eiwoh Posted November 22, 2014 Posted November 22, 2014 I'm not getting the flow rate from my Aquacomputer flow sensor. I have 4 flow sensors listed on the sensor page but all 4 have a 0.00 LPH reading. I'm using the latest beta v4.70.3237. I do have the high flow USB sensor connected to the Aquaero 6 Pro via the aquabus connection. Its displayed in the aquasuite as the third flow sensor and I have a good reading there. Flow 2 is one of the Fan channels and when I enable that I do see that value as Flow 2. Is the MPS high flow USB flow sensor currently not compatible with AIDA64? I've attached my sensor debug in case that helps. Sensor Properties Sensor Type Nuvoton NCT6776F (ISA 290h) GPU Sensor Type Diode, CHiL CHL8318 (NV-Diode, 44h) Motherboard Name Asus Sabertooth X79 Chassis Intrusion Detected Yes Temperatures Motherboard 37 °C (99 °F) CPU 19 °C (66 °F) CPU Package 35 °C (95 °F) CPU #1 / Core #1 22 °C (72 °F) CPU #1 / Core #2 21 °C (70 °F) CPU #1 / Core #3 24 °C (75 °F) CPU #1 / Core #4 19 °C (66 °F) CPU #1 / Core #5 23 °C (73 °F) CPU #1 / Core #6 25 °C (77 °F) PCH 33 °C (91 °F) SoC 32 °C (90 °F) Fan #1 VRM 24 °C (75 °F) Fan #2 VRM 24 °C (75 °F) Fan #3 VRM 23 °C (73 °F) Fan #4 VRM 23 °C (73 °F) GPU Diode 26 °C (79 °F) GPU VRM 26 °C (79 °F) Temperature #1 25 °C (77 °F) Temperature #2 26 °C (79 °F) Temperature #3 26 °C (79 °F) Temperature #4 26 °C (79 °F) Temperature #5 26 °C (79 °F) Temperature #6 25 °C (77 °F) WDC WD4001FAEX-00MJRA0 36 °C (97 °F) KINGSTON SKC100S3480G 34 °C (93 °F) Cooling Fans CPU 3470 RPM CPU OPT 2721 RPM System 4515 RPM PCH 2866 RPM Chassis #1 796 RPM Chassis #2 1525 RPM Chassis #3 5823 RPM Chassis #4 5830 RPM Fan #1 1232 RPM Fan #3 1351 RPM GPU 37% Voltage Values CPU Core 1.128 V +3.3 V 3.280 V +5 V 5.000 V +12 V 12.192 V +5 V Standby 5.139 V Fan #1 11.720 V Fan #3 11.700 V GPU Core 0.900 V GPU +12V 12.422 V GPU VRM 0.893 V Current Values Fan #1 0.19 A Fan #3 0.22 A GPU VRM 12.50 A Power Values CPU Package 45.07 W CPU IA Cores 36.47 W Fan #1 2.27 W Fan #3 2.61 W Power #2 1033.00 W GPU TDP% 17% GPU VRM 11.50 W Flow Sensors Flow #1 0.00 LPH Flow #2 0.00 LPH Flow #3 0.00 LPH Flow #4 0.00 LPH Aquaero UpTime 6138620 sec (71 days, 1 hours, 10 min, 20 sec) Total UpTime 7062539 sec (81 days, 17 hours, 48 min, 59 sec) Actual Alarm Level 0 ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-122211-Chipset$1APEQ016_BIOS DATE: 07/25/14 11:01:08 VER: 48.01 Motherboard Model : Asus Sabertooth X79 Motherboard Chipset : Intel Patsburg X79, Intel Ivy Bridge-E DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : SABERTOOTH X79 DMI MB Version : Rev 1.xx DMI MB Serial : 140120931600217 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 4801 ------[ GPIO @ isa 0500 ]------ 0000 C3 E1 7F BF C3 6F A3 09 00 00 00 00 FF 7E D9 EA 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 08 00 00 00 00 00 00 00 00 00 02 68 00 00 0030 FF F0 83 83 F4 FF F6 1F 27 FF 82 BF 00 00 00 00 ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h) ITE SuperIO Device ID = 0000h (0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port/60 = 0290h (0290h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = C333h (C333h / 0000h) Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1 Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------ 0000 04 99 04 33 00 FF FF FF FF FF FF FF FF FF FF FF 0010 04 99 00 99 33 99 FF FF 40 00 00 00 00 84 00 00 0020 94 7F CD CD 7D FF BA 25 FF FF FF DA 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 0040 03 00 50 FF FF 00 3F FF 2D FF FF FF 18 05 00 A3 0050 FF FF FF FF FF FF FF FF C1 FF FF FF FF 05 00 FF 0060 00 FF FF FF FF 01 07 FF FF FF FF FF FF FF FF FF 0070 00 0A 00 13 80 13 80 13 80 FF FF FF FF FF FF FF 0080 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00 0090 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4 00A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 01 01 00B0 00 00 00 00 00 00 2B 00 1C 00 00 34 28 00 C4 FF 00C0 01 00 00 00 00 00 00 00 00 10 01 FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------ 0000 0C 00 40 01 01 01 01 3C FF 99 FF FF 00 FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 00 1E 46 46 46 FF FF 99 FF FF FF FF FF FF FF FF 0030 FF 00 FF FF 00 4B FF FF 02 01 00 00 00 00 00 00 0040 FF FF FF FF FF 31 03 FF FF FF FF FF FF FF 00 FF 0050 7F 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------ 0000 0C 32 40 01 01 01 01 3C FF 33 FF FF 00 FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 00 14 41 46 46 FF FF 33 B2 FF FF FF FF FF FF FF 0030 FF 00 FF FF 00 4B FF FF 02 01 00 00 00 00 00 00 0040 FF FF FF FF FF 8E 0D FF FF FF FF FF FF FF 00 FF 0050 00 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------ 0000 0C 00 40 01 01 01 01 3C FF 99 FF FF 00 FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 00 1E 46 46 46 FF FF 99 FF FF FF FF FF FF FF FF 0030 FF 00 FF FF 00 4B FF FF 02 01 00 00 00 00 00 00 0040 FF FF FF FF FF A1 0A FF FF FF FF FF FF FF 00 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 0020 FF FF FF 90 6A 90 6A ED AF FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 3F 00 00 FF FF FF FF FF FF FF FF FF FF FF 00 FF 0050 00 13 FF FF 00 00 00 FF 00 FE 1F B3 09 FF FF FF 0060 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------ 0000 FF FF 00 00 00 00 FF FF FF FF FF FF FF 00 00 FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 0050 D4 CD 80 FF 00 00 00 00 FF FF FF FF FF FF FF FF 0060 00 00 00 00 00 00 07 00 01 FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------ 0000 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF 01 02 03 01 01 01 FF 00 00 00 25 25 25 07 FF 0030 33 14 0C 05 0F 10 09 0D FF 1F 00 00 00 00 00 00 0040 00 00 00 00 02 02 02 FF FF FF FF FF FF FF 00 FF 0050 7F 7F 7F 7F 7F 7F 03 31 0D 8E 0A A1 11 85 00 A4 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 7F 7F 50 4B 04 7F 7F 50 4B 04 7F 7F 50 4B 04 FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------ 0000 FF 95 02 10 00 00 00 00 00 55 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 EF BC F8 80 F8 80 F8 80 01 0020 13 03 06 00 00 00 EF 30 00 EF 00 00 00 00 00 00 0030 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0027 0150 0250 007D 007E 0490 0491 0492 0493 0494 0495 062B 062C 062D 071C 0720 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 20 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 20 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 T: 37 127 0 255 255 255 255 255 255 255 255 37 37 37 128 19 0020 0021 0022 0023 0024 0025 0026 0480 0481 0482 0483 0484 0485 0486 0487 0488 0489 048A 048B 048C 048D 048E 048F V: A3 7F CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.29602 V ] V: A3 7F CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.29602 V ] V: A3 7F CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.27600 V ] V: 82 7F CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.33105 V ] V: 82 7F CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.26099 V ] V: 82 7F CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.29602 V ] V: 92 80 CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 0.92065 V ] V: 7E 80 CD CC 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.26099 V ] V: 7E 80 CD CD 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.27600 V ] V: 90 7F CD CD 7D FF BA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ VID = 1.26099 V ] ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : ========================================================================== ------[ 5 SMBuses detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : F000 Can Have SPD: No Scan Type : Full ------[ SMBus Device B00-D44 ]------ 0000 00 00 00 04 00 00 00 00 00 39 06 22 05 21 11 14 .........9.".!.. 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF39 FF06 FF22 FF05 FF21 FF11 FF14 0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 *** SMBus Semaphore Disabled = 0 ------[ SMBus #1 ]------ SMBus Type : Intel SNB-E/IVB-E/HSW-E/BDW-E SMBus MMIO : 00000000-EFF78180 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B01-D50 ]------ 0000 11 0B 02 04 21 00 09 03 11 01 08 0C 00 36 00 69 ....!........6.i 0010 78 69 30 69 11 20 89 60 09 3C 3C 00 F0 83 81 00 xi0i. .`.<<..... 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 0F 22 01 01 00 ............"... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 02 9E 01 00 00 00 00 00 00 E2 C8 43 ...............C 0080 4D 5A 33 32 47 58 33 4D 34 41 31 38 36 36 43 31 MZ32GX3M4A1866C1 0090 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0............... 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C ................ 00B0 4A 05 13 01 08 01 08 11 2A 09 55 44 00 44 55 5E J.......*.UD.DU^ 00C0 89 11 01 57 3E 00 69 09 44 33 00 F8 3C 00 00 10 ...W>.i.D3..<... 00D0 00 24 CB F2 F2 F1 EF 00 00 00 81 00 00 00 00 00 .$.............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 ................ *** SMBus Semaphore Disabled = 0 ------[ SMBus #2 ]------ SMBus Type : Intel SNB-E/IVB-E/HSW-E/BDW-E SMBus MMIO : 00000000-EFF78180 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B02-D50 ]------ 0000 11 0B 02 04 21 00 09 03 11 01 08 0C 00 36 00 69 ....!........6.i 0010 78 69 30 69 11 20 89 60 09 3C 3C 00 F0 83 81 00 xi0i. .`.<<..... 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 0F 22 01 01 00 ............"... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 02 9E 01 00 00 00 00 00 00 E2 C8 43 ...............C 0080 4D 5A 33 32 47 58 33 4D 34 41 31 38 36 36 43 31 MZ32GX3M4A1866C1 0090 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0............... 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C ................ 00B0 4A 05 13 01 08 01 08 11 2A 09 55 44 00 44 55 5E J.......*.UD.DU^ 00C0 89 11 01 57 3E 00 69 09 44 33 00 F8 3C 00 00 10 ...W>.i.D3..<... 00D0 00 24 CB F2 F2 F1 EF 00 00 00 81 00 00 00 00 00 .$.............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 ................ *** SMBus Semaphore Disabled = 0 ------[ SMBus #3 ]------ SMBus Type : Intel SNB-E/IVB-E/HSW-E/BDW-E SMBus MMIO : 00000000-EFF78190 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B03-D50 ]------ 0000 11 0B 02 04 21 00 09 03 11 01 08 0C 00 36 00 69 ....!........6.i 0010 78 69 30 69 11 20 89 60 09 3C 3C 00 F0 83 81 00 xi0i. .`.<<..... 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 0F 22 01 01 00 ............"... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 02 9E 01 00 00 00 00 00 00 E2 C8 43 ...............C 0080 4D 5A 33 32 47 58 33 4D 34 41 31 38 36 36 43 31 MZ32GX3M4A1866C1 0090 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0............... 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C ................ 00B0 4A 05 13 01 08 01 08 11 2A 09 55 44 00 44 55 5E J.......*.UD.DU^ 00C0 89 11 01 57 3E 00 69 09 44 33 00 F8 3C 00 00 10 ...W>.i.D3..<... 00D0 00 24 CB F2 F2 F1 EF 00 00 00 81 00 00 00 00 00 .$.............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 ................ *** SMBus Semaphore Disabled = 0 ------[ SMBus #4 ]------ SMBus Type : Intel SNB-E/IVB-E/HSW-E/BDW-E SMBus MMIO : 00000000-EFF78190 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B04-D50 ]------ 0000 11 0B 02 04 21 00 09 03 11 01 08 0C 00 36 00 69 ....!........6.i 0010 78 69 30 69 11 20 89 60 09 3C 3C 00 F0 83 81 00 xi0i. .`.<<..... 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 0F 22 01 01 00 ............"... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 02 9E 01 00 00 00 00 00 00 E2 C8 43 ...............C 0080 4D 5A 33 32 47 58 33 4D 34 41 31 38 36 36 43 31 MZ32GX3M4A1866C1 0090 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0............... 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C ................ 00B0 4A 05 13 01 08 01 08 11 2A 09 55 44 00 44 55 5E J.......*.UD.DU^ 00C0 89 11 01 57 3E 00 69 09 44 33 00 F8 3C 00 00 10 ...W>.i.D3..<... 00D0 00 24 CB F2 F2 F1 EF 00 00 00 81 00 00 00 00 00 .$.............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 ................ *** SMBus Semaphore Disabled = 0 Quote
McPolli Posted November 23, 2014 Posted November 23, 2014 You can already use the Aquaero sensor module in the latest AIDA64 Extreme beta update: http://www.aida64.com/downloads/latesta64xebeta I use the beta, but I don´t have an Aquero. How can I use those feature with my Hardware (Aquastream XT USB and MPS "High flow Sensor") wich are just connected with USB? My Aquasuite reads everything fine an is able to export sensordatas with xml-files or shared memory export. There is no option for an Aquero or something else. I like to have the flow and temp values on the LCD-panel of Aida64. The Device ID´s are: Aquastream XT USB: 0C70-F0B6 MPS: 0C70-F003 Quote
Fiery Posted November 25, 2014 Author Posted November 25, 2014 I'm not getting the flow rate from my Aquacomputer flow sensor. I have 4 flow sensors listed on the sensor page but all 4 have a 0.00 LPH reading. I'm using the latest beta v4.70.3237. I do have the high flow USB sensor connected to the Aquaero 6 Pro via the aquabus connection. Its displayed in the aquasuite as the third flow sensor and I have a good reading there. Flow 2 is one of the Fan channels and when I enable that I do see that value as Flow 2. Is the MPS high flow USB flow sensor currently not compatible with AIDA64? I've attached my sensor debug in case that helps. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic. Thanks, Fiery Quote
Fiery Posted November 25, 2014 Author Posted November 25, 2014 I use the beta, but I don´t have an Aquero. How can I use those feature with my Hardware (Aquastream XT USB and MPS "High flow Sensor") wich are just connected with USB? My Aquasuite reads everything fine an is able to export sensordatas with xml-files or shared memory export. There is no option for an Aquero or something else. I like to have the flow and temp values on the LCD-panel of Aida64. The Device ID´s are: Aquastream XT USB: 0C70-F0B6 MPS: 0C70-F003 We haven't got any programming information on those devices. We've sent a request to Aquacomputer, hopefully they would help us out. I'll post updates on this issue into this topic. Quote
eiwoh Posted November 25, 2014 Posted November 25, 2014 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic. Thanks, Fiery Here is the Aquaero Debug from my system. ------[ AIDA64 Extreme v4.70.3237 Beta ]------ ------[ Microsoft Windows 8.1 Professional 6.3.9600.17415 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-122211-Chipset$1APEQ016_BIOS DATE: 07/25/14 11:01:08 VER: 48.01 Motherboard Model : Asus Sabertooth X79 Motherboard Chipset : Intel Patsburg X79, Intel Ivy Bridge-E DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : SABERTOOTH X79 DMI MB Version : Rev 1.xx DMI MB Serial : 140120931600217 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 4801 ------[ DevClass / Human Interface Devices ]------ HID-compliant game controller\\?\hid#vhidjs#9&2652118b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VHIDJS\9&2652118B&0&00000000000B00000007 HID Keyboard Device\\?\hid#vid_05a4&pid_9840#9&2d176d03&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_05A4&PID_9840\9&2D176D03&0&00000000000100000002 Razer DeathStalker Ultimate\\?\hid#vid_1532&pid_0114&mi_01&col01#8&33199ea&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_01&COL01\8&33199EA&0&00000000000900000007 Razer DeathStalker Ultimate\\?\hid#vid_1532&pid_0114&mi_02#8&1661b628&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_02\8&1661B628&0&00000000000A00000008 HID-compliant consumer control device\\?\hid#vid_1532&pid_0114&mi_01&col02#8&33199ea&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_01&COL02\8&33199EA&0&00010000000900000007 Razer DeathStalker Ultimate\\?\hid#vid_1532&pid_0114&mi_00#8&2b9c47b3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_00\8&2B9C47B3&0&00000000000800000006 HID-compliant mouse\\?\hid#vid_046d&pid_c231#2&1652c37&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C231\2&1652C37&0&00000000000D HID-compliant vendor-defined device\\?\hid#vid_0c70&pid_f001&mi_02#8&37cd2b8b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_0C70&PID_F001&MI_02\8&37CD2B8B&0&00000000000500000006 HID-compliant system controller\\?\hid#vid_1532&pid_0114&mi_01&col03#8&33199ea&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_01&COL03\8&33199EA&0&00020000000900000007 Logitech Cordless Gaming Receiver\\?\hid#vid_046d&pid_c531&mi_00#8&644dec1&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C531&MI_00\8&644DEC1&0&00000000000600000005 HID Keyboard Device\\?\hid#vid_1050&pid_0010#9&19f2e1b7&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1050&PID_0010\9&19F2E1B7&0&00000000000E00000001 HID Keyboard Device\\?\hid#vid_0c70&pid_f001&mi_00&col01#8&2bb97a0e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_0C70&PID_F001&MI_00&COL01\8&2BB97A0E&0&00000000000300000004 HID-compliant vendor-defined device\\?\hid#vid_0c70&pid_f003#7&af03736&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_0C70&PID_F003\7&AF03736&0&00000000000200000003 HID-compliant mouse\\?\hid#vid_0c70&pid_f001&mi_00&col02#8&2bb97a0e&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_0C70&PID_F001&MI_00&COL02\8&2BB97A0E&0&00010000000300000004 HID-compliant device\\?\hid#vid_1532&pid_0114&mi_01&col04#8&33199ea&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_01&COL04\8&33199EA&0&00030000000900000007 HID Keyboard Device\\?\hid#vid_046d&pid_c531&mi_01&col01#8&1e086b06&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C531&MI_01&COL01\8&1E086B06&0&00000000000700000006 HID-compliant consumer control device\\?\hid#vid_046d&pid_c531&mi_01&col02#8&1e086b06&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C531&MI_01&COL02\8&1E086B06&0&00010000000700000006 HID-compliant system controller\\?\hid#vid_046d&pid_c531&mi_01&col03#8&1e086b06&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C531&MI_01&COL03\8&1E086B06&0&00020000000700000006 HID-compliant vendor-defined device\\?\hid#vid_046d&pid_c531&mi_01&col04#8&1e086b06&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C531&MI_01&COL04\8&1E086B06&0&00030000000700000006 HID-compliant device\\?\hid#vid_1532&pid_0114&mi_01&col05#8&33199ea&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_1532&PID_0114&MI_01&COL05\8&33199EA&0&00040000000900000007 HID Keyboard Device\\?\hid#vid_046d&pid_c232#2&1928b87c&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C232\2&1928B87C&0&00000000000C HID-compliant vendor-defined device\\?\hid#vid_046d&pid_c531&mi_01&col05#8&1e086b06&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_046D&PID_C531&MI_01&COL05\8&1E086B06&0&00040000000700000006 HID-compliant consumer control device\\?\hid#vid_0c70&pid_f001&mi_01&col01#8&13f5edc9&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_0C70&PID_F001&MI_01&COL01\8&13F5EDC9&0&00000000000400000005 HID-compliant system controller\\?\hid#vid_0c70&pid_f001&mi_01&col02#8&13f5edc9&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}HID\VID_0C70&PID_F001&MI_01&COL02\8&13F5EDC9&0&00010000000400000005 ------[ Aquaero/Aquaduct Device ]------ Manufacturer = Aqua Computer GmbH & Co. KG Product = aquaero Device Serial Number = 18071-56331 Device ID = 0C70-F001 Usage = 0001h Usage Page = FF00h Input Report Byte Length = 1038 Output Report Byte Length = 2114 Feature Report Byte Length = 2428 ------[ AA5 Feature Report ]------ 0000 03 F5 0B 15 61 62 00 00 00 40 00 40 00 40 00 00 ....ab...@.@.@.. 0010 00 40 00 40 00 40 00 40 03 00 0F A0 17 70 27 10 .@.@.@.@.....p'. 0020 0F A0 00 F0 00 00 13 88 01 F4 00 00 3C FF FA 01 ............<... 0030 01 00 14 24 01 00 09 3A 01 00 0F 3B 01 00 0F 3C ...$...:...;...< 0040 01 00 0F 50 01 00 0F 25 00 00 0F 00 00 00 0F 46 ...P...%.......F 0050 00 00 0F 34 00 00 0F 37 00 00 0F 3A 00 00 0F 3B ...4...7...:...; 0060 00 00 0F 3C 00 00 0F 3D 00 00 0F 5C 00 00 0F 63 ...<...=...\...c 0070 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 0080 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 0090 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 00A0 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 00B0 FF FF 0A 00 00 FF FF 0B 00 00 FF FF 0C 00 00 FF ................ 00C0 FF 0D 00 00 00 03 00 00 03 01 F4 00 0A 00 00 00 ................ 00D0 00 00 01 00 3C FF FF FF FF FF FF 00 00 00 00 00 ....<........... 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 FF ................ 0160 FF 03 00 01 00 00 FF FF 03 00 03 00 00 FF FF 03 ................ 0170 FF FF FF FF FF FF 02 01 13 88 01 2C 01 13 88 01 ...........,.... 0180 2C 01 13 88 01 2C 01 13 88 01 2C 01 13 88 01 2C ,....,....,...., 0190 01 13 88 01 2C 01 13 88 01 2C 01 13 88 01 2C 00 ....,....,....,. 01A0 A9 00 00 53 F5 00 A9 00 00 7F FF 00 A9 00 00 05 ...S............ 01B0 DC 00 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 ................ 01C0 00 05 DC 00 A9 00 00 05 DC 00 A9 00 00 05 DC 00 ................ 01D0 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 00 67 ...............g 01E0 81 00 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 ................ 01F0 00 05 DC 00 8A 00 02 00 03 00 8A 00 00 00 01 FF ................ 0200 FF FF FF FF FF FF FF FF FF FF FF 00 01 2C 05 14 .............,.. 0210 0B B8 27 10 27 10 00 05 00 02 04 02 00 60 03 E8 ..'.'........`.. 0220 01 2C 05 14 16 A8 27 10 27 10 00 05 00 02 04 00 .,....'.'....... 0230 00 40 03 E8 01 2C 05 14 18 9C 27 10 27 10 00 05 .@...,....'.'... 0240 00 02 04 00 00 41 03 E8 01 C2 07 D0 0D AC 27 10 .....A........'. 0250 27 10 00 02 00 02 00 00 FF FF 03 E8 01 C2 07 D0 '............... 0260 0D AC 27 10 27 10 00 02 00 02 00 00 FF FF 03 E8 ..'.'........... 0270 01 C2 07 D0 0D AC 27 10 27 10 00 02 00 02 00 00 ......'.'....... 0280 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 27 10 00 02 ..........'.'... 0290 00 02 00 00 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 ..............'. 02A0 27 10 00 02 00 02 00 00 FF FF 03 E8 01 C2 07 D0 '............... 02B0 0D AC 27 10 27 10 00 02 00 02 00 00 FF FF 03 E8 ..'.'........... 02C0 01 C2 07 D0 0D AC 27 10 27 10 00 02 00 02 00 00 ......'.'....... 02D0 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 27 10 00 02 ..........'.'... 02E0 00 02 00 00 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 ..............'. 02F0 27 10 00 02 00 02 00 00 FF FF 03 E8 01 00 37 01 '.............7. 0300 00 37 FF FF 01 FF FF 00 FF FF 00 00 00 27 10 00 .7...........'.. 0310 49 00 00 00 27 10 FF FF 00 FF FF 00 13 88 FF FF I...'........... 0320 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 ................ 0330 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 ................ 0340 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 ................ 0350 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF ................ 0360 FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF ................ 0370 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 ................ 0380 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 ................ 0390 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 ................ 03A0 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF ................ 03B0 FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF ................ 03C0 02 13 88 00 00 00 00 00 FF FF 01 F4 07 D0 00 FF ................ 03D0 FF 00 00 27 10 FF FF 00 00 27 10 FF FF 00 00 27 ...'.....'.....' 03E0 10 FF FF 00 00 27 10 FF FF 0A F0 09 C4 00 03 0B .....'.......... 03F0 54 0A BE FF FF 00 00 0B 54 FF FF 0B 54 0A 8C FF T.......T...T... 0400 FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A ................ 0410 F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D ................ 0420 AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF ................ 0430 FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A ................ 0440 F0 FF FF 0D AC 0A F0 27 10 18 F3 27 10 00 00 00 .......'...'.... 0450 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0460 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0480 00 00 00 00 00 00 00 00 05 0A 8C 01 F4 00 64 00 ..............d. 0490 00 00 28 00 0A 00 17 0D AC 01 F4 00 64 00 00 00 ..(.........d... 04A0 28 00 0A FF FF 0C 80 01 F4 00 64 00 00 00 28 00 (.........d...(. 04B0 0A FF FF 0C 80 01 F4 00 64 00 00 00 28 00 0A FF ........d...(... 04C0 FF 0C 80 01 F4 00 64 00 00 00 28 00 0A FF FF 0C ......d...(..... 04D0 80 01 F4 00 64 00 00 00 28 00 0A FF FF 0C 80 01 ....d...(....... 04E0 F4 00 64 00 00 00 28 00 0A FF FF 0C 80 01 F4 00 ..d...(......... 04F0 64 00 00 00 28 00 0A FF FF 09 C4 0A BE 0A F0 0B d...(........... 0500 22 0B 54 0B 86 0B B8 0B EA 0C 1C 0C 4E 0C 80 0C ".T.........N... 0510 B2 0C E4 0D 16 0D 48 0D 7A 0D AC 19 64 1B 5C 1D ......H.z...d.\. 0520 4F 1F 40 21 34 23 28 23 8C 23 F0 24 54 24 B8 25 O.@!4#(#.#.$T$.% 0530 1C 25 80 25 E4 26 48 26 AC 27 10 FF FF 00 32 00 .%.%.&H&.'....2. 0540 00 00 1E 00 46 00 64 00 82 00 AA 00 C8 00 E5 01 ....F.d......... 0550 0E 01 2C 01 4A 01 72 01 90 01 AE 01 D6 01 F4 0B ..,.J.r......... 0560 B8 0D 8B 0F 5D 11 30 13 03 14 D5 16 A8 18 7B 1A ....].0.......{. 0570 4D 1C 20 1D F3 1F C5 21 98 23 6B 25 3D 27 10 FF M. ....!.#k%='.. 0580 FF 0B B8 0A 8C 0A FA 0B 4A 0B A4 0B F4 0C 4E 0C ........J.....N. 0590 9D 0C F8 0D 48 0D A2 0D F2 0E 4C 0E 9C 0E F5 0F ....H.....L..... 05A0 46 0F A0 00 00 00 8C 01 18 01 F4 03 20 04 B0 06 F........... ... 05B0 90 08 D4 0B 68 0E 4C 11 94 15 2C 19 28 1D 74 22 ....h.L...,.(.t" 05C0 10 27 10 FF FF 0B B8 0A 8C 0A FA 0B 4A 0B A4 0B .'..........J... 05D0 F4 0C 4E 0C 9D 0C F8 0D 48 0D A2 0D F2 0E 4C 0E ..N.....H.....L. 05E0 9C 0E F5 0F 46 0F A0 00 00 00 8C 01 18 01 F4 03 ....F........... 05F0 20 04 B0 06 90 08 D4 0B 68 0E 4C 11 94 15 2C 19 .......h.L...,. 0600 28 1D 74 22 10 27 10 FF FF 00 09 C4 00 00 00 00 (.t".'.......... 0610 00 00 0A 28 00 00 00 00 00 00 0B 54 27 10 00 00 ...(.......T'... 0620 00 00 02 00 8E 02 00 8A 00 FF FF 00 FF FF 00 FF ................ 0630 FF 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 FF FF ................ 0640 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 ................ 0650 FF FF 00 00 00 03 FF FF 00 04 FF FF FF FF 00 02 ................ 0660 FF FF FF FF 00 04 FF FF FF FF 00 02 FF FF FF FF ................ 0670 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0680 FF FF 00 0A FF FF 02 0B B8 01 0D AC 04 FF FF 00 ................ 0690 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 88 02 FF ................ 06A0 FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 88 ................ 06B0 02 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 ................ 06C0 13 88 02 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F ................ 06D0 A0 01 13 88 02 FF FF 00 0F A0 01 13 88 02 FF FF ................ 06E0 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 88 02 ................ 06F0 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 ................ 0700 88 02 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 ................ 0710 01 13 88 02 03 01 03 02 03 01 03 02 03 01 03 02 ................ 0720 03 01 03 02 03 01 03 02 03 01 03 02 03 01 03 02 ................ 0730 03 01 03 02 03 01 03 02 03 01 03 02 03 01 03 02 ................ 0740 03 01 03 02 FF FF 02 0C 6A 01 05 E9 03 FF FF 02 ........j....... 0750 01 2C 01 00 C8 02 FF FF 02 01 2C 01 00 C8 02 00 .,........,..... 0760 80 02 01 2C 01 00 C8 02 FF FF 01 00 FF FF 01 00 ...,............ 0770 FF FF 01 00 FF FF 01 00 FF FF 01 13 88 01 0B B8 ................ 0780 02 FF FF 01 13 88 01 0B B8 02 FF FF 01 13 88 01 ................ 0790 0B B8 02 FF FF 01 13 88 01 0B B8 02 FF FF 01 17 ................ 07A0 70 01 0F A0 02 FF FF 01 17 70 01 0F A0 02 FF FF p........p...... 07B0 01 17 70 01 0F A0 02 FF FF 01 17 70 01 0F A0 02 ..p........p.... 07C0 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 ................ 07D0 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 ................ 07E0 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF ................ 07F0 FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 ................ 0800 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 ................ 0810 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 ................ 0820 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF ................ 0830 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 ................ 0840 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 ................ 0850 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF ................ 0860 FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 ................ 0870 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 ................ 0880 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 ................ 0890 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF ................ 08A0 0F 01 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 08B0 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 08C0 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 08D0 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 08E0 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 08F0 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 0900 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 0910 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 0920 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 0930 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 0940 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 0950 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 0960 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 FF FF .......d........ 0970 FF FF FF 00 00 00 00 00 00 00 00 ........... ------[ AA5 Input Report ]------ Structure Version = 1013 Firmware Version = 1036 Bootloader Version = 102 Hardware Version = 6000 Device Type = 1 (Aquaero 5 Pro) 0000 0B 18 C9 06 03 F5 46 97 DC 0B 04 0C 00 66 17 70 ......F......f.p 0010 00 62 6F 59 00 70 88 68 03 00 00 01 00 0B 00 00 .boY.p.h........ 0020 00 00 00 0B 15 53 77 02 00 00 02 05 FF FF FF 00 .....Sw......... 0030 0F A0 0F A0 01 F4 00 00 00 00 04 00 00 00 00 00 ................ 0040 A6 FD A7 83 A5 38 A5 4F A5 20 A7 D1 FF D8 FF D8 .....8.O. ...... 0050 A1 60 0B 0B 00 A2 00 68 00 A1 00 6D 00 AB 00 62 .`.....h...m...b 0060 5B 7B 5A 22 6B 6C 5B A2 09 4B 09 32 09 96 09 93 [{Z"kl[..K.2.... 0070 09 9B 09 27 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ...'............ 0080 7F FF 7F FF 7F FF 7F FF 06 A4 06 A4 08 34 07 08 .............4.. 0090 08 34 07 08 0A F0 0B B8 00 03 FF E7 00 48 7F FF .4...........H.. 00A0 7F FF 09 B7 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 00B0 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 00C0 07 12 07 12 06 D7 06 D7 7F FF 7F FF 7F FF 7F FF ................ 00D0 7F FF 7F FF 7F FF 7F FF 0B 36 7F FF 7F FF 7F FF .........6...... 00E0 7F FF 7F FF 7F FF 7F FF 00 00 09 74 00 00 00 00 ...........t.... 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 12 0F 00 00 00 00 00 00 12 0F 09 96 09 93 00 03 ................ 0120 00 10 00 01 12 0F 09 4B 09 32 00 19 00 86 00 01 .......K.2...... 0130 FF FF 7F FF 7F FF 00 00 00 00 7F FF FF FF 7F FF ................ 0140 7F FF 00 00 00 00 7F FF 00 00 00 00 00 00 00 00 ................ 0150 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0160 7F FF 7F FF 7F FF 7F FF 0D AC 04 D7 27 10 04 96 ............'... 0170 00 C6 00 E8 00 B2 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 02 FF FF FF FF FF ................ 0200 FF FF 02 FF FF FF FF FF FF FF 00 00 00 00 00 00 ................ 0210 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 ................ 0220 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0230 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 27 10 18 F3 27 10 00 00 00 00 00 00 00 00 00 00 '...'........... 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 33 00 00 00 00 00 00 00 00 00 00 00 ....3........... 02D0 00 48 75 6D 69 64 69 74 79 20 34 00 00 00 00 00 .Humidity 4..... 02E0 00 00 00 00 00 00 00 57 61 74 65 72 20 71 75 61 .......Water qua 02F0 6C 69 74 79 20 31 00 00 00 00 00 00 00 57 61 74 lity 1.......Wat 0300 65 72 20 71 75 61 6C 69 74 79 20 32 00 00 00 00 er quality 2.... 0310 00 00 00 57 61 74 65 72 20 71 75 61 6C 69 74 79 ...Water quality 0320 20 33 00 00 00 00 00 00 00 57 61 74 65 72 20 71 3.......Water q 0330 75 61 6C 69 74 79 20 34 00 00 00 00 00 00 00 44 uality 4.......D 0340 35 20 70 75 6D 70 20 31 00 00 00 00 00 00 00 00 5 pump 1........ 0350 00 00 00 00 00 44 35 20 70 75 6D 70 20 32 00 00 .....D5 pump 2.. 0360 00 00 00 00 00 00 00 00 00 00 00 44 35 20 70 75 ...........D5 pu 0370 6D 70 20 33 00 00 00 00 00 00 00 00 00 00 00 00 mp 3............ 0380 00 44 35 20 70 75 6D 70 20 34 00 00 00 00 00 00 .D5 pump 4...... 0390 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF ................ 03A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0400 FF FF FF FF FF FF FF FF FF D0 EB 6F B0 ...........o. Quote
Grestorn Posted November 28, 2014 Posted November 28, 2014 Hi Fiery, I've been playing around with the new Arx Control feature to make me a all new panel for my "old" iPad. While doing that I realized, that the temperature sensor for the aquaduct using integer numbers is just not adequate. You have to understand, that a temperature in a water cooling cycle shows much less deviation than a CPU, GPU or even a motherboard temperature. My "Water inlet" temperature usually varies between 35 and 39°C. That's why AquaComputer's has a resolution of 0.1°C. I understand that it might be difficult for you to add fraction support for temperatures all through your framework, but I think it would be worthwhile. If that's too much to ask, I'd rather have the aquacomputer temperature values reflect the 10x value, i.E. showing 37.5° as 375. Quote
Fiery Posted November 28, 2014 Author Posted November 28, 2014 Hi Fiery, I've been playing around with the new Arx Control feature to make me a all new panel for my "old" iPad. While doing that I realized, that the temperature sensor for the aquaduct using integer numbers is just not adequate. You have to understand, that a temperature in a water cooling cycle shows much less deviation than a CPU, GPU or even a motherboard temperature. My "Water inlet" temperature usually varies between 35 and 39°C. That's why AquaComputer's has a resolution of 0.1°C. I understand that it might be difficult for you to add fraction support for temperatures all through your framework, but I think it would be worthwhile. If that's too much to ask, I'd rather have the aquacomputer temperature values reflect the 10x value, i.E. showing 37.5° as 375. I do understand your desire to see the fraction of degrees there, but somehow I still cannot imagine what would be the actual, practical use of it. Why is it so important to know the difference between 35.0 Celsius and 35.4 Celsius for example? Why does 0.1 or 0.4 Celsius make a difference? I of course understand the need to know the difference between 1.0 Volts and 1.1 Volts, but I cannot see myself in a position not being content with a 35, 36, 37 Celsius scale If your water is cool, it is cool anywhere between 30 and 31 Celsius. If your system is overheating, it will be hot anywhere between 80 and 81 Celsius, it doesn't matter to know whether it is 80.2 Celsius or 80.6 Celsius -- it's still very hot. The other problem -- besides the amount of work we would have to put in it -- with showing the temperature decimal digits is that most sensor devices are simply not capable of measuring temperatures at such accuracy. So for most of the temperature readouts we would have to show "39.0 Celsius" or "61.0 Celsius", and from a mathematical pont of view, that would be incorrect, since the measurement accuracy doesn't actually tell us the ".0" part. And overcomplicating the whole thing by showing "39 Celsius" for such values where accuracy is zero decimal digits, and showing "39.2 Celsius" where accuracy is one decimal digit would just make things even more complicated. And quite frankly, I cannot see the actual benefit of all that... BTW, it's no coincidence that the overwhelming majority of sensor devices will not measure temperatures with a fraction of Celsius accuracy. Aquaero/Aquaduct devices are designed for the hardest of the hardcore users, but IMHO even their engineers wouldn't be able to tell me with a straight face that there's an actual technical benefit of the extreme accuracy of their temperature diodes. It's a great thing when they want to show off the technical complexity and engineering accomplishment of their products of course, but that's more of a marketing trick Quote
Grestorn Posted November 28, 2014 Posted November 28, 2014 Well, you see, when my systems idles, my water temperature floats between 36.0 and 36.7°. In that range, the fans in the aquaduct are turned off. When I start to put some stress on it, it rises above 37°, at that temperature the fans are starting or work. To find the right spot when they should start is vital, because you don't want the fans to be on while the PC is idle. The aquasuite displays that you can put on your desktop show that the temperature measured is very stable and dependent. I don't think that it's actually really accurate, but that's not important. I don't need to know whether it's actually exactly 37.6°, but I want to to know when the temperature is starting to rise or fall, even if it's just by 0.5° or less. And the changes in the temperature are reflected well enough by all of their sensors, even the ones I've put in the water cycle myself. I understand your points and I agree that for most use cases, an accuracy of more than 1 degree is over the top. But unfortunately, water cooling system are an exception to that rule, I'm afraid. Again, I don't want to impose any additional work on your part, so I would be happy if the temperature would be shown in 10th of a degree, i.e. 375 instead of 37.5. I guess that would be a very minor change in your data collection routine only, wouldn't it? Quote
Fiery Posted November 28, 2014 Author Posted November 28, 2014 I'm not getting the flow rate from my Aquacomputer flow sensor. I have 4 flow sensors listed on the sensor page but all 4 have a 0.00 LPH reading. I'm using the latest beta v4.70.3237. I do have the high flow USB sensor connected to the Aquaero 6 Pro via the aquabus connection. Its displayed in the aquasuite as the third flow sensor and I have a good reading there. Flow 2 is one of the Fan channels and when I enable that I do see that value as Flow 2. Is the MPS high flow USB flow sensor currently not compatible with AIDA64? I've attached my sensor debug in case that helps. Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
eiwoh Posted December 5, 2014 Posted December 5, 2014 Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. That helped, thank you very much. I now have a lot more flow sensors and can read the data from my flow sensor. Its being read in LPH, is it possible to change the unit for the flow rate reading? Quote
Fiery Posted December 5, 2014 Author Posted December 5, 2014 That helped, thank you very much. I now have a lot more flow sensors and can read the data from my flow sensor. Its being read in LPH, is it possible to change the unit for the flow rate reading? Thank you for the feedback. Measurement units are fixed, they cannot be changed I'm afraid. Quote
delevic Posted December 9, 2014 Posted December 9, 2014 This is great news. I didn't know for this integration with aquaero Everything works fine. I agree with Grestorm, we need 0.1C temperature resolution I changed names of tepm. sensors in aquaero . Instead of Temperature #1 i wrote Water IN , and for Temperature #2 , Water OUT. Is it possible that I see that names is Aida64 ? I mean that for all other senosrs. Fans names, Flow meter name etc. Quote
Fiery Posted December 9, 2014 Author Posted December 9, 2014 This is great news. I didn't know for this integration with aquaero Everything works fine. I agree with Grestorm, we need 0.1C temperature resolution We'll give it a second thought I changed names of tepm. sensors in aquaero . Instead of Temperature #1 i wrote Water IN , and for Temperature #2 , Water OUT. Is it possible that I see that names is Aida64 ? I mean that for all other senosrs. Fans names, Flow meter name etc. You cannot rename items on the Computer / Sensor page, but you can rename them in the hardware monitoring modules like OSD Panel, Desktop Gadget, SensorPanel, LCD (including RemoteSensor and Logitech Arx integration). Quote
Fiery Posted December 11, 2014 Author Posted December 11, 2014 Again, I don't want to impose any additional work on your part, so I would be happy if the temperature would be shown in 10th of a degree, i.e. 375 instead of 37.5. I guess that would be a very minor change in your data collection routine only, wouldn't it? We've implemented increased accuracy for temperature measurement and temperature display in the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta You can change the default zero decimal digits for temperature readouts (which is the legacy method) in AIDA64 / main menu / File / Preferences / Hardware Monitoring. Note that the increased display accuracy will be reflected in all AIDA64 modules, including the Computer / Sensor page, RemoteSensor, Logitech Arx, LCD, SensorPanel, OSD Panel, Sidebar Gadget, Logging, etc. Except for the Sensor Icons where there's no room to display the decimal digits. As for the actual measurement accuracy, it is not available for most sensor devices, so don't be surprised to see a lot of "37.00 Celsius" or "32.00 Celsius" temperature readings. It is of course available for the Aquaero and Aquaduct Let me know how it works Quote
Grestorn Posted December 11, 2014 Posted December 11, 2014 Let me give you a hug! It's working fine! Quote
Fiery Posted December 11, 2014 Author Posted December 11, 2014 Let me give you a hug! It's working fine! I'm glad it works fine, thank you for the feedback Quote
delevic Posted December 11, 2014 Posted December 11, 2014 It works like a charm You are fast.... And I saw now that we have new aquasuite 2015 and new firmware for aquaero.... Lets see how it works Once again , thanks Quote
Fiery Posted December 13, 2014 Author Posted December 13, 2014 Hi everyone I found this topic on my search for an integration of my AquaSuite sensor data into Aida64. Are there any plans to support my components in a future release. My System has an AquastreamXT pump and a MPS Flow/Temp sensor from Aqua Computer. I used LCDHost for my G19 before but now I prefer the Aida64 LCD support. Cheers McPolli I've sent you a private message and an email about this Quote
McPolli Posted December 22, 2014 Posted December 22, 2014 Hi Fiery Testing is done, and I´ve made all your instructions. Regards McPolli Quote
Fiery Posted December 22, 2014 Author Posted December 22, 2014 Hi Fiery Testing is done, and I´ve made all your instructions. Regards McPolli Thank you for your help. Meanwhile, AquaComputer was super kind and sent us a set of gadgets to help our progress on the development of Aquastream XT and MPS support for AIDA64. We're already working on it, and will notify you here on the forum, and also in email once it is ready Quote
ilavicion Posted January 5, 2015 Posted January 5, 2015 For Aquaero 5, Aquaero 6, Aquaduct Mark 4, and Aquaduct Mark 5, the following readings are available in the first beta: - 16 generic temperatures Where do I find them? I have my aquastream XT connected to aquaero and have it's temperature listed in aquasuite. My problem is, I don't get this temperature in AIDA64. How do I manage to get this to work? Quote
Fiery Posted January 5, 2015 Author Posted January 5, 2015 Where do I find them? I have my aquastream XT connected to aquaero and have it's temperature listed in aquasuite. My problem is, I don't get this temperature in AIDA64. How do I manage to get this to work? Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach it as a TXT file to your post. Thanks, Fiery Quote
Fiery Posted January 5, 2015 Author Posted January 5, 2015 Here's the first beta update to implement AquaStream XT, MPS, PowerAdjust 2 and PowerAdjust 3 sensor support, when those devices are connected via USB. They were already supported by older AIDA64 releases when they are connected to an Aquaero controller device via Aquabus. http://www.aida64.com/downloads/latesta64xebeta In case you find any discrepancies or missing readings, please create a screen shot of Aquasuite 2014 or 2015 with the reference measured values, and right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach it as a TXT file to your post. Quote
ilavicion Posted January 5, 2015 Posted January 5, 2015 Here's the first beta update to implement AquaStream XT, MPS, PowerAdjust 2 and PowerAdjust 3 sensor support, when those devices are connected via USB. They were already supported by older AIDA64 releases when they are connected to an Aquaero controller device via Aquabus. http://www.aida64.com/downloads/latesta64xebeta In case you find any discrepancies or missing readings, please create a screen shot of Aquasuite 2014 or 2015 with the reference measured values, and right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach it as a TXT file to your post. Thank you for your response! In the beta version it works for me because I connected my aquastream via USB (additionally to aquaero). Awesome!!! anyway, here my aquaero debug dump where I don't see the aquastream temperature although it is connected to my aquaero: ------[ AIDA64 Extreme v5.00.3315 Beta ]------ ------[ Microsoft Windows 8.1 Professional 6.3.9600.17328 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-010914-Chipset$0AAAA000_BIOS DATE: 10/16/14 20:35:58 VER: 05.06.05 Motherboard Model : Asus Rampage V Extreme Motherboard Chipset : Intel Wellsburg X99, Intel Haswell-E DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : RAMPAGE V EXTREME DMI MB Version : Rev 1.xx DMI MB Serial : 140830368100635 DMI SYS Manufacturer: ASUS DMI SYS Product : All Series DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 0802 ------[ DevClass / Human Interface Devices ]------ <DESC>HID-konforme Maus</DESC><DEVPATH>\\?\hid#vid_046d&pid_c231#2&2bd58e75&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C231\2&2BD58E75&0&0000</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR></ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c531&mi_01&col04#8&d77cbeb&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C531&MI_01&COL04\8&D77CBEB&0&0003</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000005</ADDR> <DESC>Logitech Cordless Gaming Receiver</DESC><DEVPATH>\\?\hid#vid_046d&pid_c531&mi_00#8&253b5830&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C531&MI_00\8&253B5830&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c07c&mi_01&col04#7&ffa0ce2&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C07C&MI_01&COL04\7&FFA0CE2&0&0003</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_01&col01#7&148916ee&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_01&COL01\7&148916EE&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000005</ADDR> <DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c228&mi_00#8&8a7f603&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C228&MI_00\8&8A7F603&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c531&mi_01&col05#8&d77cbeb&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C531&MI_01&COL05\8&D77CBEB&0&0004</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000005</ADDR> <DESC>HID-konformer Systemcontroller</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_01&col02#7&148916ee&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_01&COL02\7&148916EE&0&0001</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000005</ADDR> <DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c232#2&248ebd5a&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C232\2&248EBD5A&0&0000</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR></ADDR> <DESC>Logitech G700s Rechargeable Gaming Mouse</DESC><DEVPATH>\\?\hid#vid_046d&pid_c07c&mi_00#7&232a2920&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C07C&MI_00\7&232A2920&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f0b6#7&2b8e0256&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F0B6\7&2B8E0256&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR> <DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c531&mi_01&col01#8&d77cbeb&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C531&MI_01&COL01\8&D77CBEB&0&0000</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000005</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_02#7&386054b0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_02\7&386054B0&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000006</ADDR> <DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c07c&mi_01&col01#7&ffa0ce2&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C07C&MI_01&COL01\7&FFA0CE2&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c229&mi_01&col01#8&274f04d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C229&MI_01&COL01\8&274F04D&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c531&mi_01&col02#8&d77cbeb&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C531&MI_01&COL02\8&D77CBEB&0&0001</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000005</ADDR> <DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c07c&mi_01&col02#7&ffa0ce2&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C07C&MI_01&COL02\7&FFA0CE2&0&0001</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c229&mi_01&col02#8&274f04d&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C229&MI_01&COL02\8&274F04D&0&0001</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-konformer Systemcontroller</DESC><DEVPATH>\\?\hid#vid_046d&pid_c531&mi_01&col03#8&d77cbeb&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C531&MI_01&COL03\8&D77CBEB&0&0002</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000005</ADDR> <DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_00&col01#7&2c4ca333&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_00&COL01\7&2C4CA333&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c228&mi_01&col01#8&2c7f33c5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C228&MI_01&COL01\8&2C7F33C5&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000002</ADDR> <DESC>HID-konforme Maus</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_00&col02#7&2c4ca333&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_00&COL02\7&2C4CA333&0&0001</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c228&mi_01&col02#8&2c7f33c5&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C228&MI_01&COL02\8&2C7F33C5&0&0001</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000002</ADDR> <DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c07c&mi_01&col03#7&ffa0ce2&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C07C&MI_01&COL03\7&FFA0CE2&0&0002</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000004</ADDR> ------[ HID Device Info / HID-konformes Benutzersteuergerät ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : aquaero System Control Serial Number : 25479-31721 Device ID : 0C70-F001 Usage : 0001h Usage Page : 000Ch Input Report Byte Length : 3 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-konformer Systemcontroller ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : aquaero System Control Serial Number : 25479-31721 Device ID : 0C70-F001 Usage : 0080h Usage Page : 0001h Input Report Byte Length : 2 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-konformes, vom Hersteller definiertes Gerät ]------ Manufacturer : Aqua Computer Product : aquastream XT Device ID : 0C70-F0B6 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 0 Output Report Byte Length : 0 Feature Report Byte Length: 170 ------[ HID Device Info / HID-konformes, vom Hersteller definiertes Gerät ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : aquaero Device Serial Number : 25479-31721 Device ID : 0C70-F001 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 1038 Output Report Byte Length : 2114 Feature Report Byte Length: 2428 ------[ Aquaero/Aquaduct Device ]------ Manufacturer = Aqua Computer GmbH & Co. KG Product = aquaero Device Serial Number = 25479-31721 Device ID = 0C70-F001 Usage = 0001h Usage Page = FF00h Input Report Byte Length = 1038 Output Report Byte Length = 2114 Feature Report Byte Length = 2428 ------[ AA5 Feature Report ]------ 0000 03 F5 00 00 00 00 00 00 00 2D 00 2D 00 2D 00 00 .........-.-.-.. 0010 00 2D 00 2D 00 2D 00 2D 02 00 0F A0 17 70 27 10 .-.-.-.-.....p'. 0020 0F A0 00 F0 00 00 13 88 01 F4 00 00 3C 00 01 03 ............<... 0030 01 00 0F 61 01 00 0F 60 01 00 0F 24 01 00 0F 25 ...a...`...$...% 0040 01 00 0F 10 01 00 0F 11 01 00 0F 00 01 00 0F 46 ...............F 0050 01 00 0F 34 01 00 0F 37 01 00 0F 3A 01 00 0F 3B ...4...7...:...; 0060 01 00 0F 3C 01 00 0F 3D 01 00 0F 5C 01 00 0F 63 ...<...=...\...c 0070 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 0080 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 0090 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 00A0 00 00 1E 00 00 00 1E 00 00 00 1E 00 00 00 1E 00 ................ 00B0 FF FF 0A 00 00 FF FF 0B 00 00 FF FF 0C 00 00 FF ................ 00C0 FF 0D 00 00 00 00 00 00 01 01 F4 00 0A 00 00 FF ................ 00D0 FF FF FF 00 3C FF FF FF FF FF FF 00 00 00 00 00 ....<........... 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF ................ 0160 FF 02 FF FF FF FF FF FF 02 FF FF FF FF FF FF 02 ................ 0170 FF FF FF FF FF FF 02 00 13 88 01 2C 00 13 88 01 ...........,.... 0180 2C 00 13 88 01 2C 00 13 88 01 2C 00 13 88 01 2C ,....,....,...., 0190 00 13 88 01 2C 00 13 88 01 2C 00 13 88 01 2C 00 ....,....,....,. 01A0 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 00 05 ................ 01B0 DC 00 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 ................ 01C0 00 05 DC 00 A9 00 00 05 DC 00 A9 00 00 05 DC 00 ................ 01D0 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 00 05 ................ 01E0 DC 00 A9 00 00 05 DC 00 A9 00 00 05 DC 00 A9 00 ................ 01F0 00 05 DC FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0200 FF FF FF FF FF FF FF FF FF FF FF 00 01 C2 07 D0 ................ 0210 00 00 27 10 0B B8 00 01 00 02 04 02 00 58 03 E8 ..'..........X.. 0220 01 C2 07 D0 00 00 27 10 0B B8 00 01 00 02 04 02 ......'......... 0230 00 58 03 E8 01 C2 07 D0 00 00 27 10 0B B8 00 01 .X........'..... 0240 00 02 04 02 00 58 03 E8 01 C2 07 D0 00 00 27 10 .....X........'. 0250 0B B8 00 01 00 02 04 02 00 58 03 E8 01 C2 07 D0 .........X...... 0260 0D AC 27 10 27 10 00 02 00 02 00 00 FF FF 03 E8 ..'.'........... 0270 01 C2 07 D0 0D AC 27 10 27 10 00 02 00 02 00 00 ......'.'....... 0280 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 27 10 00 02 ..........'.'... 0290 00 02 00 00 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 ..............'. 02A0 27 10 00 02 00 02 00 00 FF FF 03 E8 01 C2 07 D0 '............... 02B0 0D AC 27 10 27 10 00 02 00 02 00 00 FF FF 03 E8 ..'.'........... 02C0 01 C2 07 D0 0D AC 27 10 27 10 00 02 00 02 00 00 ......'.'....... 02D0 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 27 10 00 02 ..........'.'... 02E0 00 02 00 00 FF FF 03 E8 01 C2 07 D0 0D AC 27 10 ..............'. 02F0 27 10 00 02 00 02 00 00 FF FF 03 E8 01 00 37 01 '.............7. 0300 00 37 FF FF 01 FF FF 02 FF FF 02 00 00 27 10 FF .7...........'.. 0310 FF 00 00 00 27 10 FF FF 00 FF FF 03 13 88 FF FF ....'........... 0320 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 ................ 0330 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 ................ 0340 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 ................ 0350 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF ................ 0360 FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF ................ 0370 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 ................ 0380 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 ................ 0390 88 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 ................ 03A0 FF FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF ................ 03B0 FF 02 13 88 FF FF 02 13 88 FF FF 02 13 88 FF FF ................ 03C0 02 13 88 00 00 00 00 00 FF FF 01 F4 07 D0 00 FF ................ 03D0 FF 00 00 27 10 FF FF 00 00 27 10 FF FF 00 00 27 ...'.....'.....' 03E0 10 FF FF 00 00 27 10 FF FF 0D AC 0A F0 FF FF 0D .....'.......... 03F0 AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF ................ 0400 FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A ................ 0410 F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D ................ 0420 AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF ................ 0430 FF 0D AC 0A F0 FF FF 0D AC 0A F0 FF FF 0D AC 0A ................ 0440 F0 FF FF 0D AC 0A F0 27 10 00 00 00 00 00 00 00 .......'........ 0450 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0460 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0480 00 00 00 00 00 00 00 FF FF 0C 80 01 F4 00 64 00 ..............d. 0490 00 00 28 00 0A FF FF 0C 80 01 F4 00 64 00 00 00 ..(.........d... 04A0 28 00 0A FF FF 0C 80 01 F4 00 64 00 00 00 28 00 (.........d...(. 04B0 0A FF FF 0C 80 01 F4 00 64 00 00 00 28 00 0A FF ........d...(... 04C0 FF 0C 80 01 F4 00 64 00 00 00 28 00 0A FF FF 0C ......d...(..... 04D0 80 01 F4 00 64 00 00 00 28 00 0A FF FF 0C 80 01 ....d...(....... 04E0 F4 00 64 00 00 00 28 00 0A FF FF 0C 80 01 F4 00 ..d...(......... 04F0 64 00 00 00 28 00 0A 00 24 0B FE 0B B8 0B EA 0C d...(...$....... 0500 12 0C 44 0C 76 0C 9D 0C CF 0D 01 0D 2A 0D 5C 0D ..D.v.......*.\. 0510 8E 0D B6 0D E8 0E 1A 0E 42 0E 74 05 DC 06 31 06 ........B.t...1. 0520 F1 08 03 09 5F 0A FD 0C DA 0E F3 11 44 13 CB 16 ...._.......D... 0530 86 19 75 1C 95 1F E4 23 63 27 10 FF FF 0B B8 0A ..u....#c'...... 0540 8C 0A FA 0B 4A 0B A4 0B F4 0C 4E 0C 9D 0C F8 0D ....J.....N..... 0550 48 0D A2 0D F2 0E 4C 0E 9C 0E F5 0F 46 0F A0 00 H.....L.....F... 0560 00 00 8C 01 18 01 F4 03 20 04 B0 06 90 08 D4 0B ........ ....... 0570 68 0E 4C 11 94 15 2C 19 28 1D 74 22 10 27 10 FF h.L...,.(.t".'.. 0580 FF 0B B8 0A 8C 0A FA 0B 4A 0B A4 0B F4 0C 4E 0C ........J.....N. 0590 9D 0C F8 0D 48 0D A2 0D F2 0E 4C 0E 9C 0E F5 0F ....H.....L..... 05A0 46 0F A0 00 00 00 8C 01 18 01 F4 03 20 04 B0 06 F........... ... 05B0 90 08 D4 0B 68 0E 4C 11 94 15 2C 19 28 1D 74 22 ....h.L...,.(.t" 05C0 10 27 10 FF FF 0B B8 0A 8C 0A FA 0B 4A 0B A4 0B .'..........J... 05D0 F4 0C 4E 0C 9D 0C F8 0D 48 0D A2 0D F2 0E 4C 0E ..N.....H.....L. 05E0 9C 0E F5 0F 46 0F A0 00 00 00 8C 01 18 01 F4 03 ....F........... 05F0 20 04 B0 06 90 08 D4 0B 68 0E 4C 11 94 15 2C 19 .......h.L...,. 0600 28 1D 74 22 10 27 10 FF FF 00 09 C4 00 00 00 00 (.t".'.......... 0610 27 10 0D AC 00 00 27 10 00 00 0F A0 27 10 00 00 '.....'.....'... 0620 00 00 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 FF ................ 0630 FF 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 FF FF ................ 0640 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 FF FF 00 ................ 0650 FF FF 00 00 00 03 FF FF FF FF FF FF FF FF FF FF ................ 0660 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0670 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0680 FF FF 00 0A FF FF 00 0F A0 01 13 88 02 FF FF 00 ................ 0690 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 88 02 FF ................ 06A0 FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 88 ................ 06B0 02 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 ................ 06C0 13 88 02 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F ................ 06D0 A0 01 13 88 02 FF FF 00 0F A0 01 13 88 02 FF FF ................ 06E0 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 88 02 ................ 06F0 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 01 13 ................ 0700 88 02 FF FF 00 0F A0 01 13 88 02 FF FF 00 0F A0 ................ 0710 01 13 88 02 03 01 03 02 03 01 03 02 03 01 03 02 ................ 0720 03 01 03 02 03 01 03 02 03 01 03 02 03 01 03 02 ................ 0730 03 01 03 02 03 01 03 02 03 01 03 02 03 01 03 02 ................ 0740 03 01 03 02 FF FF 00 01 2C 01 00 C8 02 FF FF 00 ........,....... 0750 01 2C 01 00 C8 02 FF FF 00 01 2C 01 00 C8 02 FF .,........,..... 0760 FF 00 01 2C 01 00 C8 02 FF FF 01 00 FF FF 01 00 ...,............ 0770 FF FF 01 00 FF FF 01 00 FF FF 01 13 88 01 0B B8 ................ 0780 02 FF FF 01 13 88 01 0B B8 02 FF FF 01 13 88 01 ................ 0790 0B B8 02 FF FF 01 13 88 01 0B B8 02 FF FF 01 17 ................ 07A0 70 01 0F A0 02 FF FF 01 17 70 01 0F A0 02 FF FF p........p...... 07B0 01 17 70 01 0F A0 02 FF FF 01 17 70 01 0F A0 02 ..p........p.... 07C0 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 ................ 07D0 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 ................ 07E0 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF ................ 07F0 FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 ................ 0800 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 ................ 0810 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 ................ 0820 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF ................ 0830 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 ................ 0840 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 ................ 0850 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF ................ 0860 FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 ................ 0870 00 00 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 ................ 0880 00 00 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 ................ 0890 FF FF 00 00 00 00 00 FF FF 00 00 00 00 00 FF FF ................ 08A0 0F 01 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 08B0 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 08C0 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 08D0 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 08E0 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 08F0 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 0900 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 0910 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 0920 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 0930 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 00 00 .......d........ 0940 FF FF 00 64 00 00 00 00 00 00 00 00 FF FF 00 64 ...d...........d 0950 00 00 00 00 00 00 00 00 FF FF 00 64 00 00 00 00 ...........d.... 0960 00 00 00 00 FF FF 00 64 00 00 00 00 00 00 FF FF .......d........ 0970 FF FF FF 00 00 00 00 00 00 00 00 ........... ------[ AA5 Input Report ]------ Structure Version = 1013 Firmware Version = 1036 Bootloader Version = 102 Hardware Version = 6000 Device Type = 2 (Aquaero 5 XT) 0000 0B 4F 17 61 03 F5 63 87 7B E9 04 0C 00 66 17 70 .O.a..c.{....f.p 0010 00 00 80 44 00 3B F1 B5 03 00 00 02 00 0F 00 00 ...D.;.......... 0020 00 00 00 03 C4 83 1C FF 00 00 02 07 00 FF FF 00 ................ 0030 0F A0 0F A0 01 F4 00 00 00 00 00 01 00 00 00 00 ................ 0040 FF DA FF D9 FF D9 FF DC FF D9 FF D9 FF DA FF D6 ................ 0050 A3 67 02 CC A3 81 01 CF A3 FE 01 BA A4 1B 01 4C .g.............L 0060 75 21 74 43 69 62 5D 41 7F FF 7F FF 7F FF 7F FF u!tCib]A........ 0070 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0080 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0090 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 00A0 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 00B0 0C F8 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 00C0 0B 44 0B 44 0B 22 0B 22 7F FF 7F FF 7F FF 7F FF .D.D."."........ 00D0 7F FF 7F FF 7F FF 7F FF 0E 4B 7F FF 7F FF 7F FF .........K...... 00E0 7F FF 7F FF 7F FF 7F FF 00 00 18 A7 00 00 1A 11 ................ 00F0 00 00 19 CE 00 00 1B 44 00 00 00 00 00 00 00 00 .......D........ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 FF FF 7F FF 7F FF 00 00 ................ 0120 00 00 7F FF FF FF 7F FF 7F FF 00 00 00 00 7F FF ................ 0130 FF FF 7F FF 7F FF 00 00 00 00 7F FF FF FF 7F FF ................ 0140 7F FF 00 00 00 00 7F FF 00 00 00 00 00 00 00 00 ................ 0150 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0160 7F FF 7F FF 7F FF 7F FF 0D AC 01 D4 0E 90 04 A5 ................ 0170 00 34 00 3D 00 7C 01 B5 0E 90 04 A6 00 00 00 00 .4.=.|.......... 0180 00 00 01 C0 0E 90 04 A9 00 00 00 00 00 00 01 A3 ................ 0190 0E 90 04 AA 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 01 01 00 37 04 C4 .............7.. 0200 01 A3 02 FF FF FF FF FF FF FF 00 00 00 00 00 00 ................ 0210 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 ................ 0220 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0230 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 27 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 '............... 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 0E 90 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 33 00 00 00 00 00 00 00 00 00 00 00 ....3........... 02D0 00 48 75 6D 69 64 69 74 79 20 34 00 00 00 00 00 .Humidity 4..... 02E0 00 00 00 00 00 00 00 57 61 74 65 72 20 71 75 61 .......Water qua 02F0 6C 69 74 79 20 31 00 00 00 00 00 00 00 57 61 74 lity 1.......Wat 0300 65 72 20 71 75 61 6C 69 74 79 20 32 00 00 00 00 er quality 2.... 0310 00 00 00 57 61 74 65 72 20 71 75 61 6C 69 74 79 ...Water quality 0320 20 33 00 00 00 00 00 00 00 57 61 74 65 72 20 71 3.......Water q 0330 75 61 6C 69 74 79 20 34 00 00 00 00 00 00 00 44 uality 4.......D 0340 35 20 70 75 6D 70 20 31 00 00 00 00 00 00 00 00 5 pump 1........ 0350 00 00 00 00 00 44 35 20 70 75 6D 70 20 32 00 00 .....D5 pump 2.. 0360 00 00 00 00 00 00 00 00 00 00 00 44 35 20 70 75 ...........D5 pu 0370 6D 70 20 33 00 00 00 00 00 00 00 00 00 00 00 00 mp 3............ 0380 00 44 35 20 70 75 6D 70 20 34 00 00 00 00 00 00 .D5 pump 4...... 0390 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF ................ 03A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 03F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0400 FF FF FF FF FF FF FF FF FF FE 76 D7 B0 ..........v.. Quote
Fiery Posted January 9, 2015 Author Posted January 9, 2015 anyway, here my aquaero debug dump where I don't see the aquastream temperature although it is connected to my aquaero: Thank you. We've completely revamped the temperature measurement logic on Aquaero and Aquaduct devices in the following AIDA64 beta update: http://www.aida64.com/downloads/latesta64xebeta It may cause a temporary issue for previously configured SensorPanel and LCD layouts, since the temperature indexes may have changed. It was necessary to do that in order to add support for all 52 temperature readings Aquaero/Aquaduct devices support. Quote
