On ‎11‎/‎10‎/‎2018 at 11:02 AM, KallAdam said:
Hey AIDA64 Team,
do you have any Timeline to integrate the Water_IN_Temperatur & Water_OUT_Temperatur for the new Z390 ROG MAXIMUS XI HERO (WI-FI) ???
Thank you!
We've added those temperature readings in the latest AIDA64 beta update available at:
Let me know how it works ;)
Hey @Fiery , thanks for your Answer.
I have tested the new Beta, but I can not see the 2 Sensors.
In Asus Suite 3 and Uefi Bios I can see the 2 temperatures.
Water In T Sensor & Water out T Sensor  hopefully with next Beta !!!
Please submit a screen shot of the Computer / Sensor page of AIDA64, with the full list of thermal readings.
57 minutes ago, KallAdam said:
ok I have found it ... i have to activate Settings / stability lot of Sensor support
Now it works !!!!
Thanks for you help
Yes, I'm sorry, I forgot to mention that you need to have the following 2 options enabled in Stability:
Embedded Controller (EC) support
Embedded Controller (EC) bank switching
The rest of the options that you've activated can be disabled :)
