Fiery Posted March 30, 2016 Author Posted March 30, 2016 Thank you. It looks OK, the USB ID and HID parameters match the ones expected by AIDA64. Have you tried it after closing CUE? Quote
dragonjah Posted March 30, 2016 Posted March 30, 2016 Thanks, yes i closed CUE and the same... Maybe i have to reinstall Aida64? Quote
dragonjah Posted March 30, 2016 Posted March 30, 2016 Is there something to enable or disable expect to the v for rgb led support? Quote
dragonjah Posted March 30, 2016 Posted March 30, 2016 When rgb is activated and i type on my strafe, there is some "flash" of random colors, but not regular... Quote
Fiery Posted March 30, 2016 Author Posted March 30, 2016 When rgb is activated and i type on my strafe, there is some "flash" of random colors, but not regular... I think we've found the issue in the RGB LED module of AIDA64. We will fix it up in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta is available for download. Quote
Fiery Posted April 1, 2016 Author Posted April 1, 2016 The mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta Let me know how it works Quote
dragonjah Posted April 1, 2016 Posted April 1, 2016 It works! thanks a lot! Â There is just one issue, if i choose "row of keys" "0-9" or "1-0", always "1-0" keys light up. Never "0-9". Quote
Fiery Posted April 13, 2016 Author Posted April 13, 2016 It works! thanks a lot! Thank you for the feedback  There is just one issue, if i choose "row of keys" "0-9" or "1-0", always "1-0" keys light up. Never "0-9". Supporting non-US keyboard layouts about RGB LED is unfortunately a big challenge, regardless of the keyboard manufacturer in question. I think the ultimate solution will be to offer custom key list building, so you can specify exactly what keys do you want to be lit as a row. And i have to stop Corsair Utility Engine That's true. Corsair hasn't yet come up with a proper SDK for its RGB LED products, so we have to talk to the device directly. That will then collide with CUE. The ultimate solution for this issue will be when Corsair introduced a RGB LED SDK with proper synchronization and device sharing across multiple applications. Quote
snoker Posted May 14, 2016 Posted May 14, 2016 Hello, I have a Corsair K70 and I've been trying for hours to set up a temperature monitor to change the color of the keys. Â No luck. Â I read this thread and downloaded 5.70.3843 Beta. Â I also exited CUE. Â No luck. Â I'll attach my USB dump here. Â Please let me know if my keyboard is supported and if so, what I need to do to get this working. Thanks! usbdump.txt Quote
Fiery Posted May 16, 2016 Author Posted May 16, 2016 Is this an old variant of the K70 or a recent one? Do you perhaps know the hardware revision of the keyboard? Quote
snoker Posted May 16, 2016 Posted May 16, 2016 It's a very new keyboard - just got it. Â Here's what I see on the bottom: Â K70 RGB Mechanical Gaming Keyboard. Â M/N: RGP004 P/N: CH-9000119-NA S/N: 189316148427. Â I hope that what you need is in there somewhere. Quote
Fiery Posted May 17, 2016 Author Posted May 17, 2016 Thank you for the info. Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it still cannot find your keyboard, then please post a new USB Dump. We've added a few more details to that dump to help investigate this issue. Thanks, Fiery Quote
snoker Posted May 18, 2016 Posted May 18, 2016 Thank you for the quick response. Â I upgraded to the latest beta and restarted Windows. Â Still no luck. Â I am posting a new usb dump. Â For this dump, I had the keyboard plugged directly into a USB port on the PC and not through a hub as I had when I did the last dump. Â Thanks for taking a look. usbdump.txt Quote
jjxaker Posted May 19, 2016 Posted May 19, 2016 Please add support G.SKILL RIPJAWS KM780 RGBÂ Â usbdump.txt Quote
Fiery Posted May 19, 2016 Author Posted May 19, 2016 Please add support G.SKILL RIPJAWS KM780 RGB Do you have a SDK for the keyboard, or any other technical details on how to talk to the keyboard? Here they didn't seem to find one, but maybe things have changed since then: https://github.com/SpoinkyNL/Artemis/issues/55 Quote
Fiery Posted May 19, 2016 Author Posted May 19, 2016 Thank you for the quick response. Â I upgraded to the latest beta and restarted Windows. Â Still no luck. Â I am posting a new usb dump. Â For this dump, I had the keyboard plugged directly into a USB port on the PC and not through a hub as I had when I did the last dump. Â Thanks for taking a look. Thank you for the updated dump. We'll do some further improvements in the next AIDA64 beta update. I'll post a download link for the new beta update into this topic soon. Quote
jjxaker Posted May 19, 2016 Posted May 19, 2016 Do you have a SDK for the keyboard, or any other technical details on how to talk to the keyboard? Unfortunately not, and did not find it.((( Technical support, says nothing about this. Quote
Fiery Posted May 23, 2016 Author Posted May 23, 2016 Thank you for the quick response. Â I upgraded to the latest beta and restarted Windows. Â Still no luck. Â I am posting a new usb dump. Â For this dump, I had the keyboard plugged directly into a USB port on the PC and not through a hub as I had when I did the last dump. Â Thanks for taking a look. Please try it with the latest AIDA64 beta available at: http://www.aida64.com/downloads/latesta64xebeta Let me know if it helps Quote
snoker Posted May 23, 2016 Posted May 23, 2016 That did the trick for me! Â Thanks for the quick support. Quote
Fiery Posted May 23, 2016 Author Posted May 23, 2016 That did the trick for me! Â Thanks for the quick support. That's great news, thank you for your feedback! Quote
snoker Posted May 24, 2016 Posted May 24, 2016 OK, maybe I spoke to soon. Â It works perfectly if I choose "All Keys" or "Single Key" as the item type. Â But if I choose "Row of Keys", I get various results. Â For function keys, only F1 thru F7 light up. Â For Numbers (1-0) or, 1-5 light up. Â For numbers (0-9) the 0 and 1-4 light up. Â For QWERTYUIOP, only QWERTY light up. Â (For the rest of the rows, only the leftmost five or six light up). Â But at least I can see it's working, and for now I'm using "all keys." Â Thanks again. Quote
Fiery Posted May 25, 2016 Author Posted May 25, 2016 OK, maybe I spoke to soon. Â It works perfectly if I choose "All Keys" or "Single Key" as the item type. Â But if I choose "Row of Keys", I get various results. Â For function keys, only F1 thru F7 light up. Â For Numbers (1-0) or, 1-5 light up. Â For numbers (0-9) the 0 and 1-4 light up. Â For QWERTYUIOP, only QWERTY light up. Â (For the rest of the rows, only the leftmost five or six light up). Â But at least I can see it's working, and for now I'm using "all keys." Â Thanks again. We've contacted Corsair to ask for their assistance on this issue. I'll let you know in this topic once we have an update to this issue Quote
snoker Posted May 27, 2016 Posted May 27, 2016 Thanks for all the help with my K70. Â I'm enjoying the RGB keyboard enough that I just added a Razer Chroma RGB wireless mouse. Â I was hoping I could have AIDA64 show colors on the keyboard for one measurement and colors on the mouse for another. Â I haven't been able to get the mouse to respond to AIDA64 at all. Â Is my mouse supported? Â I'll attach another usbdump file. Â I appreciate all the support. Â usbdump.txt Quote
