AIDA64 Discussion Forum
Maident
Motherboard Fan Headers
My motherboard has 6 fan headers and a CPU_OPT header.  AIDA64 reports 7 system fans (1 thru 7).  The CPU fan in AIDA64 is obviously the CPU_FAN header.  Similarly with the other AIDA64 system fan designations.  Can anyone confirm that the System #7 fan is actually the CPU_OPT header?
Share this post
Link to post
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Share this post
Link to post
On 12/27/2018 at 7:24 PM, fads said:
What is the name of your motherboard? Why don't you connect a fan to the CPU_OPT header and see?
Aorus z390 Master.  I use the CPU_OPT for the AIO cooler pump.  I have it set to run 100% all the time.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Similar Content
    • By Maident
      While observing the System Stability Test, Statistics tab, I thought it would be nice if we could rename the Chassis fans to match their actual location.  This would make it easier to follow what each of the fans were up to.  This could be something added to preferences. i.e., rename cooling fans.
    • By StackOverflow13
      MB= Asus Maximus V Extreme
      Bios Version 1501: OS= Win8 x64. Chasis fans are showing fine but OPT fans 1 & 2 Missing OPT Fan 3 is showing.
    • By ded32
      Hello,
      I noticed that on Asus Rampage IV Extreme, AIDA64 sometimes outputs "Thread creation error: Insufficient memory for this operation" and after that readings of OPT1, OPT3, Case 2 and PCH fans become 0.0 RPM (I have OPT2, Case 1 and Case 2 fans unconnected so cannot say anything about them). CPU fan and CPU OPT fan readings are still OK.
      If I relaunch AIDA64 (File - Exit - Run again), readings become OK, and sometimes later the problem repeats.
      I have to confess that I have ASUS Suite II installed (because and only because AIDA64 missed OPTx temp support on Asus R4E!). After installation of AIDA64 Beta, I stopped running it, but process explorer shows its modules loaded and running (FanControlHelper.exe etc). So this may be result of interaction of AIDA64 and ASUS' DLLs (http://forums.aida64...ndpost__p__5532). It's not a problem for me, I plan to uninstall ASUS software. Just leaving it now only to help you in testing
      AIDA64 version: 2.50.2075 Beta.
      P.S. Fiery, thanks a lot for your great work - from another R4E user
      Never remove R4E support from AIDA64! BTW, you already have Option/Stability settings, you may add Asus Suite II compatibility there...
    • By ajtk
      Hello everyone. I'm Cristian and I from Chile, for that... sorry for my bad english ahaha.
      I've a question. I've a sony vaio laptor with a GPU: Nvidida 410m. Versión Intel® Core i5-2410M CPU @ 2.30GHz.
      Do you know what is the correct temperature of the cores and the GPU of my laptop? when I play, it's feel so hot and I don't know the correct temperatures...
      If the informations is not enough, ask me in the comments and I will put a complete report from Aida64.
      Aprecciate the help!
      Grettings, and thanks.
