FoX Posted June 17, 2020 Posted June 17, 2020 Is it possible to create the background of the sensor panel using an animated gif? This would allow some design options. Thank you an best regards FoX 1 Quote
Fiery Posted June 17, 2020 Posted June 17, 2020 16 minutes ago, FoX said: Is it possible to create the background of the sensor panel using an animated gif? This would allow some design options. Thank you an best regards FoX GIF image format and any form of animations are not supported by the SensorPanel. Quote
neg12roni Posted February 14, 2021 Posted February 14, 2021 On 6/17/2020 at 3:16 AM, FoX said: Is it possible to create the background of the sensor panel using an animated gif? This would allow some design options. Thank you an best regards FoX What I've done is to find a background where you can modify various sections of the background like the attached and I set it as a custom gauge and assign the three different backgrounds randomly across the 16 levels then I pick something like a CPU temp that changes constantly. Make sure to narrow the high and low of the gauge range so that 16 levels of the custom gauge are constantly switching the backgrounds. 2 Quote
FuryXL Posted April 25, 2021 Posted April 25, 2021 Hi, could you be a little bit more explicit please? I understand the idea, but not the implementation. Thank you Quote
Anthony Kolka Posted May 21, 2021 Posted May 21, 2021 On 6/17/2020 at 6:33 AM, Fiery said: GIF image format and any form of animations are not supported by the SensorPanel. Wishlist item. MP4 background option as well. Quote
flagrant99 Posted May 25, 2021 Posted May 25, 2021 Using custom gauge we can simulate animation tied to sensor. Can we just get a 1-16 timer like it shows in the sample window so it steps by seconds interval or something. My CPU temp barely changes. I like that I can make custom gauges tied to sensor but for background I just want something to change every second or every 5 seconds. 16 images is more than enough. Quote
max454548 Posted June 15, 2021 Posted June 15, 2021 Добрый день, усовершенствуйте AIDA 64 что б поддерживал GIF картинку, пора усовершенствовать программу а также и другие файлы Quote
dkopec91 Posted November 11, 2021 Posted November 11, 2021 On 5/25/2021 at 2:33 PM, flagrant99 said: Using custom gauge we can simulate animation tied to sensor. Can we just get a 1-16 timer like it shows in the sample window so it steps by seconds interval or something. My CPU temp barely changes. I like that I can make custom gauges tied to sensor but for background I just want something to change every second or every 5 seconds. 16 images is more than enough. I realize that this is rather an old thread. Nevertheless, I'd like to share a little program that I've made recently, which can help you achieve the described goal. How it works: Simply speaking SymlinkSwapper creates a file (symbolic link/symlink), which you can use as a sensor panel background. Symlink points to one of the files in the directory of your choosing. After user-defined time passes, SymlinkSwapper replaces the file it created with a new symlink, this time pointing to the next file in the source directory. And so on and so forth. A short while after the sensor panel detects that the symlink has changed it reloads the background image. Download + source code: SymlinkSwapper GitHub page Select the "Releases" URL to download the executable file. Demo: https://youtu.be/BuAg57Ey89Q Recorded on Windows 10 Enterprise 21H1 build 19043.1288 Aida64 Engineer 6.50.5800 Disclaimer: Running this software results in a small amount of data being written onto your SSD/HDD. However small it might be, it's happening constantly with the frequency that you choose. In order to avoid any unnecessary I/O operations that might, in the long run, impact the lifespan of your storage device I would suggest using a Ram Disk utility, such as ImDisk, to store those files in the system memory. ImDisk tutorial Please note that in order for the SymlinkSwapper to work, the executing user has to be assigned appropriate privileges. If you don't wish to modify your system settings for the sole purpose of testing this software you should be able to get it going by selecting "Run as administrator" from the context menu. 2 Quote
Daelan83 Posted October 6, 2022 Posted October 6, 2022 Ma scusate, non basterebbe fare lo sfondo di Aida trasparente e creare i vari sensori su un wallpaper animato? Quote
Wiebenor Posted December 22, 2023 Posted December 22, 2023 How about using a GIF filmstrip image in a rainmeter skin? Once you have a moving desktop animation/widget in rainmeter, then you can move it over to the sensor panel... of course, it would be a bit harder probably, if you wanted it to be a full screen background, and not just a small animation in a corner or something, and obviously, the fewer the frames and smaller the filesize and/or dimensions of the "filmstrip" GIF the better it would (likely) run on lower end hardware, as not as much memory would likely be required... 1 Quote
