Aquaero and Aquaduct sensor support
We've implemented sensor support for Aquaero 4, Aquaero 5, Aquaero 6, Aquaduct Mark 2, Aquaduct Mark 3, Aquaduct Mark 4, and Aquaduct Mark 5 devices. We'll need to refine and extend the current sensor module, so please take the first AIDA64 beta as ... well, the first beta ;)
For Aquaero 4, Aquaduct Mark 2 and Aquaduct Mark 3, the following readings are available in the first beta:
- 6 generic temperatures
- 4 fan speeds (RPM)
- 1 flow sensor (LPH -- litres per hour)
For Aquaero 5, Aquaero 6, Aquaduct Mark 4, and Aquaduct Mark 5, the following readings are available in the first beta:
- 16 generic temperatures
- 4 fan VRM temperatures
- 12 fan speeds
- 4 flow sensors
- 4 liquid level sensors (%)
Fan VRM temperatures, flow sensors and liquid levels are only available on the Computer / Sensor page currently. As soon as the Aquaero sensor module gets more mature, we'll add the new type of readings to the rest of the AIDA64 hardware monitoring modules (e.g. OSD Panel, SensorPanel, LCD).
Note: For Aquaero 5, Aquaero 6, Aquaduct Mark 4, and Aquaduct Mark 5 you need to have Firmware Revision 1036 or later to assure AIDA64 uses the proper register offsets for sensor readings.  It may or may not work with older firmware releases.
Please let us know how it works on your Aquaero/Aquaduct device. Note that Aquaeros/Aquaducts are very complicated devices, so we'll need a bit more time to put every piece of the puzzle together. Let me know if you miss anything from the current capabilities of the Aquaero/Aquaduct sensor solution.
  • Replies 77
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Just tested the sensors on my Aquaduct Mk IV.
Everything seems to work fine with the exception of the LiquidLevels. Both are completely off.
Liquid Level 1 is reported as 7096%, Level 2 as 215%
The actual value as reported by the Aquaduct is 71%.
So my guess is that you're reporting 100x the actual value.
Here's the sensor debug output:
Sensor Properties
Sensor Type Nuvoton NCT6791D/5538D  (ISA A00h)
GPU Sensor Type Diode  (NV-Diode)
Motherboard Name Asus Rampage V Extreme
Temperatures
Motherboard 31 °C  (88 °F)
CPU 68 °C  (154 °F)
CPU #1 / Core #1 72 °C  (162 °F)
CPU #1 / Core #2 71 °C  (160 °F)
CPU #1 / Core #3 78 °C  (172 °F)
CPU #1 / Core #4 72 °C  (162 °F)
CPU #1 / Core #5 73 °C  (163 °F)
CPU #1 / Core #6 72 °C  (162 °F)
CPU #1 / Core #7 75 °C  (167 °F)
CPU #1 / Core #8 65 °C  (149 °F)
PCH 41 °C  (106 °F)
VRM 55 °C  (131 °F)
Fan #1 VRM 51 °C  (124 °F)
Fan #2 VRM 51 °C  (124 °F)
Fan #3 VRM 50 °C  (122 °F)
Fan #4 VRM 50 °C  (122 °F)
GPU1: GPU Diode 46 °C  (115 °F)
GPU2: GPU Diode 45 °C  (113 °F)
Temperature #1 26 °C  (79 °F)
Temperature #2 31 °C  (88 °F)
Temperature #3 38 °C  (100 °F)
Temperature #4 33 °C  (91 °F)
Temperature #5 37 °C  (99 °F)
Temperature #6 41 °C  (106 °F)
SAMSUNG SSD 830 Series 30 °C  (86 °F)
Samsung SSD 850 PRO 1TB 32 °C  (90 °F)
Cooling Fans
CPU 3470 RPM
Chassis #1 1167 RPM
Chassis #3 562 RPM
Fan #1 1107 RPM
Fan #2 1103 RPM
Fan #3 1125 RPM
Fan #4 1195 RPM
GPU1 29%
GPU2 29%
Voltage Values
CPU Core 1.328 V
CPU VRM 1.872 V
CPU Cache 1.106 V
+1.05 V 1.041 V
+3.3 V 3.296 V
+5 V 5.040 V
+12 V 11.904 V
+3.3 V Standby 3.424 V
VBAT Battery 3.280 V
VCCIO 1.044 V
VCCSA 0.992 V
VTT 1.048 V
PCH Core 1.047 V
PCH I/O 1.488 V
DIMM AB 1.209 V
DIMM CD 1.194 V
GPU1: GPU Core 1.212 V
GPU2: GPU Core 1.250 V
Power Values
CPU Package 1.23 W
GPU1: GPU TDP% 55%
GPU2: GPU TDP% 67%
Flow Sensors
Flow #1 39.30 LPH
Flow #2 0.00 LPH
Flow #3 0.00 LPH
Flow #4 0.00 LPH
Liquid Levels
Liquid Level #1 7096%
Liquid Level #2 215%
Debug Info F 65535 65535 65535 65535 65535 65535
Debug Info T 00 00 00
Debug Info V 20 02 CC F7 FF 60 00 (01)
Motherboard ID      : 63-0100-000001-00101111-010914-Chipset$0AAAA000_BIOS DATE: 10/09/14 21:39:22 VER: 05.06.05
Motherboard Model   : Asus Rampage V Extreme
Motherboard Chipset : Intel Wellsburg X99, Intel Haswell-E
DMI MB Product      : RAMPAGE V EXTREME
DMI MB Version      : Rev 1.xx
DMI MB Serial       : 140830368100543
DMI SYS Manufacturer: ASUS
DMI SYS Product     : All Series
DMI SYS Version     : System Version
DMI SYS Serial      : System Serial Number
DMI BIOS Version    : 0801
------[ GPIO @ isa 0500 ]------
0000  E7 E1 FE DF  E7 EE 6B CA  00 00 00 00  BC DF 1B 2F
0010  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 08 00  00 00 00 00  00 00 00 00  85 40 00 00
0030  CF E8 FD 03  F7 FF 56 1D  8D 2F 56 FD  00 00 00 00
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h)
ITE SuperIO Device ID      = 0000h (0000h / 0000h)
ITE SuperIO Version        = 00h   (  00h /   00h)
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0290h (0290h / 0000h)
Winbond SuperIO HWMonitor Port/64 = 0A00h (0A00h / 0000h)
Winbond SuperIO Device ID         = C803h (C803h / 0000h)
Winbond Sensor ID A3/5C/reg$58    = A3 / 5C / C1
ASpeed SuperIO Port = 00h
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------
0000  04 E5 04 F7  00 FF FF FF  FF FF FF FF  FF FF FF FF
0010  04 FF 04 69  04 FF 03 FF  40 83 25 7C  54 53 53 00
0020  75 7E CE CE  7C F4 54 1F  FF FF FF DA  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0040  03 00 00 FF  DF 00 1E FF  2D FF FF 10  00 55 00 A3
0050  05 FF FF FF  FF FF FF FF  C1 FF FF FF  FF 01 00 FF
0060  AA 0C FF FF  FF 01 00 FF  FF FF FF FF  FF FF FF FF
0070  00 0A 00 37  00 43 80 43  80 23 00 21  80 FF FF FF
0080  FF 7F 3F BF  FF 05 05 05  00 00 00 00  00 00 00 00
0090  0A 00 00 00  00 FD FD FD  0A 95 EF 80  FF 40 46 C4
00A0  0E FF 00 00  FF 00 00 FF  00 00 80 66  06 06 01 00
00B0  00 00 00 00  00 00 32 00  04 00 00 03  D2 00 04 00
00C0  FF FF FF FF  FF FF FF FF  FF 15 07 05  FF FF FF FF
00D0  05 05 05 05  00 00 00 00  00 00 00 00  FD FD FD FD
00E0  55 80 00 00  00 FF FF FF  FF FF 37 00  00 23 00 00
00F0  00 00 00 00  00 00 00 00  00 00 00 00  40 FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------
0000  1F 00 40 01  01 01 01 3C  00 E5 FF E5  00 FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF 2B 2B 31  39 FF FF 59  59 99 FF FF  FF FF FF FF
0030  FF 00 FF FF  00 4B 00 CC  02 FF FF FF  FF FF FF 00
0040  FF FF FF FF  FF 00 00 FF  FF FF FF FF  FF FF 00 FF
0050  37 80 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF 11 00  FF FF FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------
0000  10 32 40 01  01 01 01 3C  00 F7 00 F7  00 FF FF FF
0020  FF 1E 46 46  46 FF FF 99  FF FF FF FF  FF FF FF FF
0030  FF 00 FF FF  00 4B 00 CC  02 01 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------
0000  10 00 40 01  01 01 01 3C  00 FF FF FF  00 FF FF FF
0020  FF 00 00 00  00 FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0020  FF FF FF 96  64 96 64 E1  96 00 FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF 00 00  FF FF FF FF  FF FF 00 00  00 00 00 FF
0050  03 73 FF FF  00 00 00 FF  FF 1E 13 37  09 00 FF FF
0060  FF 01 00 00  00 00 00 00  FF FF FF FF  FF FF FF FF
0080  75 7E CE CE  7C F4 54 D6  CE 83 25 7C  54 53 53 00
0090  1F 37 2C 60  1A 2D 00 32  00 37 43 43  23 21 16 2C
00A0  FF 1F FF FF  FF FF E5 F7  FF 69 00 00  00 00 00 00
00B0  24 05 0C 05  FF 1F 4A 1D  FF 1F FF 1F  00 00 FF FF
00C0  04 8E 0D 8E  00 00 02 33  00 00 00 00  FF FF FF FF
00D0  00 00 00 00  00 00 FF FF  FF FF FF FF  FF FF FF FF
00E0  E5 F7 FF 69  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  4E 80 00 00  43 00 F5 00  50 00 51 00  00 00 00 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------
0000  FF FF 00 00  00 06 00 FF  0F FF FF FF  FF 00 00 FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  D6 CE 00 FF  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 7F 3F  3F FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------
0000  00 00 00 00  00 00 00 FF  FF FF FF FF  FF FF FF FF
0010  00 00 00 F5  00 F5 FF FF  FF FF FF FF  FF FF FF FF
0020  FF 01 02 00  FF FF FF FF  FF FF FF FF  FF FF FF 1F
0030  24 05 0C 05  FF 1F 4A 1D  FF 1F FF 1F  FF 1F FF 1F
0040  FF 1F FF 1F  02 02 02 02  02 02 FF FF  FF FF 00 FF
0050  7F 7F 7F 7F  00 00 04 8E  0D 8E 00 00  02 33 00 00
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------
0000  FF 95 02 10  00 00 00 00  00 69 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 F9  61 F8 80 F8  80 F8 80 01
0020  4E 02 07 00  00 00 EF 01  00 EF 00 00  00 00 00 00
0030  00 00 00 FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
   0027 0150 0250 007D 007E 0490 0491 0492 0493 0494 0495 062B 062C 062D 071C 0720
T:   31    55   255   255   255    31    55    44    96    26    45   255   255   255   128    78
   0020 0021 0022 0023 0024 0025 0026 0480 0481 0482 0483 0484 0485 0486 0487 0488 0489 048A 048B 048C 048D 048E 048F
V:  75   7E   CE   CE   7D   F4   54   75   7E   CE   CE   7D   F4   54   D6   CE   83   25   7C   54   53   53   00   [ VID = 1.32532 V ]
V:  76   7E   CE   CE   7D   F4   54   76   7E   CE   CE   7D   F4   54   D6   CE   83   25   7C   54   53   53   00   [ VID = 1.32532 V ]
V:  75   7E   CE   CE   7D   F5   54   75   7E   CE   CE   7D   F5   54   D6   CE   83   25   7C   54   53   53   00   [ VID = 1.32532 V ]
------[ NCT6791 ISA Sensor Device at 0A00 ]------
0000  75 7E CE CE  7D F5 54 D6  CE 83 25 7C  54 53 53 00
0010  1F 37 2C 60  1A 2D 00 31  80 37 44 45  22 21 2C 36
0020  1F 00 E5 F9  FF 60 00 00  00 00 00 00  00 00 24 1B
0030  0C 1B FF 1B  49 1B FF 1B  FF 1B 04 79  0D 85 00 00
0040  02 3B 00 00  00 00 00 00  00 00 00 00  E5 F9 FF 60
0050  FF FF 50 80  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 44 00 F5  00 FF FF FF  FF FF FF FF  FF FF FF FF
     10    11    1B    20    52    71    73    75
T:   31    55    69    31    80    68   245   255
T:   31    55    69    31    80    69   245   255
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
------[ 9 SMBuses detected ]------
------[ SMBus #0 ]------
SMBus Type  : Intel ICH
SMBus Port  : 0580
Can Have SPD: No
Scan Type   : Full
  0000  00 00 00 04 00 00 00 00 00 48 52 18 03 22 10 14  .........HR.."..
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF48 FF52 FF18 FF03 FF22 FF10 FF14
  0010  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0030  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0040  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0050  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0060  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0070  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0080  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0090  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00A0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00B0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00D0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00F0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
------[ SMBus Device B00-D48 ]------
  0000  00 21 E0 C0 00 D4 20 78 1D FF 07 49 F0 00 00 00  .!.... x...I....
  0010  0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00  ....&!..........
  0020  0D 00 03 00 72 2C 04 00 00 00 00 00 00 00 00 00  ....r,..........
  0040  00 21 E0 C0 00 D4 20 78 1D FF 07 49 F0 00 00 00  .!.... x...I....
  0050  0D 00 03 00 26 25 04 00 00 00 00 00 00 00 00 00  ....&%..........
  0060  0D 00 03 00 72 2C 04 00 00 00 00 00 00 00 00 00  ....r,..........
  0080  00 21 E0 C0 00 D4 20 78 1D FF 07 49 F0 00 00 00  .!.... x...I....
  0090  0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00  ....&!..........
  00A0  0D 00 03 00 72 2C 04 00 00 00 00 00 00 00 00 00  ....r,..........
  00C0  00 21 E0 C8 FF FF 20 78 1D FF 07 49 F0 00 00 00  .!.... x...I....
  00D0  0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00  ....&!..........
  00E0  0D 00 03 00 72 2C 04 00 00 00 00 00 00 00 00 00  ....r,..........
  0000  FF00 FF21 FFE0 FFC0 FF00 FFD4 FF20 FF78 FF1D FFFF FF07 FF49 FFF0 FF00 FF00 FF00
  0010  FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF0D FF00 FF03 FF00 FF72 FF2C FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0040  FF00 FF21 FFE0 FFC0 FF00 FFD4 FF20 FF78 FF1D FFFF FF07 FF49 FFF0 FF00 FF00 FF00
  0050  FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0060  FF0D FF00 FF03 FF00 FF72 FF2C FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0080  FF00 FF21 FFE0 FFC0 FF00 FFD4 FF20 FF78 FF1D FFFF FF07 FF49 FFF0 FF00 FF00 FF00
  0090  FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00A0  FF0D FF00 FF03 FF00 FF72 FF2C FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF00 FF21 FFE0 FFC0 FF00 FFD4 FF20 FF78 FF1D FFFF FF07 FF49 FFF0 FF00 FF00 FF00
  00D0  FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF0D FF00 FF03 FF00 FF72 FF2C FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
*** SMBus Semaphore Disabled = 1
------[ SMBus #1 ]------
SMBus Type  : Intel SNB-E/IVB-E/HSW-E/BDW-E
SMBus MMIO  : 00000000-EFF98180
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B01-D50 ]------
  0000  10 0C 02 84 19 00 08 00 00 00 03 01 03 00 00 00  ................
  0010  00 08 0C FC 03 00 00 6C 6C 71 11 08 74 20 08 00  .......llq..t ..
  0020  05 70 03 00 A8 1E 2B 2B 00 00 00 00 00 00 00 00  .p....++........
  0030  00 00 00 00 00 00 00 00 00 00 00 16 36 16 36 16  ............6.6.
  0040  36 16 36 00 00 2B 0C 2B 0C 2B 0C 2B 0C 00 00 00  6.6..+.+.+.+....
  0070  00 00 00 00 ED B5 CF 00 C0 00 00 00 C2 59 3F 11  .............Y?.
  0080  11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 B6 58 23  ..............X#
------[ SMBus #2 ]------
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B02-D50 ]------
------[ SMBus #3 ]------
SMBus MMIO  : 00000000-EFF98190
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B03-D50 ]------
------[ SMBus #4 ]------
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B04-D50 ]------
------[ SMBus #5 ]------
SMBus MMIO  : 00000000-EFFB0180
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus #6 ]------
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus #7 ]------
SMBus MMIO  : 00000000-EFFB0190
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus #8 ]------
Can Have SPD: Yes
Scan Type   : Full
Thank you for the feedback.  Does Aquaduct report 2% for Level 2?  Does it report the liquid levels measurement unit as LPH (l/h) ?
Please note that the existing AIDA64 sensor dumps currently do not cover Aquaero/Aquaduct raw registers output.  We'll need to add a specific Aquaero/Aquaduct sensor dump to see how the registers look like.
The Aquaduct only shows one level sensor, I guess the other one is for a different kind of hardware. So I can't tell you the actual value of the second level sensor.
I also can only use one flow meter and up to 6 temperature sensors.
The water flow is measured in liters per hour, yes, and you're showing the correct amount for the one flow sensor I have.
The water level is listed in percent, 100% meaning it's filled up to the brim.
BTW, now the level sensor shows "80%" on the aquaduct while you list "7954%" which would confirm the factor 100. And, yes, it's pretty normal that the level meter has a huge variation, I didn't put any additional water into the device.
And there's one sensor missing from your listings: "Water Quality". At least I didn't see it.
I currently have an Aquaduct 360 XT Mark V.
Attached are an AquaSuite display snapshot and an Aida64 Report (there was 2 or 3 seconds between the report & clip).
My Aquaduct firmware version shows as 1020, and I have a thread at Aquacomputer forums regarding updating.
Notes:
- under Temperatures, Fan #4 VRM is non-existant (only 3 fans on 360)
- Liquid levels appear to be off by some percent conversion
- is it possible to catch the decimal value for Temperatures as you do for Flow Sensors?
- Water Quality is a calculated value from a water conductivity measurement (particulates in the water) and was stated as not to be relied on.
- Power Measurement is a calculated value derived from temperature differences and was stated as not to be relied on.
Item of interest I do not see:
- Pump Hz, RPM & Amps
- Fan Voltages and Amps
Edit: attachments removed
Thanks for the feedback. Here's a new AIDA64 Extreme beta update:
In this beta we've fixed the liquid levels calculation issue, and added fan voltages, fan currents and fan powers. We've also added the new readings to all hardware monitoring modules, such as OSD Panel, Desktop Gadget, LCD, SensorPanel, Logging, External Applications, and Alerting.
AIDA64 doesn't support measuring or displaying decimal digits for temperature readings. We do not believe that's a necessary information, since there's no practical difference between having a certain hardware component running at 35.1 or 35.4 Celsius.
We've checked the pump properties, but so far we haven't been able to identify those readings in the Aquaero/Aquaduct information block. It must be there somewhere, but it's not documented :( We may be able to find it if you could help us by submitting an Aquaero sensor dump: right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. When you issue the dump, please takes notes (or create a screen shot) of the actual values of the pump related readings, so we can try to find the values among the Aquaero raw registers in the dump.
We've also tried to find a solution to calculate water quality, but so far we've had no luck about that. We'll try to ask Aqua Computer about that, maybe they would be kind enough to point us to the right direction.
BTW, Aqua Computer has contacted us to notify us about an upcoming major change in the Aquaero registers layout. They said once the new firmware is available for download, they'll send us documentation on the new layout to let us adjust AIDA64 accordingly. We'll try to be quick about that, but please keep in mind that if you update to the new firmware, the values displayed by the above linked AIDA64 beta update may become wildly inaccurate due to the data layout changes.
Oops, I think I am at my limit for uploading.
For now you can pick them up with the links below:
   aquaerodump.txt
   Report.txt
again, it probably took a few seconds to initiate each report, so some values may vary slightly.
One non-aquaero related item.
Normally with an update download you included a small text file outlining the changes... I did not receive that this time.
Thanks a lot Fiery!
All your changes seem to work fine. And nice new icons for the flow and level sensors :)
Here's the sensor dump:
Sensor Properties
Temperatures
Motherboard 33 °C  (91 °F)
CPU 38 °C  (100 °F)
CPU #1 / Core #1 37 °C  (99 °F)
CPU #1 / Core #2 36 °C  (97 °F)
CPU #1 / Core #3 37 °C  (99 °F)
CPU #1 / Core #4 38 °C  (100 °F)
CPU #1 / Core #5 34 °C  (93 °F)
CPU #1 / Core #6 36 °C  (97 °F)
CPU #1 / Core #7 37 °C  (99 °F)
CPU #1 / Core #8 35 °C  (95 °F)
PCH 41 °C  (106 °F)
VRM 42 °C  (108 °F)
Fan #1 VRM 41 °C  (106 °F)
Fan #2 VRM 41 °C  (106 °F)
Fan #3 VRM 44 °C  (111 °F)
Fan #4 VRM 44 °C  (111 °F)
GPU1: GPU Diode 38 °C  (100 °F)
GPU2: GPU Diode 38 °C  (100 °F)
Temperature #1 34 °C  (93 °F)
Temperature #2 34 °C  (93 °F)
Temperature #3 35 °C  (95 °F)
Temperature #4 34 °C  (93 °F)
Temperature #5 34 °C  (93 °F)
Temperature #6 35 °C  (95 °F)
SAMSUNG SSD 830 Series 34 °C  (93 °F)
Samsung SSD 850 PRO 1TB 33 °C  (91 °F)
Cooling Fans
CPU 3461 RPM
Chassis #1 507 RPM
Fan #4 463 RPM
GPU1 26%
GPU2 26%
Voltage Values
CPU Core 1.024 V
CPU VRM 1.856 V
CPU Cache 1.041 V
+1.05 V 1.038 V
+3.3 V 3.344 V
+5 V 5.080 V
+12 V 12.000 V
VBAT Battery 3.296 V
VCCIO 1.044 V
VCCSA 1.000 V
VTT 1.048 V
PCH Core 1.047 V
PCH I/O 1.491 V
DIMM AB 1.203 V
DIMM CD 1.200 V
Fan #1 0.010 V
Fan #2 0.010 V
Fan #3 0.010 V
Fan #4 4.150 V
GPU1: GPU Core 1.093 V
GPU2: GPU Core 1.075 V
Power Values
CPU Package 0.60 W
GPU1: GPU TDP% 26%
GPU2: GPU TDP% 26%
Flow Sensors
Flow #1 38.80 LPH
Flow #2 0.00 LPH
Flow #3 0.00 LPH
Flow #4 0.00 LPH
Liquid Levels
Liquid #1 68%
Liquid #2 2%
Debug Info V 21 02 59 AD FF 60 00 (00)
0000  04 59 04 AD  00 FF FF FF  FF FF FF FF  FF FF FF FF
0010  04 FF 04 00  04 FF 03 FF  40 83 25 7D  3E 46 40 00
0020  74 7F D0 D0  7D F6 3E 21  FF FF FF DA  00 00 00 00
0040  03 00 00 FF  DF 00 1E FF  2D FF FF 10  00 55 02 A3
0070  00 0A 00 2A  00 26 80 26  80 21 00 34  00 FF FF FF
00B0  00 00 00 00  00 00 32 00  04 00 00 34  28 80 04 00
00C0  FF FF FF FF  FF FF FF FF  FF 05 04 05  FF FF FF FF
00E0  55 80 00 00  00 FF FF FF  FF FF 2A 00  00 21 00 00
0000  1F 00 40 01  01 01 01 3C  00 59 FF 59  00 FF FF FF
0040  FF FF FF FF  FF 00 00 FF  FF FF FF FF  FF FF 02 FF
0050  26 00 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0000  10 32 40 01  01 01 01 3C  00 AD 00 AD  00 FF FF FF
0040  FF FF 00 00  FF FF FF FF  FF FF 00 00  00 00 02 FF
0080  74 7F D0 D0  7D F6 3E D6  CE 83 25 7D  3E 46 40 00
0090  21 26 3A 62  1A 39 00 32  80 2A 26 26  21 34 06 3A
00A0  FF 21 FF FF  FF FF 59 AD  FF 60 00 00  00 00 00 00
00B0  54 05 0C 06  FF 1F FF 1F  FF 1F FF 1F  00 00 FF FF
00C0  01 F5 0D 85  00 00 00 00  00 00 00 00  FF FF FF FF
00E0  59 AD FF 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  2C 80 00 00  26 00 FA 00  50 00 51 00  00 00 00 FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 02 FF
0010  00 00 00 FA  00 FA FF FF  FF FF FF FF  FF FF FF FF
0030  54 05 0C 06  FF 1F FF 1F  FF 1F FF 1F  FF 1F FF 1F
0040  FF 1F FF 1F  02 02 02 02  02 02 FF FF  FF FF 02 FF
0050  7F 7F 7F 7F  00 00 01 F5  0D 85 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 F0  E7 F8 80 F8  80 F8 80 01
0020  2C 02 07 00  00 00 EF F6  00 EF 00 00  00 00 00 00
T:   33    38   255   255   255    33    38    58    98    26    57   255   255   255   128    44
T:   33    38   255   255   255    33    38    53    97    26    57   255   255   255   128    44
T:   33    38   255   255   255    33    38    58    98    26    56   255   255   255   128    44
T:   33    38   255   255   255    33    38    58    98    26    53   255   255   255   128    44
T:   33    38   255   255   255    33    38    58    97    26    57   255   255   255   128    45
T:   33    38   255   255   255    33    38    48    96    26    56   255   255   255   128    45
V:  74   7F   D0   D0   7D   F6   3E   74   7F   D0   D0   7D   F6   3E   D6   CD   83   25   7C   3E   40   4E   00   [ VID = 1.24817 V ]
V:  74   7F   D0   D0   7D   F6   3E   74   7F   D0   D0   7D   F6   3E   D6   CD   83   25   7C   3E   40   4E   00   [ VID = 1.25293 V ]
V:  74   7F   D0   D0   7D   F6   3E   74   7F   D0   D0   7D   F6   3E   D6   CE   83   25   7C   3E   40   4E   00   [ VID = 1.25293 V ]
V:  74   7F   D0   D0   7D   F6   3E   74   7F   D0   D0   7D   F6   3E   D6   CE   83   25   7C   3E   40   47   00   [ VID = 1.02649 V ]
V:  74   7F   D0   D0   7D   F6   3E   74   7F   D0   D0   7D   F6   3E   D6   CE   83   25   7C   3E   4E   40   00   [ VID = 1.02649 V ]
V:  74   7F   D0   D0   7D   F6   3E   74   7F   D0   D0   7D   F6   3E   D6   CE   83   25   7C   3E   4E   40   00   [ VID = 1.02161 V ]
0000  74 7F D0 D0  7D F6 3E D6  CE 83 25 7C  3E 4E 40 00
0010  21 26 3A 62  1A 39 00 32  80 2A 26 26  21 34 3A 06
0020  21 02 59 AD  FF 60 00 00  00 00 00 00  00 00 54 13
0030  0C 13 FF 13  2E 13 FF 13  FF 13 01 F2  0D 97 00 00
0040  03 8A 00 00  00 00 00 00  00 00 00 00  59 AD FF C8
0050  FF FF 2C 80  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 26 00 FA  00 FF FF FF  FF FF FF FF  FF FF FF FF
T:   33    38    38    33    44    38   250   255
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
SMBus Port  : 0580
Can Have SPD: No
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Pump is working at 75.0 Hz, the pump's current is floating between 450 and 475 mA, it runs at 4500 rpm, The water quality is listed as 30%.
The Aquaero CPU's temperature is listed as 44,0°C (I think that's missing from your list).
   aquaerodump.txt
   Report.txt
Thank you. I'm afraid we need Aqua Computer's kind assistance to figure the missing bits out. They said they will be able to give us a hand next week, so stay tuned ;)
Thank you, we'll fix that.
Thanks a lot Fiery!
Sensor Properties
Temperatures
CPU 38 °C  (100 °F)
PCH 41 °C  (106 °F)
VRM 42 °C  (108 °F)
Cooling Fans
CPU 3461 RPM
Chassis #1 507 RPM
Fan #4 463 RPM
GPU1 26%
GPU2 26%
Voltage Values
CPU Core 1.024 V
CPU VRM 1.856 V
CPU Cache 1.041 V
+1.05 V 1.038 V
+3.3 V 3.344 V
+5 V 5.080 V
+12 V 12.000 V
VCCIO 1.044 V
VCCSA 1.000 V
VTT 1.048 V
PCH Core 1.047 V
PCH I/O 1.491 V
DIMM AB 1.203 V
DIMM CD 1.200 V
Fan #1 0.010 V
Fan #2 0.010 V
Fan #3 0.010 V
Fan #4 4.150 V
Power Values
CPU Package 0.60 W
GPU1: GPU TDP% 26%
GPU2: GPU TDP% 26%
Flow Sensors
Flow #1 38.80 LPH
Flow #2 0.00 LPH
Flow #3 0.00 LPH
Flow #4 0.00 LPH
Liquid Levels
Liquid #1 68%
Liquid #2 2%
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
SMBus Port  : 0580
Can Have SPD: No
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Can Have SPD: Yes
Scan Type   : Full
Thank you, we'll add the Aquaero temperature in the next beta ;)
From what I understand, any additives to the water affect the conductivity of the water (pure H2O is non-conductive), and consequently the result of the Water Quality calculation. And as you say, it can vary due to concentration variations and probably temperature variations. I think any particular reading does not in and of itself indicate a bad result, The usefulness of the water quality value range is in the delta of  the result over time... if the range drops, then particulates may have increased, and a water flush could be in order.
My Water Quality reading shows around 75 and that is without any additives other than a small amount of biocide.
Aquacomputer advised not to place too much emphasis on the Water Quality reading, nor on the Power Measurement.
Here's a new AIDA64 beta update ...
... where we've added the following new bits & pieces to the Aquaero/Aquaduct sensor module:
- SoC temperature (a.k.a. Aquaero CPU temperature)
- Pump #1 and Pump #2 speed (RPM) and current. We haven't added the frequency value since it's simply 1/60 of the RPM value, and not a separate measurement
- Power measurements (as Power #1 .. Power #4)
- Water quality (%), pressure sensor, uptime and total uptime. These values are only available on the Computer / Sensor page though
Now AIDA64 supports the upcoming new generation of firmware (FW Revision 2000) for Aquaero and Aquaduct devices. The new firmware revamps the HID input report layout, and introduces a few notable feature improvements as well. We haven't had a chance to test the new firmware yet, so the current code may or may not work perfectly. As soon as the new firmware is rolled out, please create a new Aquaero Dump and post it here, so we can analyze the registers output and make changes to AIDA64 if necessary.
Initially it mostly looks good.
I have only 1 pump, so there is no pump 2 info displayed.
I was wondering what the Hz parameter was as I am used to that referring to eletrical cycles per second... thank you for that info.
The Aquaduct 360 XT Mark V has only 3 fans, but I continue to show a Fan #4 VRM (wonder which fan that is)
   under voltage, fans 1 to 3 show 4.2 to 4.3 volts while the 4th fan shows 11.9 volts
   under cooling fans I show only 3 fans (which is correct)
The Aida64>Computer>Sensor display is very difficult to read currently due to resetting the page to the top when it updates.
http://h8bs.com/Report.txt
Thank you for the feedback and the report. On the Sensor page it should only reset the page position when the number of items on the page (the number of populated lines) changes. If it's possible, please try to find which value keeps disappearing and appearing again, that should be the one that causes the resets. If you could find the culprit, we can look into it ;)
It appears to be the Current Values and Power Values for the fans from the Aquaduct.
case1   case2   case3   case4
I do have firmware version 1020, and don't know if that is an issue.
One question, what is the Power Value listed as "Power #1" with values between 104W and 110W in the screenshots?
Edit:
one value I do not see that may be of interest is the alarm level.
Update to sensor page resetting to top:
This morning when I booted up, the sensor page display action varied a bit... firstly it appeared steady without resetting, and I noticed that none of the Aquaduct fans showed under the Current and Power Values. Then there were a couple of resets, but not enough for me to see what was changing, and it has been steady since with the fans current and power values missing.
case5
It seems the problem is that your fans sometimes report a meaningful current, while in many cases they report a zero current. The zero current can also be seen on the Aquasuite 2014 screen shot that you've posted about the alarm level. And when a measured fan current gets zero, AIDA64 will remove the line from the Sensor page and update the whole page since the number of list items changed.
Power #1 is the Power Measurement 1, as you can see it in Aquasuite 2014.
We'll add Actual Alarm Level in the next AIDA64 beta ;)
When my system is idling, and the heat load is low, the fans on the radiator do stop on occasion as determined by the presets on the controller.
I know some of these values have not made it to the sensorpanel yet, but assuming they will, if I have a graph running to plot fan speed, what happens to the sensorpanel when the fan stops? Do all inputs get ignored if they go to zero? Zero can be a valid value.
Hi everyone
I found this topic on my search for an integration of my AquaSuite sensor data into Aida64.
Are there any plans to support my components in a future release.
My System has an AquastreamXT pump and a MPS Flow/Temp sensor from Aqua Computer.
I used LCDHost for my G19 before but now I prefer the Aida64 LCD support.
Cheers
McPolli
That's fine of course, but the problem in your case is that your fan registers seem to report a zero current even when they're spinning. At least that's what I can see on the Alarm Level related screen shot of yours.
Most of the items are already on the SensorPanel. The ones missing are the Pressure, Water Quality, UpTime and Total UpTime. As for the zero fan speed, it will of course be indicated as a zero value on the graphs, as expected.
Hi everyone
Cheers
McPolli
You can already use the Aquaero sensor module in the latest AIDA64 Extreme beta update:
Yes, the fan speeds behave as expected in the SensorPanel, reporting the fan speed even if zero.
But in Aida64>Computer>Sensor the fans go away when their values go to zero.
Agreed, the fan current on the Aquasuite display does show zero when it should not, and I will take that up with Aquaxcomputer.
Edit: attachment deleted
Fan RPM speeds disappear from the Sensor page when they fall to zero, that's normal. It is done because many sensor chips feature 5 or more fan speed tachometers, but most motherboards will not use all of them, and users will usually just use 1 or 2 out of those actually. And it wouldn't make much sense to show a lot of stopped fans when actually just a few of those are actually connected. Sadly, sensor chips are not capable of telling monitoring software which fan tachometer input actually has a connected fan. There's no contact or pressure sensor built into fan headers to indicate that the fan header is currently utilized/connected :(
While on the other hand, when you build your SensorPanel, you will not drop such fan speed readings on your panel that are not connected, so it's vital to see not spinning fans there, and not hide them.
I know that sometimes the logic AIDA64 uses about hardware monitoring may sound twisted or not logical at all, but usually it's just designed that way to ensure a great user experience.
