Jess Posted November 7, 2020 Posted November 7, 2020 So I saw jay2cents video about adding a lcd and I was like damn I want this. Ordered the parts and then Downloaded aida64. Everything was going fine until I heard the disconnect and connecting of the usb. Then when that was happening my aio rgb and the fans from the aio rgb would turn on and off. I was like maybe an update or something. Was playing around with lcd sensor to drag it to my lcd screen so I can see temps and stuff. Then I went to play a game and noticed I was laggy and that never happens . Then I noticed my rgb from aio (Corsair plat aio) was stuck on a color and the rgb fans are completely off. Kept happening so I gutted my pc made sure everything was plugged in right and booted up again it worked fine until I loaded aida64. Not sure if this happened to anyone but if it did please help lol. My system was working perfectly fine before I installed this and I uninstalled it and it back to normal but if I could find a fix I would def try if not I’m probably going to try and get my money back from aida64. 1 Quote
ProbablyAlex Posted November 15, 2020 Posted November 15, 2020 I'm in the same boat, came from Jayz2Cents video, and my Corsair AIO is constantly disconnecting/reconnecting while Aida64 is running with the overlay. It seems the issue is a conflicting sensor, and I found out you can turn it off in preferences. File > Preferences > Stability > 'Corsair Hydro Platinum sensor support' After I unchecked that, I haven't had another disconnect after ~20 minutes, so it seems to be working. Hope this helps! FWIW, I was having issues with the Corsair H100i RGB Platinum 1 Quote
Fiery Posted November 17, 2020 Posted November 17, 2020 On 11/7/2020 at 7:30 AM, Jess said: So I saw jay2cents video about adding a lcd and I was like damn I want this. Ordered the parts and then Downloaded aida64. Everything was going fine until I heard the disconnect and connecting of the usb. Then when that was happening my aio rgb and the fans from the aio rgb would turn on and off. I was like maybe an update or something. Was playing around with lcd sensor to drag it to my lcd screen so I can see temps and stuff. Then I went to play a game and noticed I was laggy and that never happens . Then I noticed my rgb from aio (Corsair plat aio) was stuck on a color and the rgb fans are completely off. Kept happening so I gutted my pc made sure everything was plugged in right and booted up again it worked fine until I loaded aida64. Not sure if this happened to anyone but if it did please help lol. My system was working perfectly fine before I installed this and I uninstalled it and it back to normal but if I could find a fix I would def try if not I’m probably going to try and get my money back from aida64. Expand Both of you, please let us know exactly what model of Corsair AIO cooler do you have. Thanks, Fiery Quote
ProbablyAlex Posted January 23, 2021 Posted January 23, 2021 On 11/17/2020 at 1:58 PM, Fiery said: Both of you, please let us know exactly what model of Corsair AIO cooler do you have. Thanks, Fiery Expand Link to the exact cooler I was using Quote
Fiery Posted January 28, 2021 Posted January 28, 2021 On 1/23/2021 at 5:35 PM, ProbablyAlex said: Link to the exact cooler I was using Expand Thank you, we're investigating this issue. If you still experience issues while using AIDA64, as a temporary workaround you can disable monitoring of your AIO by unchecking (disabling) the option: AIDA64 / main menu / File / Preferences / Stability / Corsair Hydro Platinum sensor support. Quote
Enzaki Posted April 8, 2021 Posted April 8, 2021 i have that problem too i have Corsair Hydro Series H115i RGB Platinum disconnecting/reconnecting Quote
Mice007 Posted April 11, 2021 Posted April 11, 2021 On 4/8/2021 at 7:00 AM, Enzaki said: i have that problem too i have Corsair Hydro Series H115i RGB Platinum disconnecting/reconnecting Expand Which AIDA64 version are you using? Quote
Enzaki Posted April 12, 2021 Posted April 12, 2021 On 4/11/2021 at 10:35 PM, Mice007 said: Which AIDA64 version are you using? Expand 6.33.5700 Quote
w4r10ck Posted May 6, 2021 Posted May 6, 2021 i have that same problem with the same version of AIDA64 Quote
merlindo Posted May 25, 2021 Posted May 25, 2021 I have the same problem here 6.33.5700 - H100i platinum. Will try to uncheck box. My RGB on the H100i goes crazy flashing then freezes up and and my usb ports keep freezing up (webcam, Yeti mic, and Asus monitor hubs). Updated to the latest Icue while Aida was turned off and RGB came back fine but I cannot load Aida without the problem comming back. Here's what happens when I load Aida (after 3-5 mins led's just freeze up): AidaH100iplatBug.mov Quote
Scott Bunting Posted June 25, 2021 Posted June 25, 2021 Just wondered if anyone had found a fix for this yet? I was using the latest version of icue and aida64 and everything was fine for a few months and then started experiencing this issue out of no where, I have looked at a few threads about the conflict but I would rather not run aida64 than turn off the features that monitor the AIO because what’s the point of running a monitoring programme that isn’t monitoring? Quote
Enzaki Posted June 27, 2021 Posted June 27, 2021 On 6/25/2021 at 7:23 AM, Scott Bunting said: Just wondered if anyone had found a fix for this yet? I was using the latest version of icue and aida64 and everything was fine for a few months and then started experiencing this issue out of no where, I have looked at a few threads about the conflict but I would rather not run aida64 than turn off the features that monitor the AIO because what’s the point of running a monitoring programme that isn’t monitoring? Expand all you can do for now is File > Preferences > Stability > 'Corsair Hydro Platinum sensor support' and uncheck it bg enzaki Quote
Ettiene Posted August 8, 2021 Posted August 8, 2021 I cant believe that it was Aida 64. Ive just been living with this issue for months now. First it was driving me crazy but i got used to it. I disable the tickbox in Aida 64 and now i guess we just wait and see if it works. Thanks eveyryone. Quote
Relly Posted August 31, 2021 Posted August 31, 2021 This problem has been going on for 5+ years where is the fix? I am having the same issue with the H100i platinum... This makes me want my money back... The same issue dating back to 2017 Quote
Ridingmac Posted September 28, 2021 Posted September 28, 2021 OMG, this has just solved my issue and unchecking CORSAIR AIO in seetings fixed it. For the past 2 months ive been doing non stop BIOS updates, Turning off PCIe 4, and messing with various BIOS setting thinking its the damn AMD Usb disconnect issue, deleteing HWinfo64 etc etc etc So i bought AIDA64 for being able to view my AIO on my sensor panel, and now i'm learning that a 5 year old bug which was never fixed is the cause and that if i want my AIO to stop randomly disconnecting, i have to stop monitoring it? Damn this sucks. Is the dev team still looking into this bug or is it just being ignored hoping it would be forgotten? I mean beeing a sofware developper i understand bugs do happen, But 5 years? Am i missing something? Sorry for venting, i've been trying to solve this issue for SO long now and it turns out its and old bug that was never fixed. Specs: 5600X X570 Aorus Elite Corsair H150i Pro XT (Firmware 1.01.32)(Icue V 4.15.153) Corsair 32gb 3600mhz MSI 3080 Gaming X Trio Corsair RM750x Samsung 970 Evo Quote
Bill McKenzie Posted September 29, 2021 Posted September 29, 2021 On 9/28/2021 at 3:40 PM, Ridingmac said: OMG, this has just solved my issue and unchecking CORSAIR AIO in seetings fixed it. For the past 2 months ive been doing non stop BIOS updates, Turning off PCIe 4, and messing with various BIOS setting thinking its the damn AMD Usb disconnect issue, deleteing HWinfo64 etc etc etc So i bought AIDA64 for being able to view my AIO on my sensor panel, and now i'm learning that a 5 year old bug which was never fixed is the cause and that if i want my AIO to stop randomly disconnecting, i have to stop monitoring it? Damn this sucks. Is the dev team still looking into this bug or is it just being ignored hoping it would be forgotten? I mean beeing a sofware developper i understand bugs do happen, But 5 years? Am i missing something? Sorry for venting, i've been trying to solve this issue for SO long now and it turns out its and old bug that was never fixed. Specs: 5600X X570 Aorus Elite Corsair H150i Pro XT (Firmware 1.01.32)(Icue V 4.15.153) Corsair 32gb 3600mhz MSI 3080 Gaming X Trio Corsair RM750x Samsung 970 Evo Expand Wow. Here I was all set to buy Aida64, and this issue remains after FIVE YEARS? I am very conflicted! Need to know what my AIO is doing, and Corsair AIO's are one of the top coolers on the market. I have the H150i 360mm rad and knowing the temp inside that unit is important to me. I would love to hear that AIDA64 team has FIXED this issue, yeah? 1 Quote
Bill McKenzie Posted September 29, 2021 Posted September 29, 2021 On 11/17/2020 at 1:58 PM, Fiery said: Both of you, please let us know exactly what model of Corsair AIO cooler do you have. Thanks, Fiery Expand Link to the exact model Corsair cooler I'm using in my system Hi Fiery, would appreciate knowing when the 'fix' is out for the Corsair AIO cooler issue, thanks. Corsair H150i Capellix RGB AIO (360mm). Quote
DrFeelgood Posted November 11, 2021 Posted November 11, 2021 The problem still exist on my Corsair iCUE H115i RGB Pro XT in AIDA64 v6.5.5800 with newest iCUE Software v4.17.244 all running on Windows 10 Pro 21H1 19043.1348 Quote
DrFeelgood Posted November 22, 2021 Posted November 22, 2021 When can we expect a fix we're all having? Need I remind you that this issue is 5 years old? Quote
ThePizzaService Posted July 8, 2022 Posted July 8, 2022 It has almost been a year since the last post in this thread. The issue still isn't resolved. Unchecking sensor support was a fix for me, though I highly criticize Aida64 for not fixing a common issue that has been around for 6 years now! Quote
PSY-BORG Posted July 11, 2022 Posted July 11, 2022 FinalWire seems to have great difficulties with certain hardware manufacturers in reading their sensors correctly. With the products from Corsair and Aquacomputer, the reading of the sensors only works with a long delay, which greatly slows down the overall update frequency. These issues have also been known for a long time, but unfortunately no one at FinalWire is interested in fixing them. Quote
