tr64 Posted August 3, 2014 Share Posted August 3, 2014 Thank you for supporting the AlphaCool LCD natively in AIDA64. It works great! One question, though. In the old AlphaLCD software, there was an option to blank the screen and turn off the LCD backlight when Windows shuts down. Is there anything similar in AIDA64? As it stands right now, AIDA64 leaves the display turned on when I shut down my computer. Thanks. Taylor Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 3, 2014 Share Posted August 3, 2014 AIDA64 is supposed to turn all LCDs off when it exits. Not all LCDs support that feature, but AlphaCool does. What happens on your computer when you close AIDA64? Quote Link to comment Share on other sites More sharing options...
tr64 Posted August 3, 2014 Share Posted August 3, 2014 If I exit AIDA64 while Windows is still running, it blanks the LCD and turns off the backlight, as desired. But if I shut down Windows without manually exiting AIDA64 first, then the LCD gets left on. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 4, 2014 Share Posted August 4, 2014 If I exit AIDA64 while Windows is still running, it blanks the LCD and turns off the backlight, as desired. But if I shut down Windows without manually exiting AIDA64 first, then the LCD gets left on. It sounds a bit odd. Are you shutting down Windows, or putting the computer to sleep or standby or hibernation? And what motherboard and Windows do you use? We'll try to reproduce the issue on a similar test system if possible. Quote Link to comment Share on other sites More sharing options...
tr64 Posted August 4, 2014 Share Posted August 4, 2014 Normal Windows shut down. I am running Windows 7 Pro on an ASUS Sabertooth Z97 Mark 2 motherboard with an Intel Core i7-4790K CPU. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 8, 2014 Share Posted August 8, 2014 We've fixed the LCD blanking issues at Windows shutdown, system restart, sleep and standby. Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild3110hdscrnq9zvzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote Link to comment Share on other sites More sharing options...
tr64 Posted August 20, 2014 Share Posted August 20, 2014 Seems to be working. Thanks. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 20, 2014 Share Posted August 20, 2014 Seems to be working. Thanks. Thank you for the feedback Quote Link to comment Share on other sites More sharing options...
namuk Posted January 18, 2015 Author Share Posted January 18, 2015 old thread but may as well ask here , the built in support for the alphacool does it use it,s own usb driver? the SDC Megatron works fine with all the software installed all i do is disable it, the alpha though it does not start i.e init failed, but the software/driver is installed, the odd thing now though if i try the second alpha screen that works never did before, got asked to test this a while ago just did not have the time, must be a conflict somewhere. got to say love this built in support it has been a while as well lol. Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 18, 2015 Share Posted January 18, 2015 AlphaCool LCD support requires the AlphaCool LibUSB drivers to be installed. Just install the AlphaCool software bundle, and it should install the driver too. 1 Quote Link to comment Share on other sites More sharing options...
namuk Posted January 19, 2015 Author Share Posted January 19, 2015 thanks .. i have the Usb driver separate as well think its a later one that is in the package. Quote Link to comment Share on other sites More sharing options...
Woodmaniac Posted February 21, 2015 Share Posted February 21, 2015 Please excuse my English school was 20 years ago Thanks for the Great performance that your team delivers here . Will it even be possible to operate the display vertically so that I could block the display standing ?Greeting Michael Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 24, 2015 Share Posted February 24, 2015 I'm afraid we currently have no plans to support portrait mode for landscape external LCD screens. Quote Link to comment Share on other sites More sharing options...
spaljeni Posted March 16, 2015 Share Posted March 16, 2015 Thanks a lot for making this possible Finally my Display is useful again Quote Link to comment Share on other sites More sharing options...
Tyrargo Posted March 23, 2015 Share Posted March 23, 2015 spaljeni can u send me your file please? the aida64 editor is not so comfortable as the alphacool editor itself. Quote Link to comment Share on other sites More sharing options...
spaljeni Posted March 23, 2015 Share Posted March 23, 2015 You can draw up anything you like on a 240 x 128 picture (I used Adobe Fireworks to do that) and then just put the values and text into place. It takes a bit of time and fiddling around with the Aida64 editor but it is worth it in the end. Here is the background without any values from Aida64: You can Save the image if you want to use it. First thing you need to do in the editor is choose "Image" and browse for where you saved this picture. Then you can add values and text and put them into place using the arrows in the editor. I used Histogram type graphs for CPU / VGA / NIC Download and Upload rate (note that they cannot be smaller than 10 x 10 pixels) The rest is just Static Labels and Simple Sensor Items. Quote Link to comment Share on other sites More sharing options...
beeonline Posted March 24, 2015 Share Posted March 24, 2015 Thanks a lot for making this possible Finally my Display is useful again This looks great, man! Quote Link to comment Share on other sites More sharing options...
noleafwilen Posted March 26, 2015 Share Posted March 26, 2015 Hi there.... I've got an Alphacool LCD since 2006... but i only worked with him for 2 years... Since 2008 ...its on the box Now i have a modern computer and wanted to activate the lcd again to show me temps, rpm, etc etc... can any of you guys show a tutorial how to put this awesome lcd back to work with aida64 for me..... having dificulties to install everything... thankx in advance. Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 26, 2015 Share Posted March 26, 2015 Just a quick guide, please let me know if you have difficulties with this, and at which point do you have issues: 1) Connect the AlphaCool LCD to the USB port of your computer 2) Download and install the latest version of AlphaLCD: AlphaLCD 1.0.4.48 Beta 3) Start AIDA64 (latest version: v5.20), go to main menu / File / Preferences / Hardware Monitoring / LCD, select the AlphaCool tab, and tick the checkbox to enable the AlphaCool LCD support 4) It should say "AlphaCool Init OK" with green colour once you've enabled the checkbox 5) Keep the Preferences open, and go to the next page called LCD Items. Press the New button or double-click in the empty list of items to add a new item to your LCD layout. If you have difficulties building your layout, refer to the following video: Note that the 2 most popular AIDA64 visual monitoring modules, SensorPanel and LCD both use the same layout building solution and the same rendering engine. So whatever you read or watch about SensorPanel, will also apply to the LCD module. Quote Link to comment Share on other sites More sharing options...
ivoradev Posted March 27, 2015 Share Posted March 27, 2015 I would like to thank very much to everyone that made this here possible, the devs and the users. Your efforts made a part of my pc that was just there and did nothing for years to become alive again and show all the things that I like. Many many thanks! Best regards, Ivo P.S. Did I mention it, that I am very very glad that it works from within the AIDA? No need to use AlphaCool's SW anymore... YAY! Quote Link to comment Share on other sites More sharing options...
noleafwilen Posted April 12, 2015 Share Posted April 12, 2015 Great. Now the alphacool's is ready for action again... Thank you very much. Now i can chose whatever i need to show in the LCD.... Awesome. Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 28, 2015 Share Posted June 28, 2015 Please excuse my English school was 20 years ago Thanks for the Great performance that your team delivers here . Will it even be possible to operate the display vertically so that I could block the display standing ? Greeting Michael We've implemented portrait mode support for AlphaCool displays in the latest AIDA64 Extreme beta update available at: http://www.aida64.com/downloads/latesta64xebeta Quote Link to comment Share on other sites More sharing options...
namuk Posted June 28, 2015 Author Share Posted June 28, 2015 edited first post with direct links for just usb driver 2.1 and the AlphaLCD 1.0.4.48 Beta software to save people faffing around searching Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 28, 2015 Share Posted June 28, 2015 edited first post with direct links for just usb driver 2.1 and the AlphaLCD 1.0.4.48 Beta software to save people faffing around searching Thank you Quote Link to comment Share on other sites More sharing options...
namuk Posted June 28, 2015 Author Share Posted June 28, 2015 Thank you Np, imop you all need and others need a bigger thank you for making Alphalcd useful again have you noticed the screens are for sale again you can even get the external surround i always thought they stopped doing them years ago. Quote Link to comment Share on other sites More sharing options...
