Koithim Posted October 21, 2020 Posted October 21, 2020 Hey there, Installed the new card but i do not see all the sensors, like i did on my 2080 ti. Also, when the GPU is idle (low clock) the GPU Clock field on my sensor panel and LCD appear and disappear sometime. Also, app takes way longer to load. If any logs are needed just let me know. Cheers! K Quote
slowburn Posted October 23, 2020 Posted October 23, 2020 Having the same issues. Can anyone from aida64 comment? thanks Quote
Fiery Posted October 25, 2020 Posted October 25, 2020 On 10/21/2020 at 11:43 PM, Koithim said: Hey there, Installed the new card but i do not see all the sensors, like i did on my 2080 ti. Also, when the GPU is idle (low clock) the GPU Clock field on my sensor panel and LCD appear and disappear sometime. Also, app takes way longer to load. If any logs are needed just let me know. Cheers! K We're rolling out a new AIDA64 update in 48 hours that will fix GPU support for RTX 3000 Series. Quote
silvertuna Posted October 25, 2020 Posted October 25, 2020 Additionally, I do not see the ICX temp sensors showing either? Quote
schrutic Posted October 25, 2020 Posted October 25, 2020 Just to tag along to this... There are only 2 GPU fans displaying as well while the 3080 has 3 GPU fans. I'm excited to see the new update correct all of this! :) Quote
Fiery Posted October 26, 2020 Posted October 26, 2020 21 hours ago, silvertuna said: Additionally, I do not see the ICX temp sensors showing either? ICX3 is not supported by AIDA64 yet, but we'll work on it 1 Quote
Zoork Posted October 27, 2020 Posted October 27, 2020 With the new Final Version the same problems - when the GPU is in idle, Clock field on sensor panel still appear and disappear, i think this happens only when the GPU ist very cold, i use watercooling - also the memory frequency reading is wrong, it shows only the double rate. My card ist a RTX 3080FE! Quote
Fiery Posted October 27, 2020 Posted October 27, 2020 49 minutes ago, Zoork said: With the new Final Version the same problems - when the GPU is in idle, Clock field on sensor panel still appear and disappear, i think this happens only when the GPU ist very cold, i use watercooling - also the memory frequency reading is wrong, it shows only the double rate. My card ist a RTX 3080FE! Thank you for your feedback on AIDA64 v6.30. Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Koithim Posted October 28, 2020 Author Posted October 28, 2020 Here it is: ------[ Versions ]------ Program Version : AIDA64 Extreme v6.30.5500 BenchDLL Version: 4.5.837.8-x64 Windows Version : Microsoft Windows 10 Pro 10.0.19041.572 (64-bit) GetProductInfo : 0x00000030 ------[ Video Adapters ]------ EVGA RTX 3090 FTW3 Ultra Gaming (24G-P5-3987) [10DE-2204 / 3842-3987 / Rev A1] ------[ Video Driver ]------ nvapi.dll: 27.21.14.5698 - nVIDIA ForceWare 456.98 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_54b043161defc764\nvldumd.dll ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------ ------[ nVIDIA I2C Device GPU #1 / B04-D2D ]------ 0000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 07 07 07 07 FF FF FF FF 20 20 20 20 20 04 FF FF ........ ... 0060 04 02 12 12 12 12 FF FF 05 0A 0A 0A 0A FF FF FF ................ 0070 04 FF FF FF FF FF FF FF 08 08 FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 04 04 04 04 FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 04 01 FF FF FF FF FF 20 FF 20 FF FF FF FF FF FF ....... . ...... 00B0 20 05 04 FF FF FF 04 FF FF FF 09 09 FF FF FF FF ............... 00C0 09 04 04 04 04 09 09 09 09 03 03 03 03 1E 1E 1E ................ 00D0 1E 03 03 03 03 06 06 06 06 03 03 03 03 1E 1E 1E ................ 00E0 1E 09 09 09 09 04 04 FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA I2C Device GPU #1 / B04-D2D ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 0107 0107 0207 0207 FFFF FFFF FFFF FFFF 5820 5820 5820 5820 5820 0004 FFFF FFFF 0060 0104 0002 C412 AE12 1612 1612 FFFF FFFF 0005 000A 000A 000A 000A FFFF FFFF FFFF 0070 0004 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF08 C708 FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 9E04 9E04 9E04 9E04 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 C004 0301 FFFF FFFF FFFF FFFF FFFF FE20 FFFF FE20 FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FF20 FC05 FC04 FFFF FFFF FFFF 0004 FFFF FFFF FFFF BA09 BA09 FFFF FFFF FFFF FFFF 00C0 0109 FF04 FF04 FF04 FF04 FF09 FF09 FF09 FF09 FF03 FF03 FF03 FF03 FF1E FF1E FF1E 00D0 FF1E FF03 FF03 FF03 FF03 FF06 FF06 FF06 FF06 FF03 FF03 FF03 FF03 FF1E FF1E FF1E 00E0 FF1E 3C09 3C09 3C09 3C09 0704 0704 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ Chips Found ]------ GPU1-B04-D2D: ***** Unknown Device ***** Total : 5.3 sec GPU1-B00: 0.7 sec GPU1-B01: 0.7 sec GPU1-B02: 0.6 sec GPU1-B03: 0.7 sec GPU1-B04: 2.0 sec ---------------------------------------------------------------------------------- Cheers! K nvidiagpureg.txt Quote
Fiery Posted October 28, 2020 Posted October 28, 2020 9 hours ago, Koithim said: Here it is: [...] Thank you! We've checked and memory clock should be reported properly. Can you please post a screen shot of the Display / GPU page when the memory is running at its highest frequency? Quote
Koithim Posted October 28, 2020 Author Posted October 28, 2020 Here is the screenshot. Thank you! Cheers! K Quote
schrutic Posted October 29, 2020 Posted October 29, 2020 Hello @Fiery Should the latest update show all 3 fans for this graphics card? I am only seeing 2 fans at the moment. Thanks! 1 Quote
Jsunn Posted October 30, 2020 Posted October 30, 2020 Same question here. Not seeing GPU clock speed on my EVGA FTW3 3090 Ultra Quote
adomas Posted October 31, 2020 Posted October 31, 2020 Just bought AIDA64 and now when I use SensorPanel to display stuffs on my 2nd screen, my GTX 3090 GPU Clock is blinking. Sometimes it shows the Clock, but on some refresh there is no label, nothing, GPU Clock disappears. Another minor issue is that I have 3 fans on GPU, but only 2 fans speeds are shown. As I understand AIDA64 does not fully support RTX 3090 yet, right? When I could expect to get an update? My Graphics Card model is Asus ROG-Strix-RTX3090-O24G-Gaming Quote
Fiery Posted November 19, 2020 Posted November 19, 2020 On 10/31/2020 at 2:15 PM, adomas said: Just bought AIDA64 and now when I use SensorPanel to display stuffs on my 2nd screen, my GTX 3090 GPU Clock is blinking. Sometimes it shows the Clock, but on some refresh there is no label, nothing, GPU Clock disappears. Another minor issue is that I have 3 fans on GPU, but only 2 fans speeds are shown. As I understand AIDA64 does not fully support RTX 3090 yet, right? When I could expect to get an update? My Graphics Card model is Asus ROG-Strix-RTX3090-O24G-Gaming We've fixed the GPU flickering issue as well as implemented support for EVGA iCX3 in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
elitegamer352 Posted December 1, 2020 Posted December 1, 2020 I Downloaded the beta driver and I can only see 2 fans still using my aorus 3080 master. Quote
Fiery Posted January 6, 2021 Posted January 6, 2021 On 12/1/2020 at 3:10 AM, elitegamer352 said: I Downloaded the beta driver and I can only see 2 fans still using my aorus 3080 master. Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Make sure to use AIDA64 v6.32 (latest version). Thanks, Fiery Quote
elitegamer352 Posted January 10, 2021 Posted January 10, 2021 On 1/6/2021 at 3:14 PM, Fiery said: Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Make sure to use AIDA64 v6.32 (latest version). Thanks, Fiery Here you go just updated to the latest beta driver also to see if it fixed the non 3 FAN issue and it did not. But what the beta did do was give me a N/A for my gpu temp. All i had to do was reactivate the temp in it and that fixed it. Thanks for looking into this for me. I am using the Aorus 3080 Master gpu . ------[ Versions ]------ Program Version : AIDA64 Extreme v6.32.5609 Beta BenchDLL Version: 4.5.841.8-x64 Windows Version : Microsoft Windows 10 Pro 10.0.19042.685 (64-bit) GetProductInfo : 0x00000030 ------[ Video Adapters ]------ Gigabyte Aorus RTX 3080 Master 10G (GV-N3080AORUS M-10GD) [10DE-2206 / 1458-403E / Rev A1] ------[ Video Driver ]------ nvapi.dll: 27.21.14.6089 - nVIDIA ForceWare 460.89 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll ------[ nVIDIA GPU #1 @ mem A2000000 ]------ Video Adapter = Gigabyte Aorus RTX 3080 Master 10G (GV-N3080AORUS M-10GD) GPU Code Name = GA102-200-A1 PCI Device = 10DE-2206 / 1458-403E [Rev A1] GPU Clocks = 1845 / 0 / 0 MHz Memory Clock = 1187 MHz GPU Base Clock = 13500 kHz Shader Base Clock = 13500 kHz Memory Base Clock = 13500 kHz nvidia-000000 = B72000A1 [GA102] nvidia-001538 = 800003FF nvidia-001704 = 8027FF71 nvidia-001714 = C027FF72 nvidia-00E114 = 0000021C nvidia-00E118 = 0000021C nvidia-00E11C = 00000001 nvidia-00E120 = 00000000 nvidia-020008 = 00002AD7 nvidia-020014 = 023801E1 nvidia-0200C4 = 000000D8 nvidia-0200C8 = 00000000 nvidia-0200D8 = 010000D8 nvidia-0200DC = 00000000 nvidia-020340 = 0000C0A0 nvidia-020344 = 000080A0 nvidia-020348 = 00000360 nvidia-020400 = 00000025 nvidia-021000 = FFFFFFCF nvidia-022400 = 00000000 nvidia-022430 = 00000007 nvidia-022434 = 00000006 nvidia-022438 = 00000006 nvidia-02243C = 00000006 nvidia-022440 = 00000004 nvidia-088000 = 220610DE [GA102] nvidia-08A000 = 1AEF10DE nvidia-100714 = 0000006B nvidia-101000 = 00400080 nvidia-10100C = 02013000 nvidia-120070 = 00100001 nvidia-120074 = 00000005 nvidia-120078 = 00000006 nvidia-122634 = 00000008 nvidia-300000 = EB7FAA55 nvidia-310000 = 485A3B74 nvidia-700000 = 00000000 nvidia-7E0000 = 0000BEEF ------[ nVIDIA GPU #1 / ForceWare Properties ]------ Memory Type = 15 (GDDR6X) Memory Vendor = 10 (Micron) Memory Bank Count = 1 Memory Bus Width = 320-bit GPU / MC / VE / BI Load = 8 / 1 / 0 / 1 VPE Count = 0 Shader Pipe Count = 6 Shader SubPipe Count = 34 Total SP Count = <unknown> Total TPC Count = 0 Total SM Count = <unknown> Core Count = 8704 ROP Count = 96 Partition Count = 5 (mask: 00000037) Fan RPM = <unknown> Fan Duty Cycle = <unknown> All Fans RPM & Duty = 1053 RPM / 1055 RPM / 53 % / 58 % Core Voltage = <unknown> Core Rail Voltage = 925000 uV Current Pstate = 0 PerfCap Reason = 16 (Utilization) Ventura State = 0 (unsupported) Physical Frame Buffer Size = 10485120 KB Virtual Frame Buffer Size = 10485760 KB Total / Free Video Memory = 10485760 KB / 8610660 KB ------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------ Perf. Levels = 5 Active Profile = 4 curr-core/shader/mem-0 = 420 MHz / 0 MHz / 405 MHz curr-core/shader/mem-1 = 420 MHz / 0 MHz / 810 MHz curr-core/shader/mem-2 = 480 MHz / 0 MHz / 5001 MHz curr-core/shader/mem-3 = 480 MHz / 0 MHz / 9251 MHz curr-core/shader/mem-4 = 480 MHz / 0 MHz / 9501 MHz [Active] orig-core/shader/mem-0 = 420 MHz / 0 MHz / 405 MHz orig-core/shader/mem-1 = 420 MHz / 0 MHz / 810 MHz orig-core/shader/mem-2 = 480 MHz / 0 MHz / 5001 MHz orig-core/shader/mem-3 = 480 MHz / 0 MHz / 9251 MHz orig-core/shader/mem-4 = 480 MHz / 0 MHz / 9501 MHz [Active] ------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------ Perf. Levels = 5 Active Profile = 2 curr-core/shader/mem-0 = 420 MHz / 0 MHz / 405 MHz curr-core/shader/mem-1 = 420 MHz / 0 MHz / 810 MHz curr-core/shader/mem-2 = 480 MHz / 0 MHz / 5001 MHz [Active] curr-core/shader/mem-3 = 480 MHz / 0 MHz / 9251 MHz curr-core/shader/mem-4 = 480 MHz / 0 MHz / 9501 MHz orig-core/shader/mem-0 = 420 MHz / 0 MHz / 405 MHz orig-core/shader/mem-1 = 420 MHz / 0 MHz / 810 MHz orig-core/shader/mem-2 = 480 MHz / 0 MHz / 5001 MHz [Active] orig-core/shader/mem-3 = 480 MHz / 0 MHz / 9251 MHz orig-core/shader/mem-4 = 480 MHz / 0 MHz / 9501 MHz ------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------ Perf. Levels = 1 Active Profile = 255 curr-core/mem-0 = 600 MHz / 5001 MHz orig-core/boost/mem-0 = 1440 MHz / 1845 MHz / 9501 MHz ------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------ Perf. Levels = 1 Active Profile = 255 curr-core/mem-0 = 555 MHz / 5001 MHz orig-core/boost/mem-0 = 1440 MHz / 1845 MHz / 9501 MHz ------[ nVIDIA GPU #1 / BIOS Info ]------ BIOS Version = 94.02.26.C0.97 Signon Message = GV-N3080AORUS M-10GD/F1/0ACB Bootup Core Clock = 0 MHz Bootup Shader Clock = 1593262 MHz Bootup Mem Clock = 0 MHz Ref. Clock 4000 = 0 kHz = 0 MHz *4 Ref. Clock 4008 = 0 kHz = 0 MHz *4 [Memory] Ref. Clock 4010 = 0 kHz = 0 MHz *4 Ref. Clock 4018 = 0 kHz = 0 MHz *4 Ref. Clock 4020 = 0 kHz = 0 MHz *4 [Shader] Ref. Clock 4028 = 0 kHz = 0 MHz *4 [GPU] Ref. Clock 4030 = 0 kHz = 0 MHz *4 Ref. Clock 4038 = 0 kHz = 0 MHz *4 Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 1593262 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 125 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 1 MHz Shader Clock = 79979168 MHz Mem Clock = 79977696 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 1 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 1 % Core Clock = 80149012 MHz Shader Clock = 80149028 MHz Mem Clock = 80149012 MHz Geom. Delta = 12950833 MHz Core Voltage = 0.00 V Fan Speed = 275 % Core Clock = 267198672 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 555 % Core Clock = 5001 MHz Shader Clock = 290642980 MHz Mem Clock = 168000392 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 167687652 % Core Clock = 290642948 MHz Shader Clock = 222883004 MHz Mem Clock = 290642916 MHz Geom. Delta = 223313604 MHz Core Voltage = 0.00 V Fan Speed = 289590624 % Core Clock = 289590488 MHz Shader Clock = 167596468 MHz Mem Clock = 289192668 MHz Geom. Delta = 288936860 MHz Core Voltage = 0.00 V Fan Speed = 290287104 % Core Clock = 0 MHz Shader Clock = 222870208 MHz Mem Clock = 222902032 MHz Geom. Delta = 289590416 MHz Core Voltage = 0.00 V Fan Speed = 289590320 % Core Clock = 289590272 MHz Shader Clock = 267132428 MHz Mem Clock = 266818880 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 8610660 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 251024664 MHz Shader Clock = 266813524 MHz Mem Clock = 267153256 MHz Geom. Delta = 267153296 MHz Core Voltage = 0.00 V Fan Speed = 1440 % Core Clock = 1845 MHz Shader Clock = 0 MHz Mem Clock = 9501 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 286588940 % Core Clock = 267385364 MHz Shader Clock = 266805668 MHz Mem Clock = 0 MHz Geom. Delta = 1 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 65281 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 555 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 5001 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 1440 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 1845 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 9501 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 289764376 MHz Mem Clock = 0 MHz Geom. Delta = 79990852 MHz Core Voltage = 0.00 V Fan Speed = 3 % Core Clock = 10485760 MHz Shader Clock = 1 MHz Mem Clock = 1053 MHz Geom. Delta = 1055 MHz Core Voltage = 0.00 V Fan Speed = 58 % Core Clock = 1 MHz Shader Clock = 1 MHz Mem Clock = 132336696 MHz Geom. Delta = 10485760 MHz Core Voltage = 0.00 V Fan Speed = 1 % Core Clock = 0 MHz Shader Clock = 50331809 MHz Mem Clock = 1077810264 MHz Geom. Delta = 570822878 MHz Core Voltage = 0.00 V Fan Speed = 1768124508 % Core Clock = 1680879967 MHz Shader Clock = 1931884080 MHz Mem Clock = 842162038 MHz Geom. Delta = 1701062245 MHz Core Voltage = 0.00 V Fan Speed = 875652403 % Core Clock = 1633646181 MHz Shader Clock = 892822070 MHz Mem Clock = 962736946 MHz Geom. Delta = 640951089 MHz Core Voltage = 0.00 V Fan Speed = 1633890683 % Core Clock = 912338224 MHz Shader Clock = 1664115001 MHz Mem Clock = 761344053 MHz Geom. Delta = 875379001 MHz Core Voltage = 0.00 V Fan Speed = 946103396 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 7.50412287910608896E20 V Fan Speed = 775037005 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 109957120 MHz Mem Clock = 0 MHz Geom. Delta = 1755996160 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 0 % Diode Gain Mul = 0 Diode Gain Div = 0 Diode Offset Mul = 0 Diode Offset Div = 0 Diode Offset Bin Mul = 0 Diode Offset Bin Div = 1 Temp Compensation Mul = 0 Temp Compensation Div = 1 Max Div = 0 Measured Temp Threshold (Raw) = 0 Measured Temp Threshold (Int) = 0 Celsius Measured Temp Threshold (Float) = 0 Celsius BIOS Temp Threshold = 125 Celsius Measured Diode Temp (Raw) = 0 Measured Diode Temp (Int) = 0 Celsius Measured Diode Temp (Float) = 0 Celsius Diode Temp by ForceWare = 33 Celsius ------[ NVAPI GPU Handles ]------ GPU Count = 1 GPU #1 = 00000100 ------[ nVIDIA GPU #1 / Thermal Settings V2 ]------ Sensor Count = 1 Sensor #0 / Controller = GPU Internal Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 33 Celsius ------[ nVIDIA GPU #1 / Thermal Settings V1 ]------ Sensor Count = 1 Sensor #0 / Controller = GPU Internal Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 33 Celsius ------[ Versions ]------ Program Version : AIDA64 Extreme v6.32.5609 Beta BenchDLL Version: 4.5.841.8-x64 Windows Version : Microsoft Windows 10 Pro 10.0.19042.685 (64-bit) GetProductInfo : 0x00000030 ------[ Video Adapters ]------ Gigabyte Aorus RTX 3080 Master 10G (GV-N3080AORUS M-10GD) [10DE-2206 / 1458-403E / Rev A1] ------[ Video Driver ]------ nvapi.dll: 27.21.14.6089 - nVIDIA ForceWare 460.89 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2635d5c616c804dc\nvldumd.dll ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------ Total : 8.1 sec GPU1-B00: 1.3 sec GPU1-B01: 1.0 sec GPU1-B02: 0.9 sec GPU1-B03: 0.9 sec GPU1-B04: 0.8 sec Quote
Fiery Posted January 12, 2021 Posted January 12, 2021 On 1/10/2021 at 9:23 PM, elitegamer352 said: Here you go just updated to the latest beta driver also to see if it fixed the non 3 FAN issue and it did not. But what the beta did do was give me a N/A for my gpu temp. All i had to do was reactivate the temp in it and that fixed it. Thanks for looking into this for me. I am using the Aorus 3080 Master gpu . Thank you for your feedback. I'm afraid so far we haven't found a way to report the 3rd fan on Gigabyte RTX 3080/3090 video cards as well as on Asus Strix RTX 3080/3090 cards. In your dumps I cannot see a 3rd fan, so these new Aorus cards must use a new, proprietary interface to report the RPM for the 3rd fan. BTW, can you see all 3 fans reporting individual RPM readings in Gigabyte's own monitoring utility? Quote
elitegamer352 Posted January 14, 2021 Posted January 14, 2021 On 1/12/2021 at 4:16 AM, Fiery said: Thank you for your feedback. I'm afraid so far we haven't found a way to report the 3rd fan on Gigabyte RTX 3080/3090 video cards as well as on Asus Strix RTX 3080/3090 cards. In your dumps I cannot see a 3rd fan, so these new Aorus cards must use a new, proprietary interface to report the RPM for the 3rd fan. BTW, can you see all 3 fans reporting individual RPM readings in Gigabyte's own monitoring utility? Hi thanks for the response. Yes if I use auros engine and open up the fan settings it shows fans 1/2 and then fan 3 Quote
Fiery Posted January 14, 2021 Posted January 14, 2021 9 hours ago, elitegamer352 said: Hi thanks for the response. Yes if I use auros engine and open up the fan settings it shows fans 1/2 and then fan 3 We've been notified today that fan#2 and fan#3 are coupled together on Aorus RTX 3000 Series video cards and so they will spin at the same RPM and use the same duty cycle setting (fan speed %). Hence what AIDA64 measures as GPU2 Fan will apply to fan#3 too. Quote
