go4i Posted February 29, 2012 Posted February 29, 2012 Hi, I decide to try Aida64 2.20.1800 and overall I am happy but I have latency problem with aida64 software when is running. That's in the moment when I am checking for the temperature in the system cpu,gpu.... aida64-->computer-->sensor. I am providing you a picture for the issue. Regards Quote
Fiery Posted February 29, 2012 Posted February 29, 2012 First of all, please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1834ws9p7dqgnzzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Then, using the new beta, please copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic. Thanks, Fiery Quote
go4i Posted February 29, 2012 Author Posted February 29, 2012 I have the some problem and with this version of the software. Quote
Fiery Posted March 3, 2012 Posted March 3, 2012 Both of you, please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.co...39s1y6ftjhwkzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Then start it, go to the Sensor page, and check if it has the same latency issues. If it still has, then right-click on the bottom status bar of AIDA64 main window --> HWMon Modules --> UPS. This will effectively disable UPS monitoring, so the relevant items (e.g. Battery Voltage) should then disappear from the Sensor page. Let me know if it fixes the latency issues or not. If you have time and like to test things out, you can try to disable other HWMon modules as well, one by one, to see which ones makes an impact on the latency. Let me know how it goes. Thanks, Fiery Quote
go4i Posted March 4, 2012 Author Posted March 4, 2012 With this new beta I didn't resolve my latency problem. The next suggestion - HWMon and disabling diffrent devices. In my case... I don't have latency problem when I disable the GPU Module, which is NVIDIA GT555 with the latest drivers. Quote
Fiery Posted March 5, 2012 Posted March 5, 2012 With this new beta I didn't resolve my latency problem. The next suggestion - HWMon and disabling diffrent devices. In my case... I don't have latency problem when I disable the GPU Module, which is NVIDIA GT555 with the latest drivers. Thank you for the feedback. Just disabling the UPS module didn't solve the latency issues, did it? Quote
go4i Posted March 5, 2012 Author Posted March 5, 2012 If I disable the GPU module in the HWMon I don't have latency problem. Quote
Fiery Posted March 5, 2012 Posted March 5, 2012 If I disable the GPU module in the HWMon I don't have latency problem. If you have the GPU module enabled, but the UPS module disabled, then do you get latency issues? Quote
go4i Posted March 6, 2012 Author Posted March 6, 2012 I am confuse. How I can do that? All the Aida64 settings are by default. I'd make only one change in this settings, which you can see from the following picture. In this case I don't have latency problem. Quote
Fiery Posted March 6, 2012 Posted March 6, 2012 I am confuse. How I can do that? All the Aida64 settings are by default. I'd make only one change in this settings, which you can see from the following picture. In this case I don't have latency problem. It means you haven't upgraded to the latest AIDA64 beta available at: http://www.aida64.co...39s1y6ftjhwkzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. With that beta a new UPS entry should be available among the HWMon Modules. Quote
go4i Posted March 6, 2012 Author Posted March 6, 2012 I'm appologise, it's my mistake. Now I'd instaled and reboted windows with the latest version but in my case is doesn't matter if the UPS is enable/disable because in boot of the cases I Ihave latency problem, which you can see from the following picture. Again I don't have latency problem when the GPU module is disable and in this version. Quote
Fiery Posted March 9, 2012 Posted March 9, 2012 Please post a screen shot that shows all settings of the Stability page (AIDA64 / main menu / File / Preferences / Stability). Also, right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic. Finally, right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic. Thank you for your time. Quote
go4i Posted March 11, 2012 Author Posted March 11, 2012 nVIDIA GPU Registers ------[ AIDA64 v2.20.1847 Beta ]------ ------[ Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 (64-bit) ]------ ------[ Video Adapters ]------ Intel Sandy Bridge-MB - Integrated Graphics Controller (MB GT2) [8086-0116 / 1028-0491] ------[ Video Driver ]------ nvapi.dll: 8.17.12.8562 igdumd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igdumdx32||8.15.10.2342|||igd10umd32||8.15.10.2342|||igd10umd32||8.15.10.2342 igdumd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igdumdx32||8.15.10.2342|||igd10umd32||8.15.10.2342|||igd10umd32||8.15.10.2342 nvd3dumx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvd3dum||8.17.12.8562 - nVIDIA ForceWare 285.62|||nvwgf2um||8.17.12.8562|||nvwgf2um||8.17.12.8562 nvd3dumx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvd3dum||8.17.12.8562 - nVIDIA ForceWare 285.62|||nvwgf2um||8.17.12.8562|||nvwgf2um||8.17.12.8562 ------[ NVAPI GPU Handles ]------ GPU Count = 1 GPU #1 = BB000100 ------[ nVIDIA GPU #1 / Thermal Settings ]------ Sensor Count = 1 Sensor #0 / Controller = GPU Internal Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 35 Celsius nVIDIA SMBus Dump ------[ AIDA64 v2.20.1847 Beta ]------ ------[ Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 (64-bit) ]------ ------[ Video Adapters ]------ Intel Sandy Bridge-MB - Integrated Graphics Controller (MB GT2) [8086-0116 / 1028-0491] ------[ Video Driver ]------ nvapi.dll: 8.17.12.8562 igdumd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igdumdx32||8.15.10.2342|||igd10umd32||8.15.10.2342|||igd10umd32||8.15.10.2342 igdumd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igd10umd64||8.15.10.2342|||igdumdx32||8.15.10.2342|||igd10umd32||8.15.10.2342|||igd10umd32||8.15.10.2342 nvd3dumx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvd3dum||8.17.12.8562 - nVIDIA ForceWare 285.62|||nvwgf2um||8.17.12.8562|||nvwgf2um||8.17.12.8562 nvd3dumx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvwgf2umx||8.17.12.8562|||nvd3dum||8.17.12.8562 - nVIDIA ForceWare 285.62|||nvwgf2um||8.17.12.8562|||nvwgf2um||8.17.12.8562 Total : 0.0 sec Quote
Fiery Posted March 15, 2012 Posted March 15, 2012 Thank you. It seems AIDA64 uses nVIDIA ForceWare driver calls via the standard NVAPI interface to measure GPU sensor values. If that causes latency issues on your system, then I'm afraid it's the fault of the ForceWare driver Quote
