Kiwzi Posted September 10, 2017 Posted September 10, 2017 On 10.9.2017 at 5:57 PM, Fiery said: I'm really not sure what could cause in PrecisionX to make AIDA64 stop working. The next time you notice the loss of iCX-related sensor readings from the Sensor page, please create an updated nVIDIA SMBus Dump , so we can see what registers changed in what way from the normal state. Here you go nvidiasmbusdump icx working and precisionx running.txt nvidiasmbusdump icx not working and precisionx not running.txt Edit: Come to think about what you said about "PrecisionX to make AIDA64 stop working", it's the other way around, I need PrecisionX for Aida64 to show ICX readings. Quote
Fiery Posted September 19, 2017 Posted September 19, 2017 On 2017. 09. 10. at 10:24 PM, Kiwzi said: Here you go nvidiasmbusdump icx working and precisionx running.txt nvidiasmbusdump icx not working and precisionx not running.txt Edit: Come to think about what you said about "PrecisionX to make AIDA64 stop working", it's the other way around, I need PrecisionX for Aida64 to show ICX readings. Thank you. It's quite puzzling at this point We've tweaked a bit on it, but we're not 100% sure whether it makes it better or worse. Please check it out, and let us know how it works now. https://www.aida64.com/downloads/latesta64xebeta Quote
Kiwzi Posted September 25, 2017 Posted September 25, 2017 On 19.9.2017 at 11:30 AM, Fiery said: Thank you. It's quite puzzling at this point We've tweaked a bit on it, but we're not 100% sure whether it makes it better or worse. Please check it out, and let us know how it works now. https://www.aida64.com/downloads/latesta64xebeta Sorry to say it, but still no change, without PrecisionX there is still only one temp reading from the gpu. nvidiasmbusdump.txt Quote
Fiery Posted October 11, 2017 Posted October 11, 2017 On 2017. 09. 25. at 11:35 AM, Kiwzi said: Sorry to say it, but still no change, without PrecisionX there is still only one temp reading from the gpu. nvidiasmbusdump.txt Thank you. We've tweaked it a bit more, although we're not sure if it makes any difference... Please check it out: https://www.aida64.com/downloads/latesta64xebeta Quote
