Caelin Posted February 14, 2021 Posted February 14, 2021 I have the latest BETA version for AIDA64 and the only sensor I am seeing from the AIO is the pump fan from the motherboard since it has a connector from the pump to the motherboard CPU fan header and it shows up as the CPU fan in AIDA64. The rest of the six fans connected to the iCUE controller core are not detected by AIDA64 and I have all the Corsair options other than Corsair Link sensor support checked in the stability section of the preferences. Attached is the USB dump you guys normally ask for in the other posts I have seen. Could use some help figuring this out to get my AIO fans detected in AIDA64 as I have a BeadaPanel to display statistics and fan speeds and would like to monitor these fans. Thanks for any help you can provide. usbdump.txt Quote
Fiery Posted February 18, 2021 Posted February 18, 2021 On 2/14/2021 at 3:50 AM, Caelin said: I have the latest BETA version for AIDA64 and the only sensor I am seeing from the AIO is the pump fan from the motherboard since it has a connector from the pump to the motherboard CPU fan header and it shows up as the CPU fan in AIDA64. The rest of the six fans connected to the iCUE controller core are not detected by AIDA64 and I have all the Corsair options other than Corsair Link sensor support checked in the stability section of the preferences. Attached is the USB dump you guys normally ask for in the other posts I have seen. Could use some help figuring this out to get my AIO fans detected in AIDA64 as I have a BeadaPanel to display statistics and fan speeds and would like to monitor these fans. Thanks for any help you can provide. Thank you for the dump! We've ordered a Corsair iCUE Capellix device to help us develop and implement support for the new protocol. I will let you know in this topic once we have a new update about this. Quote
Fiery Posted March 3, 2021 Posted March 3, 2021 On 2/14/2021 at 3:50 AM, Caelin said: I have the latest BETA version for AIDA64 and the only sensor I am seeing from the AIO is the pump fan from the motherboard since it has a connector from the pump to the motherboard CPU fan header and it shows up as the CPU fan in AIDA64. The rest of the six fans connected to the iCUE controller core are not detected by AIDA64 and I have all the Corsair options other than Corsair Link sensor support checked in the stability section of the preferences. Attached is the USB dump you guys normally ask for in the other posts I have seen. Could use some help figuring this out to get my AIO fans detected in AIDA64 as I have a BeadaPanel to display statistics and fan speeds and would like to monitor these fans. Thanks for any help you can provide. I'm afraid the Capellix is a hard nut to crack. We've tried a number of ways to try and communicate with the device, but so far we haven't found a way to interrogate it in a way to make it return the fans+pump RPM as well as the thermal reading. We'll keep researching it, but at this time I cannot promise any timeline about this issue 1 2 Quote
Gimone Posted April 9, 2021 Posted April 9, 2021 I'm also interested in this. Got the Corsair H150i Elite Capellix as well and hopping to see it integrated into AIDA64. I guess most of us are interested in the fans RPM. The pump RPM we get from the motherboard and the thermal of the pump is of no importance as we get the CPU temperature already in AIDA. As you know the fans with this are connected to the Commander Core and can be 6 of them PWM controlled in this device. Considering corsair iCue is reading all those values from the commander core, it should be a way to find out the protocol to communicate with the device... Anyway, looking forward for this feature.. Good luck. Quote
naurog Posted June 14, 2021 Posted June 14, 2021 any news ln the topic? i recently replaced faulty icue h115i rgb pro xt for icue h115i elite capellix, so would be great to have liquid temp monitoring. thanks Quote
ezuh Posted July 26, 2021 Posted July 26, 2021 @Fiery Any updates to this? Trying to use the temp sensor off of my commander core to be able to see the delta temp for my custom loop. Quote
Caelin Posted August 25, 2021 Author Posted August 25, 2021 On 3/3/2021 at 1:29 PM, Fiery said: I'm afraid the Capellix is a hard nut to crack. We've tried a number of ways to try and communicate with the device, but so far we haven't found a way to interrogate it in a way to make it return the fans+pump RPM as well as the thermal reading. We'll keep researching it, but at this time I cannot promise any timeline about this issue @Fiery any update on this? It has been a while without any update on this issue and I am still waiting to be able to monitor my cooler fans on my Beada Panel. 2 Quote
Woodhi13 Posted September 4, 2021 Posted September 4, 2021 Now it makes sense why I did not see my AIO in the sensor panel Quote
Gilbert94 Posted September 25, 2021 Posted September 25, 2021 been patiently waiting....anyone gotten any updates or insights into this issue yet? Quote
WillisIVXX Posted January 3, 2022 Posted January 3, 2022 I have a h100 elite capellix also, i'll help any way i can, either windows or linux, as aida64 for linux would be awesome also for us android peeps that cant always see conky Quote
sedge Posted January 7, 2022 Posted January 7, 2022 Issue also applies to the new style iCUE ELITE LCD Display AIO coolers. Quote
naurog Posted February 2, 2022 Posted February 2, 2022 On 3/3/2021 at 8:29 PM, Fiery said: I'm afraid the Capellix is a hard nut to crack. We've tried a number of ways to try and communicate with the device, but so far we haven't found a way to interrogate it in a way to make it return the fans+pump RPM as well as the thermal reading. We'll keep researching it, but at this time I cannot promise any timeline about this issue any update? Quote
BlueDust Posted April 11, 2022 Posted April 11, 2022 Watching. I have a Capellix 115i w/LCD, and would like to monitor the temps/pump speed on the sensor panel. If this should already be working, and only need to purchase an extreme license, please let me know as I am trying to understand the software before I buy a license. Quote
NightEngineer Posted June 23, 2022 Posted June 23, 2022 I have the Corsair iCUE H100i and have the same issue, Not being detected. Any news about this ? Quote
JeffRH Posted June 23, 2022 Posted June 23, 2022 I have an i9 9900k, Gigabyte z390 Aorus Ultra, Corsair H115i Elite Capellix, AIDA64 Extreme 6.70.6000 and I can not get the H115i coolant temp or fan speed! Any help will be greatly appreciated! usbpsudump.txt corsairlinkdump.txt Quote
greywolf123 Posted December 2, 2022 Posted December 2, 2022 Any update on this? I'm having the same issue with the Corsair H150 AIO, Commander Core and Commander Core XT. Thank you in advance. 1 Quote
Dropcheck Posted January 9, 2023 Posted January 9, 2023 I have the Corsair H100i Elite LCD AIO and would love to have the ability to put images on the LCD screen and pull AIO pump rpms to display on my LCD screen on my Hyte Y60 monitor. Quote
Jotoo Posted February 17, 2023 Posted February 17, 2023 Same issue for H170I elite any progress on update? Quote
Arbit Posted February 21, 2023 Posted February 21, 2023 On 2/13/2021 at 9:50 PM, Caelin said: I have the latest BETA version for AIDA64 and the only sensor I am seeing from the AIO is the pump fan from the motherboard since it has a connector from the pump to the motherboard CPU fan header and it shows up as the CPU fan in AIDA64. The rest of the six fans connected to the iCUE controller core are not detected by AIDA64 and I have all the Corsair options other than Corsair Link sensor support checked in the stability section of the preferences. Attached is the USB dump you guys normally ask for in the other posts I have seen. Could use some help figuring this out to get my AIO fans detected in AIDA64 as I have a BeadaPanel to display statistics and fan speeds and would like to monitor these fans. Thanks for any help you can provide. usbdump.txt 32.44 kB · 9 downloads There are a ton of posts about this. Corsair icue software is incompatible. Either remove the software or plug your fans into mobo connectors. It's Corsair causing the problem. Quote
Salsiccia Posted April 5, 2023 Posted April 5, 2023 Apologies for the late reply to this thread. I have just recently purchased AIDA64 Extreme and I find it, after just an hour or so of playing to be a far superior product to iCue which I have been trying to use to monitor my Corsair ecosystem, and really don't like, but have now pretty much given up on. Moving forward I will be making AIDA64 my monitoring weapon of choice and if anyone has any recommendations for AIO coolers that play nicely with AIDA64 then please feel free to suggest them to me. I am about to embark on my "build a sensor panel project for my system and AIDA64 looks like a very good way to get that done ! Sal Quote
