cyperous Posted May 30, 2019 Posted May 30, 2019 When I go to setup the Remote sensor panel and setup LCD items the window on the view is empty and nothing is displayed. I'm on Windows 10 May Update on the latest Aida64. I even tried using the latest beta with no luck. Here is a screenshot. This is happening on two different systems. One is an older machine with Intel 6700K the other is new with an Intel 8700K so I don't think it's hardware related. They even have different motherboards. Infact both these system used to have this working previously but I wiped both of them and did a fresh install of Windows 10 May. Quote
Fiery Posted June 18, 2019 Posted June 18, 2019 On 5/30/2019 at 7:14 PM, cyperous said: When I go to setup the Remote sensor panel and setup LCD items the window on the view is empty and nothing is displayed. I'm on Windows 10 May Update on the latest Aida64. I even tried using the latest beta with no luck. Here is a screenshot. This is happening on two different systems. One is an older machine with Intel 6700K the other is new with an Intel 8700K so I don't think it's hardware related. They even have different motherboards. Infact both these system used to have this working previously but I wiped both of them and did a fresh install of Windows 10 May. Please post a screenshot of the Preferences / Hardware Monitoring / LCD page as well, so we can see which LCD device you've enabled and what your settings for that device are. Thanks, Fiery Quote
elior77 Posted January 20, 2021 Posted January 20, 2021 Same here on two systems - any update ? Quote
Melenxxio Posted February 10, 2023 Posted February 10, 2023 any update on this? i am having the same problem on AX206 LCD I have enabled it under lcd but not being detected Quote
