Ben10lightnin Posted November 19, 2020 Posted November 19, 2020 I have set all of my custom gauge states but the gauges just randomly disappear on my sensor panel leaving only the number, is there a fix to this? Quote
Fiery Posted November 24, 2020 Posted November 24, 2020 On 11/19/2020 at 11:36 PM, Ben10lightnin said: I have set all of my custom gauge states but the gauges just randomly disappear on my sensor panel leaving only the number, is there a fix to this? Where do you store the custom gauge images? On a local hard drive or SSD? Do you have all states defined? Quote
Ben10lightnin Posted November 26, 2020 Author Posted November 26, 2020 On 11/24/2020 at 5:36 AM, Fiery said: Where do you store the custom gauge images? On a local hard drive or SSD? Do you have all states defined? I have them stored on a local ssd and the stages are all defined, it seems to be happening less now but still happens sometimes Quote
Fiery Posted December 2, 2020 Posted December 2, 2020 On 11/26/2020 at 10:03 PM, Ben10lightnin said: I have them stored on a local ssd and the stages are all defined, it seems to be happening less now but still happens sometimes I've sent you a private message about this. Quote
Fiery Posted January 6, 2021 Posted January 6, 2021 On 11/26/2020 at 10:03 PM, Ben10lightnin said: I have them stored on a local ssd and the stages are all defined, it seems to be happening less now but still happens sometimes Please check the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
Vernon Posted January 13, 2021 Posted January 13, 2021 I am having this same problem even after updating to the latest beta. Is there a fix for this issue? Quote
Fiery Posted January 13, 2021 Posted January 13, 2021 1 hour ago, Vernon said: I am having this same problem even after updating to the latest beta. Is there a fix for this issue? Right now, no We've run out of ideas about this right now. Quote
Vernon Posted January 26, 2021 Posted January 26, 2021 This solution I found in another thread related to images disappearing also solved my problem with the custom gauges. The solution I found is to make the .PNG files that you use for each state on the gauge as small as possible by removing as much metadata as possible. Hope this helps someone out! Quote
Elude Posted February 7, 2021 Posted February 7, 2021 I was able to fix this issue by removing the meta data from the png files with gimp. I did not adjust the image size (150x150). Thank you!!! Quote
carluccifamily Posted February 14, 2021 Posted February 14, 2021 having same issues, will try this see if it works. Quote
carluccifamily Posted February 14, 2021 Posted February 14, 2021 worked, images cant have meta data at all...wonder why ? Quote
Fiery Posted March 12, 2021 Posted March 12, 2021 On 2/14/2021 at 6:44 AM, carluccifamily said: worked, images cant have meta data at all...wonder why ? The issue is caused by the embedded thumbnail data of PNG files. If you remove that from the PNG file, it works fine with AIDA64. We're working on a bug fix about decoding PNG images in AIDA64. Quote
Fiery Posted March 12, 2021 Posted March 12, 2021 On 2/14/2021 at 6:44 AM, carluccifamily said: worked, images cant have meta data at all...wonder why ? Here's the fix for the PNG loading issues: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let us know how it works with your PNG images. Quote
Folklore Posted October 27, 2021 Posted October 27, 2021 I'm have this same problem with newest version of Aida64 Extreme. As of this date Quote
Folklore Posted October 27, 2021 Posted October 27, 2021 LoL never mind, I discovered that I must use all 15 states of gauges. Now it works fine! Quote
