JKDESIGNZ Posted February 3, 2017 Posted February 3, 2017 I think it would be awesome if you could add support for Motion "animated" PNG or Gif files. so we could make custom sensor panel images for fans, temp, ect. Or so we can make custom gauges and bar images that continuously move. even though it supports PNG. it just won't work with the Motion PNG or Gif Files. like this one. 1 Quote
Fiery Posted February 4, 2017 Posted February 4, 2017 In order to enable such a feature, it would be necessary to re-render the SensorPanel 30 or more times a second, which would put quite a load on the system. And certain users already complain about the "high" (2 or 3%) CPU load that the monitoring and SensorPanel rendering layer of AIDA64 puts on the system. So I'm afraid we're not planning to implement the requested feature. Regards, Fiery Quote
FuryXL Posted April 13, 2021 Posted April 13, 2021 (edited) With cpus getting 16 or more core, it should maybe be a feature now, no? Maybe the user could check a mark in config to enable something like this. It's probably one of the last lack of Aida64 imo. Maybe you could propose a tick option, to allow this to be possible warning users that it is more ressource consuming. Would it be possible? Edited April 25, 2021 by FuryXL adding details Quote
Nereus Posted August 21, 2021 Posted August 21, 2021 This the the reason I've used .rslcd instead of .sensorpanel many times - because it supports animated gifs and runs in a browser window. Maybe there is a way to use the custom gauge in sensor panel to simulate animation, but instead of being tied to a sensor, just run it on a timer - at least that would allow a sort of 16-frame animation, albeit a relatively slow and jerky one since the entire panel has to be rendered each time, but at least it's something. Quote
MadMartin Posted August 23, 2022 Posted August 23, 2022 would it not be possible to add this feature and leave it up to the users if they want to use it ...ie put the setting for it under its own settings in the menu 1 Quote
Galactus33 Posted March 21, 2023 Posted March 21, 2023 On 8/23/2022 at 5:50 PM, MadMartin said: would it not be possible to add this feature and leave it up to the users if they want to use it ...ie put the setting for it under its own settings in the menu Expand Agreed. Can't fathom why this would not be a thing in 2023. At least give us the choice, right? 1 Quote
ZERBERUS80 Posted April 3, 2023 Posted April 3, 2023 Auch ich finde, dass es noch auch für den relativ hohen Lizenzpreis die Möglichkeit geben sollte animierte PNG oder GIFs zu implementieren. Haben Sie sowas nun in den aktuellen Releases eingeplant? Quote
ThomasK Posted July 10, 2023 Posted July 10, 2023 On 2/4/2017 at 10:50 AM, Fiery said: In order to enable such a feature, it would be necessary to re-render the SensorPanel 30 or more times a second, which would put quite a load on the system. And certain users already complain about the "high" (2 or 3%) CPU load that the monitoring and SensorPanel rendering layer of AIDA64 puts on the system. So I'm afraid we're not planning to implement the requested feature. Regards, Fiery Expand Couldn’t it just be a feature you enable in preferences for those that really want to use that 2-5% processing power? sure it’d be a cool feature to have… but I’m not married to it either way. 1 Quote
