Evga clc360 does not show pump speed and water temperature.
In some previous versions, it didn't show up in 6.25.5468 beta. (Extreme version)
Is there anyone who has the same problem as me?
Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
I attached usb dump. I know that the evga flow control program is interfering with the aida64 sensor because there is a conflict with the evga flow control program, so I am not using the program. By the way, today's test confirmed that even using the LED sync function of evga Precision x1 (evga vga program) interferes with the sensor function of aida64. When the LED sync function is turned off at the precision, the CLC water temperature is normally displayed by kraken X -1.
usb dump.txt
