TechNicaL Posted July 16, 2021 Report Share Posted July 16, 2021 This has been the excuse for several years now that it is on AMD to fix this issue. I am feeling at this time the developer of Aida64 just no longer able to support amd. Sadly i am feeling that this is a waste of $30 but such is life. If the developer is ever ready to continue troubleshooting this issue. I am willing to provide as many logs and testing as they would need. 3 Quote Link to comment Share on other sites More sharing options...
trancie27 Posted July 17, 2021 Report Share Posted July 17, 2021 While I totally agree, I dont see any alternitives to make a sensor panel for your pc, the radeon software overlay is, to put it lightly, lacking features. same for NZXT. I can't figure out rainmeter at all and from what i understand its resource heavy. this was really the only viable solution for my needs. and its incompatable with radeon cards. Quote Link to comment Share on other sites More sharing options...
boombastik Posted July 20, 2021 Report Share Posted July 20, 2021 I created an account here only to tell that the last version that don't has this bug is the: 5.99.4900 build date 19/11/2018 After this version i checked them all manually and all have the crash problem at least with rx580 and latest driver. So someone with older PC that don't care with latest change-log can use the version i mention above. It is compatible with latest windows 10 updates. 2 Quote Link to comment Share on other sites More sharing options...
trancie27 Posted July 27, 2021 Report Share Posted July 27, 2021 I'm sad it has come to this, but giving how long this has been an issue, I have used the secondary screen on my system for another project, It's now the display on my game server box. I will no longer be monitoring aida64 for updates. I wish ya'll the best! 2 Quote Link to comment Share on other sites More sharing options...
FrankieDedo Posted July 27, 2021 Report Share Posted July 27, 2021 So, no fix on AMD or AIDA64's behalf. At least, does it still crash if we disable GPU sensor polling? Quote Link to comment Share on other sites More sharing options...
boombastik Posted July 29, 2021 Report Share Posted July 29, 2021 It works if you disable the GPU sensor polling. I gave the last version that it works properly, now a simple fix is to tracking down what they change above that version and fix it. My personal opinion that the bug is in aida64 because hwinfo64 has the same sensor and i don't see a crash. And i am gonna bet that even someone use drivers from 2019 again it will crash with the last aida64. 1 Quote Link to comment Share on other sites More sharing options...
Edoardo001 Posted August 12, 2021 Report Share Posted August 12, 2021 On 7/29/2021 at 7:26 PM, boombastik said: It works if you disable the GPU sensor polling. I gave the last version that it works properly, now a simple fix is to tracking down what they change above that version and fix it. My personal opinion that the bug is in aida64 because hwinfo64 has the same sensor and i don't see a crash. And i am gonna bet that even someone use drivers from 2019 again it will crash with the last aida64. How to disable gpu sensor polling? Quote Link to comment Share on other sites More sharing options...
wONKEyeYEs Posted August 14, 2021 Report Share Posted August 14, 2021 On 8/12/2021 at 4:37 AM, Edoardo001 said: How to disable gpu sensor polling? File/Preferences/Stability/GPU sensor support. Quote Link to comment Share on other sites More sharing options...
TechNicaL Posted August 21, 2021 Report Share Posted August 21, 2021 As far as I can tell. The developers of Aida have just walked away from this issue. It is far easier to blame AMD then to try and fix their software. I know plenty of members of the community, including myself, have offered throughout the years to help them test and fix this issue but they never take us up on the offer. In 2021 do not waste your money on this software just get HWinfo or HWmonitor as they both can see gpu sensor information without crashing your pc which aida 64 cannot do. 3 Quote Link to comment Share on other sites More sharing options...
Edoardo001 Posted August 24, 2021 Report Share Posted August 24, 2021 On 8/21/2021 at 7:15 PM, TechNicaL said: As far as I can tell. The developers of Aida have just walked away from this issue. It is far easier to blame AMD then to try and fix their software. I know plenty of members of the community, including myself, have offered throughout the years to help them test and fix this issue but they never take us up on the offer. In 2021 do not waste your money on this software just get HWinfo or HWmonitor as they both can see gpu sensor information without crashing your pc which aida 64 cannot do. Maybe it’s true that the problem is Amd side but if other software not make is crash, it’s obvious that they can use other way to monitor gpu values without make gpu driver crash Quote Link to comment Share on other sites More sharing options...
jadoo Posted September 19, 2021 Report Share Posted September 19, 2021 I think this not a hardware problem, this would be software. Here I suggest you to install the AVG PC TuneUp & PC Tools Registry Mechanic which helps you to fix this issue. If you want to download just visit the getintopc. 1 Quote Link to comment Share on other sites More sharing options...
Edoardo Catalano Posted September 30, 2021 Report Share Posted September 30, 2021 It's an AMD bug, but no other monitoring software have this problem. It's obvius an excuse and even if isn't, you can just do a workaround to fix it since a lot of people will not buy this software anymore instead. Quote Link to comment Share on other sites More sharing options...
ConfyScenty Posted October 6, 2021 Report Share Posted October 6, 2021 It's 6th October 2021 and yet no good news from Aida64. Crashes are still a thing when using the software to monitor AMD cards - a problem that only happens with Aida64. Monitoring with other software like HWInfo64 or MSI Afterburner do not cause any stutters or crashes so pls... Aida64 devs, fix your stuff. 2 Quote Link to comment Share on other sites More sharing options...
Edoardo001 Posted October 20, 2021 Report Share Posted October 20, 2021 There’s a lot of people on forums and tech groups that ask for help because their pc crash without any reason with their new amd gpu. By asking”are you using Aida 64?” I’ve helped a lot of people. This must be fixed 1 Quote Link to comment Share on other sites More sharing options...
jt705 Posted October 21, 2021 Report Share Posted October 21, 2021 Just wanted to say I also have this problem, I have a amd 3600 b450 mother board and a Gtx 1080 Ti. My computer crashes regularly with gpu sensor enabled, but its work fine when I disable the gpu sensor Quote Link to comment Share on other sites More sharing options...
kaiuvve Posted October 21, 2021 Report Share Posted October 21, 2021 Heyjo, can somebody confirm that this issue is maybe fixed in the new Version 6.50? Or Maybe fixed with WIN11? See ya, Kai Quote Link to comment Share on other sites More sharing options...
Xoric Posted November 4, 2021 Report Share Posted November 4, 2021 Still occurring on Win 11 with 6.50.5800 i stopped using it for some time due to this bug, fired it up again recently to see if it would now be stable, but within the first hour i got a full system lockup. disabled and played for the next 3-4 hours without issue. specs are: Ryzen 5900x AMD 6800 32gb 3200MHz G.Skill DDR4 Win 11 Pro Build: 22000.282 Sensor panel display on external 1024x800 display Quote Link to comment Share on other sites More sharing options...
Zvrgolija Posted December 17, 2021 Report Share Posted December 17, 2021 (edited) As the "bombastic" user said above, the latest version of the program that works without problems is 5.99.4900. All other versions to date lead to a severe system crash when GPU temperature monitoring is turned on, and without it everything works perfectly. I don't know what the problem is with fixing it and all the next versions of the program are working, or they are not expert to do it properly or they don't want to do it. They have very stupid excuses that AMD is in question, when everyone who has a little brain sees that the problem is up to them. Has anyone tried the latest version of the program and has anything changed? Edited December 17, 2021 by Zvrgolija :) Quote Link to comment Share on other sites More sharing options...
JJeronimus Posted December 17, 2021 Report Share Posted December 17, 2021 Well, I had this problem for a long time and it gave me a headache until I found out that Aida64 in combination with AMD Radeon Adrenalin Drivers was the reason. After I stopped using AIDA64, everything was fine. Once in a while I try AIDA64 again and it hard-locks the machine, mostly within minutes. But not since Wednesday... I had the PC since then almost non-stop running for study, work and gaming. It also sat idle for many hours. No crash so far.... AMD Radeon Software version 21.11.3 (16-11-2021) FinalWire AIDA64 Extreme v 6.690.5900 (14-12-2021) I'll keep this post updated for a few days, lets see what happens. It looks good for now! Quote Link to comment Share on other sites More sharing options...
Zvrgolija Posted December 17, 2021 Report Share Posted December 17, 2021 4 hours ago, JJeronimus said: Well, I had this problem for a long time and it gave me a headache until I found out that Aida64 in combination with AMD Radeon Adrenalin Drivers was the reason. After I stopped using AIDA64, everything was fine. Once in a while I try AIDA64 again and it hard-locks the machine, mostly within minutes. But not since Wednesday... I had the PC since then almost non-stop running for study, work and gaming. It also sat idle for many hours. No crash so far.... AMD Radeon Software version 21.11.3 (16-11-2021) FinalWire AIDA64 Extreme v 6.690.5900 (14-12-2021) I'll keep this post updated for a few days, lets see what happens. It looks good for now! AMD Radeon Software has nothing to do with strange computer crashes, only AIDA is to blame. If the temperature indicator is on, it crashes with any AMD GPU driver. Quote Link to comment Share on other sites More sharing options...
Zvrgolija Posted December 18, 2021 Report Share Posted December 18, 2021 I had to post again because for the first time I didn't know how to post it. As the "bombastic" user said above, the latest version of the program that works without problems is 5.99.4900. All other versions to date lead to a severe system crash when GPU temperature monitoring is turned on, and without it everything works perfectly. I don't know what the problem is with fixing it and all the next versions of the program are working, or they are not expert to do it properly or they don't want to do it. They have very stupid excuses that AMD is in question, when everyone who has a little brain sees that the problem is up to them. Has anyone tried the latest version of the program and has anything changed? Quote Link to comment Share on other sites More sharing options...
CraigLee Posted December 26, 2021 Report Share Posted December 26, 2021 On 12/17/2021 at 2:11 PM, JJeronimus said: Well, I had this problem for a long time and it gave me a headache until I found out that Aida64 in combination with AMD Radeon Adrenalin Drivers was the reason. After I stopped using AIDA64, everything was fine. Once in a while I try AIDA64 again and it hard-locks the machine, mostly within minutes. But not since Wednesday... I had the PC since then almost non-stop running for study, work and gaming. It also sat idle for many hours. No crash so far.... AMD Radeon Software version 21.11.3 (16-11-2021) FinalWire AIDA64 Extreme v 6.690.5900 (14-12-2021) I'll keep this post updated for a few days, lets see what happens. It looks good for now! I still hard-lock using Radeon version 21.12.1 and AIDA64 Extreme latest. It's disappointing, but I think it's pretty clear Finalwire just doesn't care. Quote Link to comment Share on other sites More sharing options...
DaddyNinjaShark Posted March 12 Report Share Posted March 12 I bought AIDA64 extreme a week ago, and was thrilled until it started causing these same crashes. I thought my Rx580 was the culprit, and finally splurged on a 6700xt. The same crashes happen, and I am running a Ryzen 5 2600 with 16 gb of ram. I just did 2 error reports to AMD in the span of 15 minutes, same crash on 2 separate games. I am running 21.10.2 version of AMD software. I notice in the alerts, it says "default Radeon WattMan settings have been restored due to an expected system failure." Maybe that means it is a power sensor conflict. I have an 750w PSU with no issues there. If I can't run the sensor software safely on here, I might try to request a refund but willing to try some things first. :/ Quote Link to comment Share on other sites More sharing options...
Anthony Harvey Posted April 4 Report Share Posted April 4 I built my pc a year ago and it had endless crashes due to aida64. i cannot believe a company that is actively taking money for a product has let something like this continue for the amount of time that it has. its completely unstable with amd and makes my system unusable when installed. such a shame this was the perfect solution for me. i now have a sensor screen in my system without any sensors on. i wish someone would pull their finger out Quote Link to comment Share on other sites More sharing options...
Yiannis Kasidokostas Posted April 6 Report Share Posted April 6 Hello everyone, I've bought AIDA64 Extreme December 2021 for AUD $81 and since I've installed it I've experienced amazing crashes on my pc and pretty much whatever everyone is complaining about... I had no luck of thinking that the issue came from aida64 monitor software and started troubleshooting software and hardware.... I've spent AUD $4500 in new hardware and I've sold my previous one for a lot less than I've bought it... Last night googled if aida64 is responsible for crashes and here I am after 4 months (I feel stupid saying that took me long enough to realise that) Today I've sent a message at the support team addressing the issue (they know already) and I am waiting to hear back from them..... Fingers crossed they will reply and if we can get a fix it will be great just because the customisable layout of aida64 extreme is unique and I love my little monitor next to my main one showing me temps and all the stats.... Let's see... Quote Link to comment Share on other sites More sharing options...
