tistou77 Posted November 23, 2019 Posted November 23, 2019 It is possible, with other monitoring software, it works very well It may be best to include a function to choose the desired formula, if you think the formulas may be different And if in this function, we could choose to indicate or not the probes, available in other software too Thanks Quote
tistou77 Posted November 25, 2019 Posted November 25, 2019 up Formula seems the same for all (rpm = *60/1000 for LPH) Quote
tistou77 Posted December 8, 2019 Posted December 8, 2019 Too bad, it must not be possible to put this kind of thing with Aida64 Quote
Fiery Posted December 14, 2019 Posted December 14, 2019 On 12/8/2019 at 5:43 PM, tistou77 said: Too bad, it must not be possible to put this kind of thing with Aida64 We've come up with an idea about that. It will be implemented in the next AIDA64 beta update. I will post a message into this topic once the new beta becomes available for download. Quote
tistou77 Posted December 14, 2019 Posted December 14, 2019 Just now, Fiery said: We've come up with an idea about that. It will be implemented in the next AIDA64 beta update. I will post a message into this topic once the new beta becomes available for download. Ahhh good news, thanks so much Quote
Fiery Posted December 15, 2019 Posted December 15, 2019 19 hours ago, tistou77 said: Ahhh good news, thanks so much Here's the above mentioned new AIDA64 beta build where we've added the same flow rate reading to the list of flow rates as well as keeping the original value reported in RPM. https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. Quote
tistou77 Posted December 15, 2019 Posted December 15, 2019 3 minutes ago, Fiery said: Here's the above mentioned new AIDA64 beta build where we've added the same flow rate reading to the list of flow rates as well as keeping the original value reported in RPM. https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. Thank you so much Where is the option to change the RPM to L/H ? Quote
Fiery Posted December 15, 2019 Posted December 15, 2019 2 minutes ago, tistou77 said: Thank you so much Where is the option to change the RPM to L/H ? No option is necessary, since both the RPM and LPH values are listed now (only for your motherboard). Quote
tistou77 Posted December 15, 2019 Posted December 15, 2019 Just now, Fiery said: No option is necessary, since both the RPM and LPH values are listed now (only for your motherboard). I still have RPMs Quote
Fiery Posted December 15, 2019 Posted December 15, 2019 13 minutes ago, tistou77 said: I still have RPMs Check the flow rates near the bottom of the Computer / Sensor page as well. Quote
tistou77 Posted December 15, 2019 Posted December 15, 2019 4 minutes ago, Fiery said: Check the flow rates near the bottom of the Computer / Sensor page as well. I did not understand. I just have 1 Flow rate in Computer / Sensor and it is always indicated in RPM Thanks Quote
Fiery Posted December 15, 2019 Posted December 15, 2019 4 minutes ago, tistou77 said: I did not understand. I just have 1 Flow rate in Computer / Sensor and it is always indicated in RPM Thanks Please copy-paste the full content of the Computer / Sensor page into this topic, as well as post an ISA Sensor Dump. Quote
tistou77 Posted December 15, 2019 Posted December 15, 2019 Field Value Sensor Properties Sensor Type Nuvoton NCT6796D (ISA A00h) GPU Sensor Type Diode (NV-Diode) Motherboard Name Asus ROG Rampage VI Extreme Chassis Intrusion Detected No Temperatures Motherboard 30 °C CPU 29 °C CPU Package 30 °C CPU #1 / Core #1 25 °C CPU #1 / Core #2 21 °C CPU #1 / Core #3 21 °C CPU #1 / Core #4 21 °C CPU #1 / Core #5 23 °C CPU #1 / Core #6 22 °C CPU #1 / Core #7 19 °C CPU #1 / Core #8 21 °C CPU #1 / Core #9 24 °C CPU #1 / Core #10 23 °C CPU #1 / Core #11 20 °C CPU #1 / Core #12 22 °C CPU #1 / Core #13 21 °C CPU #1 / Core #14 22 °C CPU #1 / Core #15 22 °C CPU #1 / Core #16 20 °C CPU #1 / Core #17 20 °C CPU #1 / Core #18 23 °C PCH 49 °C PCH Diode 50 °C Eau 25 °C VRM 30 °C GPU 2080ti 26 °C DIMM-A1 32 °C DIMM-B1 35 °C DIMM-C1 35 °C DIMM-D1 35 °C Samsung 970 EVO Plus 1To 39 °C / 38 °C Intel Optane 905P 380Go 40 °C Cooling Fans Optane 905P 2947 RPM Water Pump #1 3857 RPM Water Pump #2 3857 RPM Water Flow 2763 RPM Voltage Values CPU Core 0.685 V CPU VID 0.681 V +3.3 V 3.392 V +5 V 5.120 V +12 V 12.384 V +3.3 V Standby 3.392 V VBAT Battery 3.200 V DIMM AB 1.376 V DIMM CD 1.376 V PCH Core 1.032 V CPU Cache 1.034 V VCCIN 1.888 V VCCIO 1.040 V VCCSA 0.832 V GPU Core 0.725 V Current Values CPU 17.00 A Power Values CPU 11.65 W CPU Package 1.16 W GPU TDP% 0% And the files : isasensordump.txt Quote
Fiery Posted December 15, 2019 Posted December 15, 2019 4 minutes ago, tistou77 said: Field Value Sensor Properties Sensor Type Nuvoton NCT6796D (ISA A00h) GPU Sensor Type Diode (NV-Diode) Motherboard Name Asus ROG Rampage VI Extreme Chassis Intrusion Detected No Temperatures Motherboard 30 °C CPU 29 °C CPU Package 30 °C CPU #1 / Core #1 25 °C CPU #1 / Core #2 21 °C CPU #1 / Core #3 21 °C CPU #1 / Core #4 21 °C CPU #1 / Core #5 23 °C CPU #1 / Core #6 22 °C CPU #1 / Core #7 19 °C CPU #1 / Core #8 21 °C CPU #1 / Core #9 24 °C CPU #1 / Core #10 23 °C CPU #1 / Core #11 20 °C CPU #1 / Core #12 22 °C CPU #1 / Core #13 21 °C CPU #1 / Core #14 22 °C CPU #1 / Core #15 22 °C CPU #1 / Core #16 20 °C CPU #1 / Core #17 20 °C CPU #1 / Core #18 23 °C PCH 49 °C PCH Diode 50 °C Eau 25 °C VRM 30 °C GPU 2080ti 26 °C DIMM-A1 32 °C DIMM-B1 35 °C DIMM-C1 35 °C DIMM-D1 35 °C Samsung 970 EVO Plus 1To 39 °C / 38 °C Intel Optane 905P 380Go 40 °C Cooling Fans Optane 905P 2947 RPM Water Pump #1 3857 RPM Water Pump #2 3857 RPM Water Flow 2763 RPM Voltage Values CPU Core 0.685 V CPU VID 0.681 V +3.3 V 3.392 V +5 V 5.120 V +12 V 12.384 V +3.3 V Standby 3.392 V VBAT Battery 3.200 V DIMM AB 1.376 V DIMM CD 1.376 V PCH Core 1.032 V CPU Cache 1.034 V VCCIN 1.888 V VCCIO 1.040 V VCCSA 0.832 V GPU Core 0.725 V Current Values CPU 17.00 A Power Values CPU 11.65 W CPU Package 1.16 W GPU TDP% 0% And the files : isasensordump.txt Thank you. The problem is that we've only unlocked the new feature for Asus ROG Maximus IX/X Code / Formula / Hero, and not for ROG Rampage VI Series. We'll add it for your motherboard too, and I will send you a private message about further to-do's. Quote
tistou77 Posted December 15, 2019 Posted December 15, 2019 Just now, Fiery said: Thank you. The problem is that we've only unlocked the new feature for Asus ROG Maximus IX/X Code / Formula / Hero, and not for ROG Rampage VI Series. We'll add it for your motherboard too, and I will send you a private message about further to-do's. Aa ok, thanks Quote
tistou77 Posted January 8, 2020 Posted January 8, 2020 Hello With the last beta, the value of Flow Meter is not good (x20 too high) for Rampage VI Extreme Indicated 4100 LPH while the pump is only 1500 LPH (and the good value is around 150 LPH) Aida64 : SIV : As indicated by PM, if it's to leave as is, don't bother adding it This value is duplicates that indicated in Cooling Fan and is not User Friendly at all, compared to SIV for example (where it doesn't bother anyone to have RPM and LPH "together") Thanks Quote
Fiery Posted January 14, 2020 Posted January 14, 2020 On 1/8/2020 at 7:01 PM, tistou77 said: Hello With the last beta, the value of Flow Meter is not good (x20 too high) for Rampage VI Extreme Indicated 4100 LPH while the pump is only 1500 LPH (and the good value is around 150 LPH) Aida64 : SIV : As indicated by PM, if it's to leave as is, don't bother adding it This value is duplicates that indicated in Cooling Fan and is not User Friendly at all, compared to SIV for example (where it doesn't bother anyone to have RPM and LPH "together") Thanks I'm afraid I'm more confused about all that than ever before. If it's possible, please send me an email about this issue. I think you must have my email address from previous correspondance. But if not, just drop me a private message and we'll go from there. Quote
tistou77 Posted January 14, 2020 Posted January 14, 2020 3 hours ago, Fiery said: I'm afraid I'm more confused about all that than ever before. If it's possible, please send me an email about this issue. I think you must have my email address from previous correspondance. But if not, just drop me a private message and we'll go from there. PM sent Quote
Fiery Posted January 14, 2020 Posted January 14, 2020 9 minutes ago, tistou77 said: PM sent Thx Quote
Neomail Posted April 20, 2022 Posted April 20, 2022 (edited) Hello, i have an Asus ROG Maximus X Hero and i can't see those flow metter in AIda64 I have one connected and it show in bios but not available in Aida64 , someone can help ? Edit : Finaly i enabled ECC and it show now but only RPM :/ Edit 2 : i found it ... now everything is ok :p Edited April 21, 2022 by Neomail RESOLVED Quote
Neomail Posted October 5, 2022 Posted October 5, 2022 On 4/21/2022 at 12:30 AM, Neomail said: Hello, i have an Asus ROG Maximus X Hero and i can't see those flow metter in AIda64 I have one connected and it show in bios but not available in Aida64 , someone can help ? Edit : Finaly i enabled ECC and it show now but only RPM :/ Edit 2 : i found it ... now everything is ok :p Hello it finaly disapear after the last update (the flow metter ) is it normal ? Quote
