Hello,whenever I'm trying to run System Stability Test on Aida64 extreme and I check the "Stress GPU(s)" checkbox,the system crashes and I have to reboot my pc.Do you have any idea why? (when I run SST's with only GPU's box unchecked,it runs smoothly)
Also I'm trying to save the data from System Stability Test into a file (for instance .txt) but "Save" button only gives me a PNG image.Any ideas?
Thank you for your time!
1) The GPU stress test relies on the OpenCL subsystem that seems to be broken on your system.  Try to uninstall your video driver and install the latest WHQL one to fix that up.
2) Saving the stress test history or statistics to text file is not supported.  You can however use the Logging facility to save your selection of sensor readings into a CSV or HTML file.  Go to AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging to configure that feature.
