namuk Posted June 28, 2015 Author Posted June 28, 2015 well this is fun, both Alpha Lcd screens are working at same time , also the SDC megatron is connected as well, question is there a Brightness level at all ? i know i could do this with the SDC megatron software .. ah found Brightness for SDC meg now , i take it none for Alpha Quote
Fiery Posted June 28, 2015 Posted June 28, 2015 well this is fun, both Alpha Lcd screens are working at same time , also the SDC megatron is connected as well, question is there a Brightness level at all ? i know i could do this with the SDC megatron software .. ah found Brightness for SDC meg now , i take it none for Alpha As far as I know, AlphaCool displays only support backlight on/off setting, but no brightness or contrast adjustment Quote
namuk Posted June 29, 2015 Author Posted June 29, 2015 As far as I know, AlphaCool displays only support backlight on/off setting, but no brightness or contrast adjustment ah remember now the big update to the SDC was the brightness adjustment as it really is an updated alpha Quote
namuk Posted June 29, 2015 Author Posted June 29, 2015 Running both sdc megtron and alpha now all is stable there also more responsive running direct as well, at least they will be easier to setup just using one software now, one thing on download and upload rate it would be great to have Mbps instead of Kbps on the Gauge item type. i have a second Alpha i know that works as i plugged it in and used software just i have got nowhere to put it due to no room in case or an external body to hold it,will look into that one. Quote
Fiery Posted July 2, 2015 Posted July 2, 2015 one thing on download and upload rate it would be great to have Mbps instead of Kbps on the Gauge item type. I'm afraid that's not possible. But, here's a new AIDA64 update that now implements support for all 4 rotation options (0 degrees, 90 degrees, 180 degrees, 270 degrees) for AlphaCool and Samsung SPF LCDs: http://www.aida64.com/downloads/latesta64xebeta 1 Quote
bartgrefte Posted July 19, 2015 Posted July 19, 2015 I've been thinking about getting an AlphaCool LCD, but the outdated driver is holding me back. Does that old driver even work on (64 bit editions of) Windows 7 and Windows 10? Quote
Fiery Posted July 19, 2015 Posted July 19, 2015 AFAIK AlphaCool LCDs work fine under Win7 64-bit, so they should also work under Win10. Worst case we can generate a libusb0 driver anytime, and sign it using our digital signature. Quote
Fiery Posted July 20, 2015 Posted July 20, 2015 I've been thinking about getting an AlphaCool LCD, but the outdated driver is holding me back. Does that old driver even work on (64 bit editions of) Windows 7 and Windows 10? We've just tested Windows 10 Build 10240 (64-bit) with an AlphaCool 240x128 display on an unreleased Intel platform, and it worked flawlessly. The only trick is: install.exe of the AlphaCool driver package doesn't work properly, so you have to manually install the driver using Device Manager. Quote
namuk Posted September 3, 2015 Author Posted September 3, 2015 when it says "Cpu package" in temp sensors is that the whole cpu temp? also just replace mb and cpu ect and added the old profiles 99% worked was well happy , with the old software i had to start from scratch, saved allot of faffing around i can tell you, also both screens work flawless on win 10 pro 64bit , had to install software for the SDC for it to work and only the alpha driver 2.1 needed installing. Quote
Fiery Posted September 3, 2015 Posted September 3, 2015 CPU Package is the temperature that is measured by the CPU itself, and it represents the overall temperature of the CPU package -- as opposed to the core temperatures which correspond to an individual CPU core. Quote
namuk Posted September 3, 2015 Author Posted September 3, 2015 understand, well i have CPU and Cpu package on screen , if i run a cpu stress test which would be the most important one? Quote
namuk Posted September 3, 2015 Author Posted September 3, 2015 will do, i ran Hw monitor and the package was the overall temp so really it is pointless having Cpu temp showing just have the cores showing and package Quote
ciottino Posted October 8, 2016 Posted October 8, 2016 Hello Have a big problem, alphalcd.de is closed.. now is impossible to find the software, someone can help me? Quote
namuk Posted October 8, 2016 Author Posted October 8, 2016 Just checked the links they are gone all you need is the USB driver for aida64 , will setup a download link later. use winrar to extract http://www.megafileupload.com/ot72/USBDisplayDriverv21.zip Quote
bartgrefte Posted October 9, 2016 Posted October 9, 2016 Just checked the links they are gone all you need is the USB driver for aida64 , will setup a download link later. use winrar to extract http://www.megafileupload.com/ot72/USBDisplayDriverv21.zip Can you upload it somewhere else, like attach it to your message? Tried downloading it from that website several times, download won't finish in Firefox. Chrome blocks it because it is "harmfull". Quote
Fiery Posted October 9, 2016 Posted October 9, 2016 Please try this link: http://users.aida64.com/alphacool_lcd_driver_2_1.zip 1 Quote
namuk Posted October 9, 2016 Author Posted October 9, 2016 Please try this link: http://users.aida64.com/alphacool_lcd_driver_2_1.zip nice one ,saves me finding another , works here as well also changed first page to that driver link Quote
ciottino Posted October 9, 2016 Posted October 9, 2016 Please try this link: http://users.aida64.com/alphacool_lcd_driver_2_1.zip Thank you Quote
bartgrefte Posted October 10, 2016 Posted October 10, 2016 Please try this link: http://users.aida64.com/alphacool_lcd_driver_2_1.zip Thanks Quote
namuk Posted March 5, 2017 Author Posted March 5, 2017 The recent corsair link update solved the signal drop out on the i series psu's and the AIO cooler monitoring if peeps would like to know, as i thought it was a combined issue with aida64 and alpha/megtron driver problem my self but thats not the case Quote
Fiery Posted March 6, 2017 Posted March 6, 2017 16 hours ago, namuk said: The recent corsair link update solved the signal drop out on the i series psu's and the AIO cooler monitoring if peeps would like to know, as i thought it was a combined issue with aida64 and alpha/megtron driver problem my self but thats not the case We're working together with Corsair, NZXT and Asus right now, in order to improve the synchronization (interlocking) between their respective monitoring software and AIDA64. We're glad if you guys can notice the progress 1 Quote
namuk Posted April 29, 2017 Author Posted April 29, 2017 On 2017-3-6 at 4:29 PM, Fiery said: We're working together with Corsair, NZXT and Asus right now, in order to improve the synchronization (interlocking) between their respective monitoring software and AIDA64. We're glad if you guys can notice the progress always notice and fixes like that are welcomed indeed, i was going to post about it but the update came out, you beat me too it lol. one thing i do want to know is are you doing to add EVGA - iCX support ? would not mind adding this to the alpha and mega screens, well some of it Quote
Fiery Posted May 2, 2017 Posted May 2, 2017 On 2017. 04. 29. at 10:08 PM, namuk said: always notice and fixes like that are welcomed indeed, i was going to post about it but the update came out, you beat me too it lol. one thing i do want to know is are you doing to add EVGA - iCX support ? would not mind adding this to the alpha and mega screens, well some of it Do you mean that AIDA64 should be able to monitor the 9 temperature sensors managed by iCX? If yes, then we'll need to look into that. Do you know if EVGA's own monitoring software is already capable of monitoring those 9 temperature sensors? Quote
namuk Posted May 11, 2017 Author Posted May 11, 2017 On 2017-5-2 at 8:13 AM, Fiery said: Do you mean that AIDA64 should be able to monitor the 9 temperature sensors managed by iCX? If yes, then we'll need to look into that. Do you know if EVGA's own monitoring software is already capable of monitoring those 9 temperature sensors? I do mate and yes there own precision x monitors it you can even through up a map diagram were each sensor is that shows temps, only shows one fan speed but there is two speeds (default) but can be set in custom profile or set both the same. seems like EVGA are replacing all the ACX3.0 for ICX coolers, so it will be worth looking into as others may follow suit. Quote
