Note that fan speeds are only shown there when the actual RPM can be measured for the fan. Many fans are implemented in a way that only their fan duty cycle (%) can be detected, but the RPM cannot be measured.
Actually both GPUs fan speeds are correctly shown in the "Sensors" window ("current values in %"), but they are not shown in Stability Test statistics (max, min, average). So it looks like AIDA can correctly measure gpu fan speeds, but just does not have a feature "to show GPU fan statistics".
That's what I meant when I mentioned the difference between fan duty cycle (%) and fan RPM readout. Fan RPMs are shown in the AIDA64 System Stability Test, but fan duty cycles are not. So if your second GPU only provides a fan duty cycle, then it's normal that it will not appear in the System Stability Test Statistics.
