible but mostly they were not. Since I didn't have the the rest of the icons (voltage, CPU etc) anyway and huge gauges with tiny little icons were not good for me. I've decided to abandon this route and rather downscale the phone's resolution. I'm using Samsung Galaxy S4 with Full HD display. Since it is already rooted, it was just a breeze. On Playstore look for Resolution chagers. I went with this one https://play.google.com/store/apps/details?id=com.iutilities.screen_resolution This app particulary enables you to set up custom resolution and assing it to apply for specific applications only. In this case for the odospace's Remote Panel. So the phone works normally in FULLHD when Im browsing menus or web but once it detects Remote Panel it downscales the resolution to desired one. Chek out pics how it turned out. Quote
odospace Posted December 7, 2020 Author Posted December 7, 2020 On 12/5/2020 at 10:40 AM, zzzyz36 said: Does USB use less CPU than Wifi? Expand There is no relevant difference. On 12/5/2020 at 10:40 AM, zzzyz36 said: Is there anyway to have Odospace/AIDA64 use less than 5% CPU to function? Expand Try to increase "Update Frequency" for LCD within Aida64 preferences. A question on my own: Does any one knows an android device running without a battery? Quote
odospace Posted December 7, 2020 Author Posted December 7, 2020 On 12/6/2020 at 12:35 PM, Fish said: Crashing aida after wakeup Expand Phuu, working 6 hours on the problem.... Try the beta version http://apps.odospace.com/RemotePanelSetup16a.exe, and please inform me if it works. Question again: Does any one knows an android device running without a battery? Quote
zzzyz36 Posted December 8, 2020 Posted December 8, 2020 On 12/7/2020 at 5:04 PM, odospace said: There is no relevant difference. Expand Ok so USB and Wifi use similar amount of CPU so will stick to wifi. Is it normal for this Odospace/AIDA64 setup to use 5% CPU 24/7 ? Can I uninstall remote panel on the PC so I dont have to manually close it in the system tray each time I start windows? Quote
Jack Kolesar Posted December 8, 2020 Posted December 8, 2020 I just tried 3 times with the Beta and no crashing! Something else is waking my computer now but I think that is unrelated. I'll keep testing and post if I have any other problems. Thanks! Quote
djase Posted December 10, 2020 Posted December 10, 2020 Here is a good way to recycle an old Galaxy Tab 3 7" . A few days ago, I was using Remote System Monitor but the problem is that it's not complete enough with my 5900x and my 3080. I modified a little bit a theme found on a thread and from adapt it to my taste at a resolution of 1024x600 Quote
Andre Vitti Posted December 21, 2020 Posted December 21, 2020 this is awesome!! i have a G19 keyboard which is getting very old and was looking for a replacement (only 2nd hand available, old so probably with issues) - this looks like a great solution - i do have an old phone i can use. i was wondering since it;s a touchscreen, can this also accept a press to open something else? eg. have stats and then a bottom row of icons to load stuff on pc, or get extra system stats. thx Quote
zzzyz36 Posted December 28, 2020 Posted December 28, 2020 On 11/15/2020 at 3:29 PM, Jack Kolesar said: Also, here is my current Odospace Export and layout files (GIMP) if anybody wants it. Expand https://imgur.com/NzEOwgv Finally got a screenshot of my modified version of your layout running on a Nexus 7. Quote
